Devices leaving a geofence but not moving
Sun Jul 17, 2016 8:45 am
jalves offline
Anybody have difficulty with iFindStuff reporting a device has left the geofence (in my case the home geofence) yet the device is still sitting on the shelf, plugged in, unmoved for the past 12 hours. I get this occasionally and wonder if there is a solution. I'm using the default parameters for the device.
Running Indigo 7.1.1 on a 27" iMac (mid-2017), 8G memory, 1T Fusion Drive, OS X 10.13.3
Jeff
Mon Jul 18, 2016 8:13 am
Chameleon offline
Re: Devices leaving a geofence but not moving
Jeff
It's probably the accuracy of the Apple FindMyPhone application it uses. I get the same issue occasionally when it reports that my mobile is outside and about 50 m down the street.
There are a couple of things you can do to resolve it:
1. Check the reporting. You can plot the historical data for a device over 24 hours and you will be able to see on the Google Map where Apple thinks the device has been. You'll probably find it drifting throughout the day - not by much but enough to go outside your Geofence.
2. After doing (1) or just on spec - increase the Geofence size in the iFindStuff Geofence device from say 50-100m.
That should resolve it. If it doesn't let me know and I'll investigate further.
Regards
Mike
Mon Jul 18, 2016 9:16 am
TOPS offline
Hi Guys,
Sorry to Hijack the post but all I seem to be getting is the dreaded "to many queries for one day" argggh...how can we rectify this problem??
Cheers,
Dave
Mon Jul 18, 2016 7:20 pm
mattggarland offline
I never did much work on this but I thought about a hybrid ping system. Something like
device leaves home geofence
Indigo tries a ping on iPhone ip
If response, ignore and wait for next location update before acting...
A shell script should do it but I'd need to google my way through something
Fri Jul 22, 2016 3:42 am
Chameleon offline
Matt
I think that you could use the link that iFindStuff has with FINGSCAN. The configuration allows you to ping devices in the home geofence for better results. I think that there's a post here that explains what Karl added to make it work... Let me know how you get on...
http://forums.indigodomo.com/viewtopic.php?f=181&t=14943
Regards
Mike
Fri Jul 22, 2016 3:43 am
Chameleon offline
TOPS wrote:
Hi Guys,
Cheers,
Dave
Dave
I've sent you an mail for some more information...
Mike
