master in Line '415' has error=''mac''
Fri Mar 16, 2018 4:18 pm
Hackencrash offline
There appears to be an error in master.py running on the rPi that manifests itself when selecting to run BLEconnect in parallel in Indigo on the rPi devices. Selecting to run in sequence clears the error.
Fri Mar 16, 2018 6:05 pm
Re: master in Line '415' has error=''mac''
Will check later today.
Fri Mar 16, 2018 8:42 pm
v .. . 212 @ https://www.indigodomo.com/pluginstore/59/ should fix it .
Sat Mar 17, 2018 11:14 am
Hackencrash offline
Thanks Karl,
Now I am getting:
in line'929' has error='string index out of range'
beacon loop bad data,skipping
When I switch back to run in sequence, the error clears.
Sat Mar 17, 2018 11:48 am
thats in regular ibeacon sensor (beaconloop.py) it receives a junk message (too short) ... besides the error message nothing should happen
I should check for the length .. next release
Sat Mar 17, 2018 1:11 pm
Also what kind of setup do you have. Rpi 2/3 WiFi?
Try to add another BLE dongle. The BLEconnect will use the extra dongle so that it does not conflict with the regular iBeacon
Sun Mar 18, 2018 11:26 am
in v ..213 it will check for more error conditions when receiving ibeacon packages on the RPI and will reject quietly non conforming messages.
ps also added for one wire temp sensors to show the serial number in the notes column.
Tue Mar 20, 2018 6:57 am
Hackencrash offline
Ah, OK, I did the config.txt and modprobe thing to disable my rPi3’s onboard Bluetooth to use the adapter only. Are you implying that it may be better not to do this as piBeacon can use both onboard and USB Bluetooth adapters at once?
Tue Mar 20, 2018 9:19 am
Issue with RPI3:wifi and BLE use the same hardware. There is a conflict when heavy BLE usage (sending=BLEconnect not listening=ibeacon) and wifi transmit is done at the same time.Then Wifi performance comes to a standstill.
==> solution: add another BLE dongle. pibeacon will use that one for BLEconnect
BLEconnect is trying to connect to the remote device (eg iPhone). During that time it OWNS the BLE stack. When 2 or more BLE connect programs are running this might create problems for regular ibeacon listening part.
So also here adding a second BLE dongle might help. Also I do not believe there is an advantage of having BLEconnect running in parallel for each target device. The timeouts are set to a few secs. That should not make any difference if a BLE device is home (retesting presence aver 60 secs), and when a single BLE device comes home it should get tested pretty quickly. Only issue I see when you have many BLE devices away and each of them is tried in sequence.
in summary: adding a second BLE dongle should improve the ibeacon side by separating BLEconnect from ibeacon
Tue Mar 20, 2018 12:05 pm
Hackencrash offline
Ah, OK, so in my case I should re-enable the on-board Bluetooth on my pi3 so that beacons can use that whilst BLE devices will use my USB BLE dongle. I had no idea piBeacon would automatically do that 8)
Tue Mar 20, 2018 12:46 pm
that feature was sneaked in secretly 8) (*)
some 2 months ago
def whichHCI():
    ret    = subprocess.Popen("hciconfig ",shell=True,stdout=subprocess.PIPE,stderr=subprocess.PIPE).communicate()#################################  BLE iBeaconScanner  ----> end
    # try again, sometimes does not return anything
    if len(ret[0]) < 5:
        time.sleep(0.5)
        print "U.whichHCI, hciconfig 2. try: ",ret
    lines = ret[0].split("\n")
    hci={}
    for ll in range(len(lines)):
        if lines[ll].find("hci")>-1:
            bus = lines[ll].split("Bus: ")[1]
            hciNo = lines[ll].split(":")[0]
            hci[hciNo] = {"bus":bus, "numb":int(hciNo[3:])}
            if lines[ll+1].find("BD Address:")>-1:
                mm=lines[ll+1].strip().split(" ")
                if len(mm)>2:
                    hci[hciNo]["BLEmac"]=  mm[2]
        #hci1:   Type: Primary  Bus: UART
        #   BD Address: B8:27:EB:D4:E3:35  ACL MTU: 1021:8  SCO MTU: 64:1
        #   UP RUNNING
        #   RX bytes:2850 acl:21 sco:0 events:141 errors:0
        #   TX bytes:5581 acl:20 sco:0 commands:115 errors:0
        #hci0:   Type: Primary  Bus: USB
        #   BD Address: 5C:F3:70:69:69:FB  ACL MTU: 1021:8  SCO MTU: 64:1
        #   UP RUNNING
        #   RX bytes:11143 acl:0 sco:0 events:379 errors:0
        #   TX bytes:4570 acl:0 sco:0 commands:125 errors:0
    if hci =={}: print lines
    return  hci
Tue Mar 20, 2018 4:53 pm
Hackencrash offline
Cool 8)
Just trying to decipher your Python...
If the hciconfig command reveals more than 2 Bluetooth adapters, e.g. onboard BT plus 2 USB BT adapters, what happens?
Tue Mar 20, 2018 5:41 pm
not an option, only 2 allowed don't know what will happen if you use more than 2
Tue Mar 20, 2018 6:15 pm
Hackencrash offline
Good, that saves an Amazon order
Tue Mar 20, 2018 8:00 pm
And this only works on rpi3. Not rpi2. 2 BLE dongle would be both on usb bus
Will add that for rpi 2 when I am back.
