rpi 3 plus
Tue Apr 10, 2018 9:20 pm
rpi 3 plus
before you buy the latest rpi 3 plus..
I am still struggling to get things working .. don't buy yet
Wed Apr 11, 2018 9:43 am
Re: rpi 3 plus
looks like the rpi3+ needs a new SSD image to run properly.. will post one in the next days
tested:
ibeacon
i2c sensors
onewire sensors
dht sensors
BLEconnect
Thu Apr 12, 2018 1:36 am
Hackencrash offline
Re: rpi 3 plus
If we use Ethernet wire and external USB Bluetooth adapter, is this OK?
Thu Apr 12, 2018 6:29 am
Re: rpi 3 plus
Have not done detailed testing:
Only Ethernet + internal BLE
And serial bleconnect seems to work. But have not done any timing etc.
Re: rpi 3 plus
Thu Apr 12, 2018 11:09 am
Re: rpi 3 plus
tested BLEconnect with 3 devices in parallel
with ethernet no extra BLE dongle
with ethernet and extra BLE dongle
with wifi and extra BLE dongle
with wifi no extra BLE dongle
all work fine -- no problems connecting ... ping over wifi :
- 5 GHz ~ 1.4 msec and 0 packet loss with and w/o extra BLE dongle
- 2.4Ghz ~1.5 msec and 0 packet loss with and w/o extra BLE dongle
looks like the same for 2 a,d 5 ghz
It looks very good now
Thu Apr 12, 2018 11:15 am
Hackencrash offline
Re: rpi 3 plus
Excellent - I wonder if the onboard WiFi driver now supports promisquous mode as that was something missing from the 3B?
Thu Apr 12, 2018 5:24 pm
Re: rpi 3 plus
how do you (can I ) test that?
Fri Apr 13, 2018 3:36 am
Hackencrash offline
Re: rpi 3 plus
Hi Karl,
One way would be to install the nmcli command line utility
sudo apt-get install network-manager
With this, you can scan for any wireless devices in the area (with signal strength) without them necessarily being on your WiFi network - a bit like what Fingbox does. Edit: Actually, I lie, it's Kismet that does this - https://gary-dalton.github.io/Raspberry ... ismet.html
Typical command:
nmcli d wifi
:idea: Here's a guide, (you will need step 4) but there may be better ones: https://gary-dalton.github.io/Raspberry ... nmcli.html
