Couple of bugs
Fri Nov 20, 2015 12:59 am
Couple of bugs
Hi Gary,
When in the iPhone app and you go to the "Login and leave the iOS device running" page whatever you call that, then hit "Login" you get options for Facebook a and Twitter.
If you don't have either account, there's no way out of that page without force-quit.
Second isn't a bug as such, but when you go to email yourself the Config from iOS app (when you've just turned the setting on, and app tells you it's in Docs or available to email) - the subject line of the email that opens is white text so you can't see that the subject is prefilled.
Peter
Wed Nov 25, 2015 7:15 am
Gary_BBGames offline
Re: Couple of bugs
Hey Peter, thanks for spotting that... There is a back button but it's gone missing! There should be an image too. I'll fix that in 2.8.
As for the white text, I'll check that out too. Thanks.
Tue Dec 01, 2015 2:53 pm
Re: Couple of bugs
Hey Peter, the white text bug is fixed in 2.9. Beta in a few days.
Ta :)
Thu Dec 17, 2015 4:47 am
Re: Couple of bugs
Hi Gary - small thing:
When you first successfully connect to the Indigo Server, the pop-up dialog says,
"And Indigo Reflector has been found. Would you like to use it?"
Cheers,
Dave
Thu Dec 17, 2015 4:52 am
Re: Couple of bugs
Bugger. Changed and will be in the update.
Thanks for the spot.
