piBeacon: 10- How to use plot beacon positions
Wed Feb 20, 2019 6:07 am
johnpolasek offline
Re: piBeacon: 10- How to use plot beacon positions
Didn't see your later posts till now, but playing last night at home, setting all the Zs to 0 didn't help, but when I moved the x coordinate back and forth, 70 and under appeared, 71 through 74 sometimes appeared depending on the y, and anything 75+ never appeared... I'll check those logs tonight when I can get to the machine that the server's running on. But don't waste a lot of time on this if you've got other stuff to do; like I said earlier, I rarely used this feature and didn't even notice it was having problems till I started playing with new types of beacons.
Wed Feb 20, 2019 9:29 am
I checked the code. And have not found any cut off besides x y max set in config.
So if you check the log file you should see
A if the plugin sends the device info to the plot pgm
B what the plot program does
- 1 receive which devices.
- 2 if it gets plotted
And the parameters used
Wed Feb 20, 2019 11:03 am
found it:
         if pos[0] > Yscale :   continue
         if pos[1] < 0     :      continue
should be:
         if pos[1] > Yscale :   continue
== tested x position against Ymax and not Xmax
and in my setup Ymax is bigger than Xmax so it never hit my setup
will post a fix
Thu Feb 21, 2019 2:00 pm
please check the latest release v7.103.273 for that bug fix .
Sun Feb 24, 2019 6:24 am
johnpolasek offline
Well I thought that fixed it, but then when I checked this morning, I discovered that it only updated the png once; the document in the documents folder is 2 days old, even though when I turned logging back on, it indicates that piBeacon THINKS it's updating the file:
    tart @ 2019-02-24 05:28:23.413105
    u'imageYscale :70
    u'imageXscale :140
    u'imageDotsY :824
    u'imageText :text on Top
    u'imageTextColor :#000000
    u'imageTextPos :0,0
    u'imageTextRotation :0
    u'distanceUnits :1.0
    u'imageOutfile :/Users/jeff/Documents/INDIGOplotD/BeaconDisplay.png
    u'compressImag :True
    u'Zlevels :0,12
    u'beacon data:
    B8:27:EB:6B:88:C9 {u'distanceToRPI': 1.0, u'status': u'up', u'symbolColor': u'#00F000', u'symbolAlpha': u'0.5', u'name': u'RPI-0', u'symbolType': u'square', u'position': [64.0, 55.0, 0.0], u'textColor': u'#008000', u'nickName': u' R-0'}
    B8:27:EB:F4:C3:A9 {u'distanceToRPI': 1.0, u'status': u'up', u'symbolColor': u'#00F000', u'symbolAlpha': u'0.5', u'name': u'RPI-3', u'symbolType': u'square', u'position': [105.0, 11.0, 0.0], u'textColor': u'#008000', u'nickName': u' R-3'}
    B8:27:EB:6E:E9:C1 {u'distanceToRPI': 1.0, u'status': u'expired', u'symbolColor': u'#00F000', u'symbolAlpha': u'0.5', u'name': u'RPI-1', u'symbolType': u'square', u'position': [67.0, 25.0, 0.0], u'textColor': u'#008000', u'nickName': u' R-1'}
    00:EA:24:3B:CB:C4 {u'distanceToRPI': 2.0, u'status': u'up', u'symbolColor': u'#000000', u'symbolAlpha': u'0.5', u'name': u'Jeffs xy', u'symbolType': u'dot', u'position': [96.7, 36.9, 0.0], u'textColor': u'', u'nickName': u'Jeffs'}
    00:EA:24:45:4A:F4 {u'distanceToRPI': 2.1, u'status': u'up', u'symbolColor': u'#0000FF', u'symbolAlpha': u'0.5', u'name': u'Johns XY', u'symbolType': u'smallCircle', u'position': [64.0, 54.0, 0.0], u'textColor': u'#0000FF', u'nickName': u'Johns XY'}
    F4:BC:BD:C4:F2:F5 {u'distanceToRPI': 4.7, u'status': u'up', u'symbolColor': u'#00FFFF', u'symbolAlpha': u'0.5', u'name': u'Tile', u'symbolType': u'smallCircle', u'position': [67.7, 50.7, 0.0], u'textColor': u'#FF0000', u'nickName': u'Tile'}
    B8:27:EB:2C:8D:4B {u'distanceToRPI': 1.0, u'status': u'up', u'symbolColor': u'#00F000', u'symbolAlpha': u'0.5', u'name': u'RPI-2', u'symbolType': u'square', u'position': [95.0, 42.0, 0.0], u'textColor': u'#008000', u'nickName': u' R-2'}
