HI Karl
Think it has to do with the blank ipAddress?
This rpi has a USB wifi connector (to use big antenna) as far away.
Occasionally gets 2 ip address 192.168.1.185 and on from the unwanted wlan1 adpater 192.168.1.42
Typically I disable that wlan1 with sudo ifconfig wlan1 down, and all ticks over until reboot.
ifconfig
- Code: Select all
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:c4:3e:e3 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 619 bytes 149512 (146.0 KiB)
TX packets 619 bytes 149512 (146.0 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.185 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::f185:3dda:a1eb:bfde prefixlen 64 scopeid 0x20<link>
ether e8:4e:06:0c:32:39 txqueuelen 1000 (Ethernet)
RX packets 14125 bytes 2572946 (2.4 MiB)
RX errors 0 dropped 133 overruns 0 frame 0
TX packets 2154 bytes 350569 (342.3 KiB)
But now getting (after resend all files) no ip address?
- Code: Select all
27-08:53:25 piBeaconUtils writeTZ L:1333 Lv:30 cBY:master changing timezone executing
27-08:53:26 piBeaconUtils writeIPtoFile L:1627 Lv:30 cBY:master writing ip number to file >><< reason:
27-08:53:31 master checknetwork0 L:1621 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
27-08:53:39 master checknetwork0 L:1621 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
27-08:53:46 master checknetwork0 L:1621 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
27-08:53:53 master checknetwork0 L:1621 Lv:30 no ip number working, trying again, indigoServerOn:True, ip:
27-08:53:53 master checknetwork0 L:1613 Lv:30 no ip number working, giving up, running w/o ip number, setting mode to clockMANUAL
27-08:53:55 piBeaconUtils writeTZ L:1333 Lv:30 cBY:master changing timezone executing
27-08:53:55 master readNewParams L:382 Lv:30 UPS-V2 interface NOT enabled
27-08:54:02 piBeaconUtils writeTZ L:1333 Lv:30 cBY:ADS1x15 changing timezone executing
27-08:54:02 ADS1x15 readParams L:611 Lv:30 ==== Start ADS1x15 ===== @ i2c:73; inputC:0; deltaX:0.1, gain:6144, resModel:1
27-08:54:02 ADS1x15 readParams L:613 Lv:30 ==== Start ADS1x15... sendToIndigoEvery:60.0;minSendDelta:4.0; sensorRefreshSecs:10.0,all i2c->devids:{73: [u'297270947', u'1036561108', u'1021059064', u'752082303']}
27-08:54:02 piBeaconUtils getIPNumber L:640 Lv:30 cBY:ADS1x15 no ip number defined
27-08:54:02 ADS1x15 execADS1x15 L:679 Lv:30 no ip number working, giving u
Ipaddress seems to be False Alarm - Sorry
Resend everything and reboot seems to have resolved the ipAddress
The status still is recording 'bad Sensor data, disconnected'
That rpi is on a long long power cable above a water tank in waterproof box.
No surprising is undervolt; haven't got around to upgrading the gauge of cable...
