Fresh pies every day
Tue Jul 18, 2017 4:13 pm
Hackencrash offline
I have 3 pi's
When I do an uptime on them it's several days, even though the piBeacon plugin is set to reboot them at 2am.
I've tried changing the reboot command to: sync; sync;reboot -f but this makes no difference.
When I select either: REBOOT rPi through ssh command or: Reboot rPi Force through socket both appear to work OK.
The properties file on the rPi's appears to be updated correctly.
Please can you explain the mechanics of how the daily reboot should work so that I can diagnose further?
If it's of any interest, I've never managed to get this working in the long time that I've been enjoying this fantastic plugin.
Thank you
Thu Jul 27, 2017 3:41 am
Hackencrash offline
Re: Fresh pies every day
These are, I think, the relevant parts of the ~/pibeacon/parameters file on the rPi:
"enableRebootCheck": "restartLoop,pingBoot"
"rPiRestartCommand": ""
"rebootCommand": "sudo sync; sync;sudo reboot -f"
"rebootHour": 2
"rebootWatchDogTime": "4"
Thu Jul 27, 2017 11:38 am
will look into it later today ..
Thu Jul 27, 2017 2:25 pm
do
ssh pi@x.x.x.x.x
cd pibeacon
nano parameters
you should find (not together though):
 "rebootCommand": "reboot now",
  "rebootHour": xx,
  "rebootWatchDogTime": "-1",
change xx to the current hour (0-23) and save (ctrl-o) and exit (ctrl-x)
the RPI should reboot within 1-2 minute. .. depending on your loop time / refresh rates ..
if that works, it should also work at 1 am .. I have not tried with 0 hours
if that does not work, your rpi could be bad (or likely a bug) ..
the new version should tell you about it in the indigo log file
also there is a permanent log file in the pibeacon directory . you should have lines like these in there.
20170727-01:22:51  master  master rebooting / shutdown reboot now   reboot at 2017-07-27 01:22:51.674656  regular_reboot_at_1_hours_requested
and by looking at it I found a bug somewhere else.. that might have an impact (the SPS check had a bug and forces getsensorvalues.py to restart every 5 minutes... it still works, but should not do that)
Fri Jul 28, 2017 7:48 am
Hackencrash offline
Hi Karl,
My RebootCommand and RebootWatchDogTime values are different to yours as can be seen by my second post above.
I changed the rebootHour from 2 to 13 in my case as the time on my rPi was 13:44. However, 45 minutes later and this rPi still hasn't rebooted.
Here is a tail of the ~/pibeacon/permanentLog.log file taken just now. Note that it does appear to be rebooting on some days (notice the gaps between the dates), but it is missing the reboot that should have taken place 45 minutes ago and note that it is the 28th today.
20170711-02:00:00  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-07-11 02:00:00.534994  regular_reboot_at_2_hours_requested
20170712-02:00:01  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-07-12 02:00:01.496611  regular_reboot_at_2_hours_requested
20170718-02:00:01  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-07-18 02:00:01.782468  regular_reboot_at_2_hours_requested
20170719-02:00:00  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-07-19 02:00:00.275634  regular_reboot_at_2_hours_requested
20170725-02:00:01  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-07-25 02:00:01.826513  regular_reboot_at_2_hours_requested
20170726-02:00:03  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-07-26 02:00:03.519663  regular_reboot_at_2_hours_requested
I did a ps -ef | grep .py and I can see that both master.py and beaconloop.py are running.
Fri Jul 28, 2017 9:27 am
It is a question of timing. If the pi programs read the config file at the right time it works. And that is triggered by the plugin sending the config file.
Have a version that does it right. Want to test for one night.
Thu Aug 03, 2017 1:29 am
Hackencrash offline
2 out of 3 rPi's rebooted with the new version, but that's not necessarily to say that the reboot isn't fixed.
I'll rebuild this rPi tonight as it could be foobar'd in some other way - will let you know.
Sat Aug 05, 2017 3:36 pm
johnfdl offline
I was so excited when I saw the thread title....I love fresh pies. :D
Sat Aug 05, 2017 5:29 pm
What’s your favourite pie? I’d say a nice rhubarb pie with custard!
Sat Aug 05, 2017 6:40 pm
roussell offline
Lemon is the one true pie
Sat Aug 05, 2017 6:53 pm
As for reboot.
If the rpi (ie master.py) starts before the boot time it will not boot that day. It has go over that time to set bootenable true
Sun Aug 06, 2017 10:44 am
Buttermilk (or my grandmother's chocolate)
Sun Aug 06, 2017 11:11 am
as I am on a no carb diet (-17 lbs =- 7.5kg) I take it with bacon
Mon Aug 07, 2017 5:09 am
Hackencrash offline
LOL!
I have rebuilt the pi that was not rebooting after the update to piBeacon (using the new SSD image) and here is the permanentLog.log output for today:
20170805-20:31:08  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-08-05 20:31:08.074673  change_in_ramdisk_for_logfiles
20170806-02:00:08  master  master rebooting / shutdown sudo sync;sync;sudo reboot -f   reboot at 2017-08-06 02:00:08.801555  regular_reboot_at_2_hours_requested
It is missing the 2am reboot for this morning (9th), yet everything else looks to be OK.
What do you think I should do?
P.S. The other 2 rPi's are absolutely fine
Mon Aug 07, 2017 9:07 am
I can't look into code for 3 weeks. will need to wait sorry. karl
