Errors after updating to 1.17.20
Thu Apr 14, 2016 10:33 pm
dnomode offline
Hello Karl,
I hope this is where you wanted me to post this.
After updating I started receiving some errors.
piBeacon                        in Line '2697' has error=''key id 808119854 not found in database''
  piBeacon                        in Line '2697' has error=''key id 969851054 not found in database''
  piBeacon                        in Line '2697' has error=''key id 1206880738 not found in database''
I deleted the three XY iBeacons from indigo and only two showed back up. I know the iBeacon is working because its detected by the XY Find It app. Good thing is, I'm no longer getting the above error.
I'm getting an error that one of the beacons is not set up. This error just keeps coming up over and over again.
piBeacon                        device not fully defined, please edit Edmond's Keys pi# not defined com.karlwachs.piBeacon : (dict)
     SupportsBatteryLevel : true (bool)
     address : 00:EA:23:2F:5F:24 (string)
     beaconTxPower : 20 (integer)
     created : 0 (integer)
     expirationTime : 90 (integer)
     fastDown : 0 (string)
     note : beacon (string)
     piServerNumber :  error contact author (string)
     signalDelta : 999 (integer)
     typeOfBeacon : xy (string)
     updateSignalValuesSeconds : 0 (integer)
     uuid : 07775dd0111b11e491910800200c9a66-9007-24356 (string)
I'm also getting a web server error that also keeps coming up over and over again.
Apr 14, 2016 9:13:29 PM
  WebServer                       request to set variable "pi_IN_0" value to "{"pi_IN_":"0","ipAddress":"10.0.1.19","sensors":{"BLEconnect":{"1517931032":{"D0:03:4B:BC:2D:ED":{"txPower":12,"signal":-17}}}},"ts":"1460693609=PDT"}" from 10.0.1.19
  WebServer                       request to set variable "pi_IN_0" value to "{"pi_IN_":"0","ipAddress":"10.0.1.19","sensors":{"BLEconnect":{"142624969":{"78:D7:5F:BC:4F:FB":{"txPower":12,"signal":-9}}}},"ts":"1460693612=PDT"}" from 10.0.1.19
  WebServer                       request to set variable "pi_IN_0" value to "{"msgs":[["00:EA:23:2F:5F:24",1,"0-0-0",-60.2,-58.7,54,""],["00:EA:23:2F:CC:47",1,"0-0-0",-69.2,-49.0,14,""],["14:99:E2:24:B6:A5",1,"0-0-0",-90.6,3.0,116,""]],"pi_IN_":"0","ts":"1460693617=PDT","secsCol":"60","mac":"B8:27:EB:58:95:A3","ipAddress":"10.0.1.19"}" from 10.0.1.19
Apr 14, 2016 9:14:36 PM
  WebServer                       request to set variable "pi_IN_0" value to "{"msgs":[["40:F4:F6:AE:6C:FA",3,"0-0-0",-76.1,79.0,17,""],["00:EA:23:2F:5F:24",1,"0-0-0",-60.4,-57.9,54,""],["00:EA:23:2F:CC:47",1,"0-0-0",-66.8,-49.0,13,""],["14:99:E2:24:B6:A5",1,"0-0-0",-90.3,3.0,122,""]],"pi_IN_":"0","ts":"1460693676=PDT","secsCol":"58","mac":"B8:27:EB:58:95:A3","ipAddress":"10.0.1.19"}" from 10.0.1.19
Apr 14, 2016 9:14:59 PM
  WebServer                       request to set variable "pi_IN_Alive" value to "{"pi":"0","ts":"1460693699=PDT"}" from 10.0.1.19
Apr 14, 2016 9:15:38 PM
  WebServer                       request to set variable "pi_IN_0" value to "{"msgs":[["00:EA:23:2F:5F:24",1,"07775dd0111b11e491910800200c9a66-9007-24356",-60.3,-57.9,53,""],["14:99:E2:24:B6:A5",1,"0-0-0",-90.5,3.0,145,""],["00:EA:23:2F:CC:47",1,"0-0-0",-66.2,-49.0,14,""],["40:F4:F6:AE:6C:FA",1,"0-0-0",-86.0,3.8,171,""]],"pi_IN_":"0","ts":"1460693738=PDT","secsCol":"61","mac":"B8:27:EB:58:95:A3","ipAddress":"10.0.1.19"}" from 10.0.1.19
To recap, one of my iBeacons no longer shows up in Indigo, device not fully defined error and WebServer error.
Thanks for your help Karl
Edmond
Thu Apr 14, 2016 11:51 pm
Re: Errors after updating to 1.17.20
this is not an error message. indigo web server is logging its activity. to switch if off use the menu feature to turn off web server logging:[quote] WebServer request to set variable "pi_IN_0" value to "{"msgs":[["00:EA:23:2F:5F:24",1,"07775dd0111b11e491910800200c9a66-9007-24356",-60.3,-57.9,53,""],["14:99:E2:24:B6:A5",1,"0-0-0",-90.5,3.0,145,""],["00:EA:23:2F:CC:47",1,"0-0-0",-66.2,-49.0,14,""],["40:F4:F6:AE:6C:FA",1,"0-0-0",-86.0,3.8,171,""]],"pi_IN_":"0","ts":"1460693738=PDT","secsCol":"61","mac":"B8:27:EB:58:95:A3","ipAddress":"10.0.1.19"}" from 10.0.1.19[/quote
for the rest: try the following
- in menu "(un) Ignore INDIVIDUAL iBeacons".. "Delete tracking History of .. < all beacons>".
- then enable new i beacons
also delete "Edmond's Keys" it seems to be screwed up.
the field "piServerNumber" has " error contact author" as contents not a number.
I have mistake in the code:
errorDict["piServerNumber"] = " error contact author"
should have been
errorDict["errormsg"] = " error contact author"
it came from the fact that while defining a device in the UI something went wrong and it came to that exception As I never had that exception, I never go that problem..
hope that helps
Fri Apr 15, 2016 7:43 am
dnomode offline
Are you talking about menu item labeled "Replace Indigowebserver file by reducing logging option version"
The beacon showed up again. I forgot what you had me use before and I can't find it. What should I set the txPower -dBm value at? I'm using XY beacons.
Edmonds keys seem fine now.
Edmond
Fri Apr 15, 2016 3:53 pm
.. YES
Users browsing this forum: No registered users and 21 guests