    3D:86:20:BD:A3:87 {u'distanceToRPI': 2.4, u'status': u'up', u'symbolColor': u'#00FF00', u'symbolAlpha': u'0.5', u'name': u'Nut', u'symbolType': u'smallCircle', u'position': [66.0, 54.1, 0.0], u'textColor': u'#FF0000', u'nickName': u'Nut'}
    B8:27:EB:A0:04:78 {u'distanceToRPI': 1.0, u'status': u'up', u'symbolColor': u'#00F000', u'symbolAlpha': u'0.5', u'name': u'RPI-4', u'symbolType': u'square', u'position': [40.0, 50.0, 0.0], u'textColor': u'#008000', u'nickName': u' R-4'}
    u'textOffY :0.339805825243
    u'textOffX :0.424757281553
    time used 0.00 -- setup fig, ax
    time used 0.18 -- loading background image file
    time used 0.27 -- adding text
    time used 0.27 -- now loop though the beacons and add them
    RPI-0 R-0 color:#00F000 edgecolor:#000000 symbol:square type:square distanceToRPI: 0.7 hatch: status:up
    RPI-3 R-3 color:#00F000 edgecolor:#000000 symbol:square type:square distanceToRPI: 0.7 hatch: status:up
    RPI-1 R-1 color:#00F000 edgecolor:#00F000 symbol:square type:square distanceToRPI: 0.7 hatch: status:expired
    Jeffs xy Jeffs color:#000000 edgecolor:#000000 symbol:dot type:circle distanceToRPI: 0.1 hatch: status:up
    Johns XY Johns XY color:#0000FF edgecolor:#000000 symbol:smallcircle type:circle distanceToRPI: 0.3 hatch: status:up
    Tile Tile color:#00FFFF edgecolor:#000000 symbol:smallcircle type:circle distanceToRPI: 0.3 hatch: status:up
    RPI-2 R-2 color:#00F000 edgecolor:#000000 symbol:square type:square distanceToRPI: 0.7 hatch: status:up
    Nut Nut color:#00FF00 edgecolor:#000000 symbol:smallcircle type:circle distanceToRPI: 0.3 hatch: status:up
    RPI-4 R-4 color:#00F000 edgecolor:#000000 symbol:square type:square distanceToRPI: 0.7 hatch: status:up
    textDeltaX 0.509708737864
    time used 0.30 -- making the plot:
    24 05:38:31 savebeaconPositionsFile {u'B8:27:EB:6B:88:C9': {u'distanceToRPI': 1.0, u'status': u'up', u'symbolColor': u'#00F000', u'symbo
    makeNewBeaconPositionPlots .. beaconPositionsUpdated: 0
    makeNewBeaconPositionPlots cmd: /usr/bin/python2.7 '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/makeBeaconPositionPlots.py' '/Library/Application Support/Perceptive Automation/Indigo 7.2/Preferences/Plugins/com.karlwachs.piBeacon/plotPositions/' &
    start @ 2019-02-24 05:38:31.598188
    u'imageYscale :70
    u'imageXscale :140
    u'imageDotsY :824
    u'imageTextPos :0,0
    u'Zlevels :0,12
    u'beacon data:
    00:EA:24:3B:CB:C4 {u'distanceToRPI': 1.8, u'status': u'up', u'symbolColor': u'#000000', u'symbolAlpha': u'0.5', u'name': u'Jeffs xy', u'symbolType': u'dot', u'position': [96.7, 37.3, 0.0], u'textColor': u'', u'nickName': u'Jeffs'}
    00:EA:24:45:4A:F4 {u'distanceToRPI': 2.0, u'status': u'up', u'symbolColor': u'#0000FF', u'symbolAlpha': u'0.5', u'name': u'Johns XY', u'symbolType': u'smallCircle', u'position': [64.0, 54.0, 0.0], u'textColor': u'#0000FF', u'nickName': u'Johns XY'}
    F4:BC:BD:C4:F2:F5 {u'distanceToRPI': 4.6, u'status': u'up', u'symbolColor': u'#00FFFF', u'symbolAlpha': u'0.5', u'name': u'Tile', u'symbolType': u'smallCircle', u'position': [67.7, 50.7, 0.0], u'textColor': u'#FF0000', u'nickName': u'Tile'}
    3D:86:20:BD:A3:87 {u'distanceToRPI': 2.2, u'status': u'up', u'symbolColor': u'#00FF00', u'symbolAlpha': u'0.5', u'name': u'Nut', u'symbolType': u'smallCircle', u'position': [66.0, 53.1, 0.0], u'textColor': u'#FF0000', u'nickName': u'Nut'}
    time used 0.16 -- loading background image file
    time used 0.25 -- adding text
    time used 0.25 -- now loop though the beacons and add them
    time used 0.28 -- making the plot:
I searched the entire machine and can't find any more recent copies, although there were a couple of ancient ones in the indigo and indigo 7.0 directories...
