Geofence and Indigo
Thu Jan 12, 2017 5:45 am
midd offline
Geofence and Indigo
So I finally figured out how to set up a geofence in Home Remote. But how do I integrate it with indigo. I'm trying to replace iFindstuff. I have variables and triggers setup through that. I want to switch them over to Home Remote's geofence.
Thanks.
Indigo 7, Mojave on a 2009 Mac Pro..
Thu Jan 12, 2017 6:17 am
Japple55 offline
Re: Geofence and Indigo
These should get you started. The first two are from the documentation (lots of good stuff there) and the last one is a bunch of examples posted by howardtp.
http://bouncingball.mobi/apps/files/Hom ... _Attribute
http://bouncingball.mobi/apps/files/Hom ... tle=Indigo
viewtopic.php?f=186&t=15080&start=45#p105873
Thu Jan 12, 2017 7:35 am
midd offline
Thanks for the tips. I've seen the documentation but it's still a little unclear. I would need two Geofence actions, one for entering and one for exiting? that's how I set it up. I have the app configured to my reflector's address.
So basically I'm creating a trigger in the form of an action group that will execute when i enter or exit my geofence in home remote? I'm not home so I'm trying to picture it in my head. lol
Thu Jan 12, 2017 10:49 am
I'll look later if you don't sort it; I don't use geofence so haven't looked at it.
Thu Jan 12, 2017 12:21 pm
ac4lt offline
I'm using the home remote app also so I can try to help if you need it. Yes, you do need two actions, one for entering and one for leaving the geofence. The entering action will set an indigo virtual device to on and leaving will set it to off. I've been using it for the last 2-3 weeks and it's been 100% reliable for me so far. I've been using geofences around 100m I'm diameter which has been precise enough for my needs.
Thu Jan 12, 2017 4:25 pm
midd offline
Thanks. I think I figured it out. Like I said, I had triggers setup for iFindstuff, I took the action part of each trigger and created an action group. I will have to setup a separate action group for each phone. Then I'll be able to adjust hvac system based on if anyone is home or not.
My reflector is down right now and I can't test it out.
quote="ac4lt"]
I'm using the home remote app also so I can try to help if you need it. Yes, you do need two actions, one for entering and one for leaving the geofence. The entering action will set an indigo virtual device to on and leaving will set it to off. I've been using it for the last 2-3 weeks and it's been 100% reliable for me so far. I've been using geofences around 100m I'm diameter which has been precise enough for my needs.[/quote]
Thu Jan 12, 2017 7:52 pm
midd offline
So I'm just double checking as I'm finally home and my reflector is up again.
So I created an action for indigo. which will execute an action group to toggle variables that I am home. Then I go back and setup the geofence. Home Remote will execute the action group once I enter the geofence? I'm only asking because I didn't set it up in that order. I did the execution of the action group first, then I set up the geofence to enter it.
