Not connecting to Indigo server
Sun Mar 06, 2016 5:44 pm
gtreece offline
Anyone else having issues getting the 3.0 version to connect to the Indigo Server (with the Indigo action type)? The HR app finds the server when it searches for it, but it's not connecting, and not giving me any messages or anything. The Indigo logs are not showing a connection attempt through the web server.
I'm not new to Indigo, and the web server is working fine. Browser connects are working fine.
I'll try setting up some URL based actions to see what that does. Just wondering if anyone else is having any connectivity problems with HR to Indigo.
Sun Mar 06, 2016 6:13 pm
tatrog offline
Re: Not connecting to Indigo server
Just checked and my HR is working fine from iPhone ,apple watch, and Apple TV.
Sun Mar 06, 2016 10:41 pm
gtreece offline
A URL action to trigger an action in Indigo works. Same server address and credentials. So it seems to be something with the Indigo action type in Home Remote, at least as it relates to my server somehow (6.1.6 Pro).
Mon Mar 07, 2016 7:42 am
Gary_BBGames offline
I have checked, and my version is 6.1.6 too.
If it was bad username or password it would say, and if it was bad data it would say.
If it failed to connect it would say too.
This leads me to believe the data format is "correct", but it's maybe the format is not what I am expecting or have seen before.
If you could send me your actions.son and devices.json I will load it up and have a look.
Mon Mar 07, 2016 9:51 pm
gtreece offline
Gary, I responded to your email, with some json output.
Mon Mar 14, 2016 5:11 pm
gtreece offline
Anything yet? I'm still not having any success.
Tue Mar 15, 2016 12:42 am
Apologies for not getting back to you yet. The whole family came down with something terrible so we've all been out of action. I will endeavour to check today.
Have you upgraded Indigo to tr new 1.7 release?
Tue Mar 15, 2016 10:41 am
gtreece offline
Yes, I did update to the 6.1.7 release, and I am seeing the same behavior.
I have tested on iOS 9.2.1 as well as 9.3 beta versions on a separate device. Same results across both.
Tue Apr 05, 2016 10:50 pm
gtreece offline
Any ideas yet, as to what might be going on with my setup? I've re-checked periodically, and am continuing to see the same behavior.
Tue Apr 05, 2016 11:55 pm
I don't know where you are so this might be a silly question - do you use any foreign or Unicode characters in your device or action names?
Wed Apr 06, 2016 11:22 pm
gtreece offline
No, I have not intentionally used any, and have not found any unintentional instances either. I sent my devices and actions json to Gary to look at a while back, and was hoping he found something to explain the behavior.
