Page 1 of 11
indigo utilities discussion
Posted:
Thu Oct 08, 2015 2:03 pm
by kw123
Re: indigo utilities discussion
Posted:
Sat Oct 24, 2015 7:06 pm
by kw123
new version 1.1.3 posted :
http://forums.indigodomo.com/viewtopic.php?f=164&t=14825fixed:- print device states etc works now with all options in Postgres
- fixed some spelling and improved the tables to make sure it is self explaining
new:- added option to print device.name-- device.id to log file. This is useful if you have the device.id but want to know the device.name
Posted:
Fri Oct 30, 2015 9:19 am
by kw123
version 1.2.1
added printout of zwave network: all devices with their network numbers and neighbors. This is useful if you want to debug your z-wave network
http://forums.indigodomo.com/viewtopic.php?f=164&t=14825Karl
Posted:
Fri Oct 30, 2015 10:08 am
by autolog
Hi karl,
Very useful - Thanks
It poses a question though and this is just one example:
I have a battery operated device (a Stella-with address 33).
I have a TKB Power switch (mains powered) - It shows a list of neighbours including 33 (the battery device).
Just wondering how Zwave differentiates between battery and non-battery devices and more specifically which devices are relays.
Obviously sending a command via the battery device wouldn't work if it was asleep.
Recently when including any z-wave device, my Z-Stick S2 is taking a very long time to do the include
Posted:
Fri Oct 30, 2015 2:44 pm
by howartp
Zwave has a property called 'supports routing' (well, not sure what it's actually called, but...)
Battery devices always have this as False, as they will never relay.
I believe when you scan for neighbours, the scan also reads that property - so the device you're scanning from will know that it cannot route through that battery device.
I further suspect that mains devices don't see battery devices when scanning neighbours, so won't add them to their neighbour list - I suspect it's only when you scan neighbours from the battery device (and have thus woken it up) that IT sees the mains device and updates both neighbour lists.
Posted:
Fri Oct 30, 2015 4:34 pm
by kw123
the info is from :
indigo.server.log(indigo.devices[devnumber].globalProps["com.perceptiveautomation.indigoplugin.zwave"]["zwNodeNeighborsStr"])
it is the zwave neighbor list that indigo has it its properties.
you can get everything indigo has: with
indigo.server.log(unicode(indigo.devices[devnumber])) .. not nicely formatted though(*)
(*)which would look like for the key fob :
u'address : 8\nbatteryLevel : 98\nbuttonGroupCount : 0\nconfigured : True\ndescription : 008 - \ndeviceTypeId : zwCustomType\ndisplayStateId : batteryLevel\ndisplayStateImageSel : None\ndisplayStateValRaw : 98\ndisplayStateValUi : 98%\nenabled : True\nenergyAccumBaseTime : None\nenergyAccumTimeDelta : None\nenergyAccumTotal : None\nenergyCurLevel : None\nerrorState : \nfolderId : 1630687330\nglobalProps : MetaProps : (dict)\n com.perceptiveautomation.indigoplugin.zwave : (dict)\n SupportsBatteryLevel : true (bool)\n SupportsEnergyMeter : false (bool)\n SupportsEnergyMeterReset : false (bool)\n SupportsOnState : false (bool)\n SupportsSensorValue : false (bool)\n address : 8 (integer)\n propsPushTickler : 3 (string)\n tempAlwaysFalse : false (bool)\n userConfigVal250 : true (bool)\n userPollAfterActivity : true (bool)\n userPollInterval : 0 (integer)\n userPollingEnabled : true (bool)\n userWakeInterval : 60 (integer)\n zwAppVersMajor : 1 (integer)\n zwAppVersMinor : 12 (integer)\n zwAssociationsMap : (dict)\n g1 : (list)\n Item : 1 (integer)\n zwAssociationsMapStr : 1:[1] (string)\n zwClassCmdBase : 0 (integer)\n zwClassCmdMap : (dict)\n c112 : 1 (integer)\n c114 : 1 (integer)\n c128 : 1 (integer)\n c132 : 2 (integer)\n c133 : 1 (integer)\n c134 : 1 (integer)\n c32 : 1 (integer)\n zwClassCmdMapStr : 20v1 80v1 84v2 85v1 86v1 70v1 72v1 (string)\n zwClassIds : (list)\n Item : 1 (integer)\n Item : 1 (integer)\n Item : 1 (integer)\n zwClassInstanceCountMap : (dict)\n zwClassInstanceCountMapStr : - none - (string)\n zwClassName : Portable Remote Controller (string)\n zwConfigVals : (dict)\n p250 : 1 (integer)\n zwConfigValsStr : 250:1 (string)\n zwDevSubIndex : 0 (integer)\n