Sun Feb 24, 2019 6:46 am
could you open a terminal and run:
and post any printout
Sun Feb 24, 2019 8:30 am
johnpolasek offline
    Last login: Sun Feb 24 08:33:00 on ttys000
    DS9:~ jeff$ /usr/bin/python2.7 '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/makeBeaconPositionPlots.py' '/Library/Application Support/Perceptive Automation/Indigo 7.2/Preferences/Plugins/com.karlwachs.piBeacon/plotPositions/' &
    [1] 94569
    DS9:~ jeff$ Traceback (most recent call last):
    File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/makeBeaconPositionPlots.py", line 250, in <module>
    plt.savefig((piPositionsDir+"beaconPositions.png").encode('utf8')) # this does not work ==> ,bbox_inches = 'tight', pad_inches = 0)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/pyplot.py", line 561, in savefig
    return fig.savefig(*args, **kwargs)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/figure.py", line 1421, in savefig
    self.canvas.print_figure(*args, **kwargs)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backend_bases.py", line 2220, in print_figure
    **kwargs)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backend_bases.py", line 1962, in print_png
    return agg.print_png(*args, **kwargs)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backends/backend_agg.py", line 505, in print_png
    FigureCanvasAgg.draw(self)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backends/backend_agg.py", line 451, in draw
    self.figure.draw(self.renderer)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/artist.py", line 55, in draw_wrapper
    draw(artist, renderer, *args, **kwargs)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/figure.py", line 1034, in draw
    func(*args)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/axes.py", line 2086, in draw
    a.draw(renderer)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/text.py", line 563, in draw
    gc.set_foreground(self.get_color())
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backend_bases.py", line 921, in set_foreground
    self._rgb = colors.colorConverter.to_rgba(fg)
    File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/colors.py", line 365, in to_rgba
    'to_rgba: Invalid rgba arg "%s"\n%s' % (str(arg), exc))
    ValueError: to_rgba: Invalid rgba arg ""
    to_rgb: Invalid rgb arg ""
    could not convert string to float:
And just incidentally, it did update again once this morning about half an hour ago.
Sun Feb 24, 2019 8:39 am
johnpolasek offline
Found it looking at the above; Jeff's keys did not have a color set, so when he got home, the RGB of null killed the file generation. I set the color on that beacon and it;'s working now.
Sun Feb 24, 2019 12:59 pm
Will add some more checks to catch these
But if you open the device it should populate the colors w default values.
They should never be empty
But if you have never edited the device the prop might be empty.
Sun Feb 24, 2019 2:03 pm
adding some more check and improved logging to plot positions:
logfile will look like this - and ALL errors should show up.
makeNewBeaconPositionPlots ..   beaconPositionsUpdated: 6
plotPosition: ========= start @ 2019-02-24 13:59:44.712799  ===========
plotPosition: imageYscale        :30
plotPosition: imageXscale        :20
plotPosition: imageDotsY         :824
plotPosition: imageText          :3704 Stanford ave
plotPosition: imageTextColor     :#0F0F0F
plotPosition: imageTextPos       :0.5,34
plotPosition: imageTextRotation  :0
plotPosition: distanceUnits      :1.0
plotPosition: imageOutfile       :/users/karlwachs/plots/beacon.png
plotPosition: compressImage      :True
plotPosition: Zlevels            :0,5,10
plotPosition: textOffY           :0.145631067961
plotPosition: textOffX           :0.182038834951
plotPosition: beacon data:
plotPosition: 00:EA:24:20:D5:A4  {u'distanceToRPI': 4.8, u'status': u'up', u'symbolColor': u'#000000', u'symbolAlpha': u'0.5', u'name': u'b-xy-orange-1-60', u'symbolType': u'largeCircle', u'position': [89.6, 57.7, 5.0], u'textColor': u'#FF00FF', u'nickName': u'orange'}
