indigo utilities discussion
Thu May 12, 2016 7:20 am
roquej offline
Re: indigo utilities discussion
Karl,
Sorry, but luck. Your suggestion worked for variables but not for devices. It doesn't matter what device is selected or how many times you select it, not states show.
Any other suggestions?
JP
Thu May 12, 2016 8:26 am
don't know what to do.. mine works fine. could I look at your system to see whats wrong?
Thu May 12, 2016 8:34 am
the message field (bottom) should state: "select states for device selected",
also could you switch on debug.
as soon as you select a device you should see something like this:
 utilities                       UiValuesDict : (dict)
     devOrVar : dev (string)
     device : 1312758245 (integer)
     execute :  (string)
     header : no (string)
     infoLabel1 :  (string)
     msg : select states for device selected (string)
     numberOfRecords : 50 (string)
     printFile :  (string)
     separator :  (string)
     state0 :  (string)
     state0Condition : any (string)
     state0Value : up (string)
     state1 :  (string)
     state2 :  (string)
     state3 :  (string)
     state4 :  (string)
     state5 :  (string)
     state6 :  (string)
     state7 :  (string)
     state8 :  (string)
     variable : 1177413189 (integer)
.. just need more info
Thu May 12, 2016 1:14 pm
roquej offline
Karl,
I deleted and reloaded the plugin. Everything is fairly straight forward. However, no states show, for any device. The error in the log is:
utilities Error Error in plugin execution UiAction:
TypeError: pickDeviceCALLBACK() takes at most 3 arguments (4 given)
However, I selected --- do not use --- for all the options. Also, as you can see, the ✓ is where the list of states should show. Nothing appears.
JP
Screen Shot 2016-05-12 at 3.08.42 PM.png (101.23 KiB) Viewed 6163 times
Thu May 12, 2016 1:29 pm
ok there is a bug
.. don't know why.. which version are you using?
latest is 1.7.3
this is the code where it complains. but it works for selecting variables (the 2. def)...
####-----------------   pickDeviceCALLBACK          ---------
    def pickDeviceCALLBACK(self,valuesDict="",typeId=""):    <======= this throws an error.. have no clue why, this is directly out of the book.  ANY INPUT FROM OTHER DEVELOPERS??
####-----------------   pickVariableCALLBACK          ---------
    def pickVariableCALLBACK(self,valuesDict="",typeId=""):  <==== this one  works..
Thu May 12, 2016 7:23 pm
roquej offline
Karl,
Using plugin version 1.7.3 with Indigo 6.1.9
JP
Thu May 12, 2016 8:03 pm
could we do an online session? I would need to look at the things when they happen.
Thu May 12, 2016 8:09 pm
roquej offline
Sure, but will need to be tomorrow. Will send you a message to coordinate.
Thu May 12, 2016 8:10 pm
ok
Mon Jun 20, 2016 3:22 pm
v 1.7.4 posted
fixed:
SQL report had a typo (one lower case letter instead of upper case theSplit instead of thesplit ).
Sometimes this bombed : --printSQL error in Line '936' ; error='global name 'thesplit' is not defined'--
Thu Jun 23, 2016 9:22 am
v 1.8.1 posted
added: FOR SQL reporting:
increased the number of state from 4 --> 6 that can be reported (or all)
added selection =; != for state#1. Now you can have 2 if/where conditions e.g. "status" =up and temp="0"
Tue Jun 28, 2016 11:25 am
posted v 1.9.4
ADDED:delete duplicate records in sql data base
This option will go through your indigo SQL database and remove records with the same time stamp- keep only last one. There are several modes:
== test- will create the SQL statements in a file in the indigo utilities directory,
== execute - will execute these sql statements and and print progress in logfile
== execute quiet - will execute the SQL statement , but will not show progress in the log file
+++ you can do this through the menu or through an action (execute and execute quite)
+++ this can take a long time depending on the size of your database.
+++ if you use SQLITE, please stop sqllogger before executing. when finished reenable sqllogger. POSTGRES seems to be better for multi user / access environments.
+++ program will check for errors and stop if any DB-LOCKed conditions occur.
+++ mac records to be deleted parameter can be set in config. depending on your DB, ram etc you can limit the number of records to be deleted in one pass.
Running this on my database removed 50% of the records. This comes from devices that have multiple states that are updated. Indigo creates an update for ALL states everytime it updates
-- each dev.updateStateOnServer() creates a complete update of ALL states in the database of that device.
Example:if you have 5 states that get updated (temp, pressure, update time ...) there will be 5 entries in the SQL database. Only the last one is needed. This is what this option does- deletes all but the last update.
For SQLite you need to run "vacuum" to reduce / reclaim the space.
POSTGRES does one step: it reclaims the empty spaces and reuses it, but does not reduce the database size.. Thats my understanding.
There is no advantage of running this against variables, as they have only one state.
Karl.
Thu Jun 30, 2016 10:41 am
posted v 1.9.5
added: support for LARGE databases and many records to be removed (it works with a 50GByte SQLITE db).
When issuing an SQL statement the length of the statement is limited ~ 200kbyte on my mac setup for SQLITE.
It now executes deletes in chunks if the SQL statement gets too long - as many as needed - to remove all duplicate entries. The max SQL command length used can be set in config.
Fri Jul 01, 2016 10:48 am
posted v 1.10.1
added:
- prune option: selectively prune the sql database i.e. keep only records of a specific devices/variables younger than xx days. Indigo only gives the option to set a date for ALL devices or ALL variables.
- create a backup-dump file for a postgres DB. You can put this into a schedule and run it eg at 2 am in the morning. Then your regular backup will pick it up and copy a CONSISTENT version to your backup. Backing up files of a running database will not necessarily result in a consistent version as the field are changed while the backup is running.
Both can be called from the menu, as an action, or in a python script. See examples in the plugin download post.
Sun Jul 24, 2016 11:28 am
gsbrewer offline
Small bug - In the inpPrintdevzWave() function, if any of your ZWave devices has a neighbor list that consists of a single device with a single digit address, there will be no entry displayed for that device.
I worked around that problem by changing line 389 in file plugin.py from:
if len(neighb)< 2: continue
to
if len(neighb)< 1: continue
Please let me know if there is a reason why this change may be bad.
Thank you for the excellent tools!
