Page 1 of 78
Posted:
Wed Nov 25, 2015 1:03 pm
by kw123
use this thread to discuss the piBeacon plugin
Re: piBeacon presence monitoring plugin discussions
Posted:
Wed Dec 02, 2015 8:11 am
by ac4lt
This looks really interesting. Might have to pick up a Pi to try it out.
Do you think the apple watch would work as a beaconing device with this?
Posted:
Wed Dec 02, 2015 8:43 am
by kw123
If it behaves like beacon and advertises , yes.
I now have 9 PIs in my house and I am covering everything. I am working on a version that is completely self configuring. Only need to put in the ssd ...
Posted:
Wed Dec 02, 2015 9:01 am
by ac4lt
My guess is that it doesn't but sticking a Radius Dot or something similar on a key chain wouldn't be a problem. Now all I have to do is fine some time....
Posted:
Wed Dec 02, 2015 9:25 am
by kw123
the biggest challenge I have to figure out is which BLE device is what. There are too many. The only info they deliver is the MAC number, UUID Major and Minor numbers.
I have not found a list where those are mapped to producers. With IP mac numbers there are maps for vendors/ suppliers available
The detective wok is to isolate them: find with which PI they are communicating, interpolate between them , then try to switch some devices in the area on / off see if any BLE entry goes offline.
Posted:
Sun Dec 06, 2015 11:30 pm
by kw123
http://forums.indigodomo.com/viewtopic.php?f=187&t=15152&p=106411#p106411New Version 0.9.9 has been released. This is close to a released product. Several weeks of debugging and tuning went into it.
new features:- added Exclude/Include list for iBeacons that are not interesting = no indigo devices created, no updates etc.
- added exclude "family of beacons" list. It looks as if cars have BLE devices with a common UUID (first xx characters are 1a13ff4c000c0e .....). They show up once (while they drive by) and then not any more. With this option you can define a UUID string that will exclude those from being tracked i.e. no indigo devices will be generated and no history is kept
- Distance calculation was added. You will see the distance between the beacon and egPi # 3 in the state Pi_3_Distance in the beacon. It is in Meters.
- As there are MANY updates especially when you have many PIs as they see themselves as beacon, you have an option to reduce the update frequency of indigo states for PIs themselves. From regular (every new message) to only every 5 minutes-- this is reasonable as you should not see PI's appear and disappear and they should be stationary.
- Several configuration help menus and reports were added: update PIs, restart PIs, restart Plugin web server, configure Wifi, manage Bacon lists etc.
- Added interface to FINGSCAN to enable FINGSCAN to use beacons for presence magagement . The new FINGSCAN will be posted tomorrow
- Option to clear history of beacons tracked
- All menue items have tool tips - leave the mouse on the items and the tool tip will pop up
- Some more error control was added i.e. if the RSA keys do not match, the plugin will change the .ssh/known_hosts file to enable access to the new PI with its IP number, it deletes the old RSA key and enables the PIs to be put into the this list
This plugin/ setup enables a very fast reliable local presence monitoring system independent of any internet connection. So far no false positives or negatives in my setup.
The load on the Indigo server is small ~ 1-2%. The network load is also small ~ 10Kbit every 60 seconds per Pi server if no new beacons appear. When a new beacon appears it will generate ~ 3 messages immediately (3 kByte), then back to normal. Mostly negligible
Posted:
Tue Dec 08, 2015 12:25 am
by rhanson
Will this work on the new PI-Zero, the $5 pi?
Apologies if that's a dumb question, I don't know my way around the various Pi devices yet.
Posted:
Tue Dec 08, 2015 4:43 am
by kw123
It should. Key question is how do you get the wifi and Bluetooth dongles working.
Posted:
Fri Dec 11, 2015 10:32 pm
by olympus
This looks brilliant!
Forgive me if I've missed a step, but I think I'm stuck.
I've loaded the raspi image on the SD and have it booted. I've got the plugin installed and configured. I've went through the Setup Pi servers and Send Config to Pi Server routines, but I'm not seeing any devices. I've got iPhones, iPads, Apple Watches and some radbeacon dots.
Any ideas?
Posted:
Fri Dec 11, 2015 10:39 pm
by kw123
debugging that remotely is difficult.. if you like we can do a Skype session. that would likely be MUCH faster.
The key is the proper setup of the pi.
but could you do
change the debug level for the pi to 1, then send config to pi
check if pi is running with terminal
ping ipnumber of pi
after it reboots
ssh pi@ipnumber and enter password
then
tail logfile
you should see something happening.
if not type
ps -ef | grep beacon
check if you see some programs running
Will be posting a new version tonight, may be you can wait until then.
some stability (too many open files, need to close files, not just open them) and some minor changes.
Which bluetooth dongle are you using.?
Posted:
Fri Dec 11, 2015 10:49 pm
by olympus
Thanks for the quick response.
If you're pushing out a new version tonight, I'll just save you the time and see if the new version sets things straight; no worries.
I set the debug on the pi to 1 and pushed out the new config. After it rebooted this is what I found in the logfile.
- Code: Select all
pi@pibeacon ~ $ tail logfile
debug: 1; loopMaxCallBLE: 300; sendAfterSeconds: 60; collectMsgs: 3
ble thread started
secsCollected, data 0=1=5C:F3:70:6D:E7:25=0C:F3:EE:00:31:46,2f234454cf6d4a0fadf2f4911ba9ffa6-1-1,-70.0,-63.0,3=
I picked up some of the iogear bluetooth dongles you suggested.
Am I supposed to create the piBeacons Indigo folder? Also, when it's working are devices supposed to show up in Indigo automatically?
Thanks for the help.
Posted:
Fri Dec 11, 2015 10:51 pm
by kw123
That log file looks good
Could you do
cat parameter.fixed and .pi. And post.
Posted:
Fri Dec 11, 2015 10:56 pm
by olympus
pi@pibeacon ~ $ cat parameters.fixed
debug=1
loopMaxCallBLE=300
collectMsgs=3
sendAfterSeconds=60
rebootSeconds=86400
ipOfServer=10.0.1.2
pi@pibeacon ~ $ cat parameters.ip
portOfServer=9931
myPiNumber=1
This also keeps showing up in the Indigo log.
- Code: Select all
piBeacon web server restarted unsuccessfully, giving up
Posted:
Fri Dec 11, 2015 10:58 pm
by kw123
looks good too
open finder goto documents/pibeacon
and double click piwebserver.log
you should see something like this:
- Code: Select all
22:55:55 IP= 192.168.1.xx #cycles= 34
0
5C:F3:70:6D:DA:75
5C:F3:70:69:69:FB,2f234454cf6d4a0fadf2f4911ba9ffa6-1-1,-59.0,-94.1,99
5C:F3:70:6D:DA:7A,2f234454cf6d4a0fadf2f4911ba9ffa6-1-1,-59.0,-90.6,94
5C:F3:70:6D:D9:4A,2f234454cf6d4a0fadf2f4911ba9ffa6-1-1,-59.0,-73.0,273
5C:F3:70:6B:BE:A8,2f234454cf6d4a0fadf2f4911ba9ffa6-1-1,-59.0,-86.5,80
00:15:83:E5:12:D5,010300d512-58755-5376,0,0,83
5C:F3:70:6D:DA:76,2f234454cf6d4a0fadf2f4911ba9ffa6-1-1,-59.0,-80.4,271*
if not do a restart web server # 1
Posted:
Fri Dec 11, 2015 11:00 pm
by kw123
AND make sure a pibeacon is switched on: e.g. the green led on the radius beacon should flash once and hold it next to the raspberry ~ 1 meter