plotPosition: 00:15:83:E5:12:D5  {u'distanceToRPI': 1.0, u'status': u'down', u'symbolColor': u'#00F000', u'symbolAlpha': u'0.5', u'name': u'RPI-1', u'symbolType': u'square', u'position': [1.0, 3.0, 0.0], u'textColor': u'#008000', u'nickName': u' R-1'}
plotPosition: time used 0.00 --   setup fig, ax
plotPosition: time used 0.17 --   loading background image file
plotPosition: time used 0.21 --   adding  text
plotPosition: time used 0.21 --   now loop though the beacons and add them
plotPosition: b-xy-orange-1-60            orange  color:#000000  edgecolor:#000000 symbol:largecircle type:circle   distanceToRPI:  1.2  hatch://  status:up
plotPosition: RPI-2                        R-2    color:#00F000  edgecolor:#000000 symbol:square      type:square   distanceToRPI:  0.7  hatch://  status:up
plotPosition: b-xy-volvo-keys-green-49    VG      color:#0F0F0F  status:up  use nickname text, no symbol
plotPosition: RPI-1                        R-1    color:#00F000  edgecolor:#00F000 symbol:square      type:square   distanceToRPI:  0.7  hatch:    status:down
plotPosition: Caption: text offset x= 0.22;   y=0.18
plotPosition: time used 0.24 --   making the plot:
plotPosition: time used 0.49 --   compressing the png file
plotPosition: time used 0.70 --   file sizes: original file: 131.5;  compressed file:  39.1  [KB]
plotPosition: time used 0.70 --   moving file to destination: /users/karlwachs/plots/beacon.png
plotPosition: time used 0.70 --   end  @ 2019-02-24 13:59:45.411490
24 14:00:03 savebeaconPositionsFile {u'B8:27:EB:20:90:32': {u'distanceToRPI': 1.0, u'status': u'up', u'symbolColor': u'#00F000', u'symbo
Wed Jun 19, 2019 3:32 pm
siclark offline
Hi Karl,
Any ideas why my background plot png file is not being used? I just get blank plots generated. I have it here.
/Volumes/Macintosh SSHD/Users/simon/indigo/piBeacon/plotPositions/background.png
is that correct?
Thanks... Simon
Wed Jun 19, 2019 5:45 pm
the directory for the output file and the background file is the same. it is set in config
you can set debug position plot on and check this log file:
/Library/Application Support/Perceptive Automation/Indigo 7.3/Logs/com.karlwachs.piBeacon/plugin.log
then you should see something like this::
18:43:20 makeNewBeaconPositionPlots cmd:  /usr/bin/python2.7 '/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/makeBeaconPositionPlots.py' '/Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/Plugins/com.karlwachs.piBeacon/plotPositions/' &
plotPosition: ========= start @ 2019-06-19 18:43:22.232706  ===========
plotPosition: imageText          :3xxx
plotPosition: 00:EA:24:20:D5:A4  {u'distanceToRPI': 0.5, u'status': u'expired', u'symbolColor': u'#000000', u'symbolAlpha': u'0.5', u'name': u'b-xy-orange-1-60', u'symbolType': u'square45', u'position': [8.0, 16.0, 5.0], u'textColor': u'#FF00FF', u'nickName': u'orange'}
plotPosition: B8:27:EB:20:90:32  {u'distanceToRPI': 1.0, u'status': u'up', u'symbolColor': u'#00F000', u'symbolAlpha': u'0.5', u'name': u'RPI-8', u'symbolType': u'square', u'position': [12.0, 18.0, 0.0], u'textColor': u'#008000', u'nickName': u' R-8'}
plotPosition: time used 0.16 --   loading background image file
plotPosition: time used 0.20 --   adding  text
plotPosition: time used 0.20 --   now loop though the beacons and add them
plotPosition: b-xy-orange-1-60            orange  color:#000000  edgecolor:#000000 symbol:square45    type:square45 distanceToRPI:  0.7  hatch://  status:expired
plotPosition: RPI-8                        R-8    color:#00F000  edgecolor:#000000 symbol:square      type:square   distanceToRPI:  0.7  hatch:    status:up
plotPosition: b-xy-volvo-keys-turcoise    VT      color:#000000  edgecolor:#000000 symbol:square45    type:square45 distanceToRPI:  0.7  hatch:    status:expired
etc
karl
Wed Jun 19, 2019 7:42 pm
sorry I was wrong, that's the output directory. The background is loaded from:
/Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/Plugins/com.karlwachs.piBeacon/plotPositions/background.png
will add automatic search in that directory and image output directory for background.png
Wed Jun 19, 2019 11:06 pm
added the background.png file location option in release 7.105.287 - set in config
Thu Jun 20, 2019 12:03 am
siclark offline
Thanks. First post in this thread has a different folder to put it in.