zwEndpointClassMap : (dict)\n zwEndpointClassMapStr : - none - (string)\n zwEndpointDevTypeMap : (dict)\n zwEndpointDevTypeMapStr : - none - (string)\n zwFeatureListStr : battery, beaming, waking (string)\n zwLibType : 2 (integer)\n zwManufactureId : 134 (integer)\n zwManufactureName : Aeon Labs (string)\n zwMeterSubTypeFlags : 0 (integer)\n zwMeterSupportsReset : false (bool)\n zwMeterType : 0 (integer)\n zwModelDefnVers : 3 (integer)\n zwModelId : 65558 (integer)\n zwModelName : Key Fob (DSA22) (string)\n zwNodeNeighbors : (list)\n zwNodeNeighborsStr : - none - (string)\n zwProtoVersMajor : 2 (integer)\n zwProtoVersMinor : 78 (integer)\n zwShowMainUI : true (bool)\n zwShowPollingUI : false (bool)\n zwShowWakeIntervalUI : true (bool)\n zwWakeInterval : 60 (integer)\nid : 1223893079\nlastChanged : 2013-09-03 13:39:01\nmodel : Key Fob (DSA22)\nname : Key Fob\npluginId : com.perceptiveautomation.indigoplugin.zwave\npluginProps : emptyDict : (dict)\nprotocol : ZWave\nremoteDisplay : True\nstates : States : (dict)\n batteryLevel : 98 (integer)\n batteryLevel.ui : 98% (string)\nsubModel : \nsupportsAllLightsOnOff : False\nsupportsAllOff : False\nsupportsStatusRequest : False\nversion : 0'
Posted:
Fri Nov 06, 2015 6:27 am
by McJohn
Hi Karl,
I'm playing with the other features of Indigo util.
Nice Print lists!
Is it possible for you to make an overview of all the Triggers/Schedules/Groups, which are "connected" to each (Z-Wave) Device?
Kind regards,
John
Posted:
Mon Nov 09, 2015 12:03 pm
by kw123
new Version 1.3.1
http://forums.indigodomo.com/viewtopic.php?f=164&t=14825added:print information about all triggers
some menu typos etc.
improved:database recovery: due to an unfortunate accident the recovery process could be improved. It now checks for more errors in the DB.
Posted:
Thu Nov 12, 2015 5:55 am
by McJohn
Thanks for the update Karl, nice!
Question about the SQL backup feature;
- receive an email when the SQL file is corrupt?
- an option to overwrite former backup?
Kind regards,
John
Posted:
Thu Nov 12, 2015 11:22 am
by kw123
John,
currently the backup is done on request = you should have a schedule e.g. at 1:07 am to start
then it renames the last backup to -2 and the new one is -1
I hope that is enough flexibility.
Thought about adding the email feature.
I would propose to add a trigger event and then you add a trigger that triggers on that event and you decide about what to do, send an email, sound alarm ...
Does that make sense?
Posted:
Fri Nov 13, 2015 8:16 am
by McJohn
Thanks for the explanation.
OK, so, max 2 backups , that's perfect!
The Trigger idea works I think.
Or is this possible with a Trigger, SQL Logger event, Error in Event Log , what kind of error should I specify?
John
Posted:
Fri Nov 13, 2015 8:19 am
by kw123
Will check.
Posted:
Mon Nov 16, 2015 4:27 pm
by kw123
new version posted 1.4.1:
http://forums.indigodomo.com/viewtopic.php?f=184&t=14825added:- you now can setup a trigger on an event of "backup failure" due to a corrupt DB or other other circumstances
- you can select the number of back-ups to keep(1-5) - (they are called indigo_histoyr-1.sqlite .. -5.sqlite in the indigo.logs folder
improved:data recovery in case of a bad database, added some more recovery functions (i.e. bad time sequence)
As time machine does not do a reliable backup of your live sqliteDB ( only every x days or so it actually works) this tools gives you the option to create a back up every hour / every day through a schedule you setup.
THEN Time Machine will backup that backup file reliably -- not the live db though.
In case of a crash you can then switch back to the last good backup or use the fix option in the utility.
Posted:
Thu Nov 26, 2015 8:33 am
by McJohn
Karl, I have failed to find a Time Machine backup check in your Util plugin
(something like; if the backup goes wrong, an email will be send or if the backup was OK, an email wil be send)
Posted:
Thu Nov 26, 2015 10:54 am
by kw123
John,
controlling time machine would be a VERY difficult task.
The storage used by time machine is very complex, and it tries every 10 minutes,
Even if i could do that ( 1 year project) creating emails on success or failure of time machine might flood your inbox.
