iFindStuff failing after update
Posted: Tue Apr 19, 2016 11:14 pm
Hello,
I had been using a old (probably beta) version of iFindStuff and just updated tonight (1.02.03). After I updated, it seemed to be unable to locate my device so I deleted the device and account to basically start over.
At this point I have readded my Apple Account Device. After doing this I see "Login Successful" message. However, when I go to create my iDevice, I'm running into issues.
When creating an iDevice, I am able to select my Apple Account and confirm. This works and I get the "Account Confirmed". However, when I drop down the "Devices on Account" dropdown, it is empty. I am able to click "confirm device" and save, but it results in an error:
Following this I get the following log sequence repeatedly:
I'm assuming this is happening because I haven't actually the selected the device (because it doesn't show up). I also noticed when I go back in to edit the iDevice, the account still says account confirmed but the entry in the dropdown is blank (no text, just a ).
Could there be some saved data from a previous version that is preventing me from recreating the device? Any other thoughts on why I'd be unable to retrieve a list of devices? I have confirmed I have "Find My Phone" on my phone, that it is logged in, enabled in settings and connected to the account I have logged into.
Thanks for any help you can provide.
- Code: Select all
iFindStuff Error Error in plugin execution UiAction:
File "plugin.py", line 4856, in selectedDevice
<type 'exceptions.KeyError'>: ('530771342',)
- Code: Select all
iFindStuff Setting up the API...
iFindStuff Standard API fields set up correctly...
iFindStuff Setting up the Custom API...
iFindStuff Custom API fields set up correctly...
iFindStuff Updating: new device 1 this time
iFindStuff Refreshing Apple Device...new device 1 on account Andy's Apple Account
iFindStuff NCE
iFindStuff Devicenew device 1
iFindStuff Critical Error Failed login...NCE
iFindStuff Failed to update Apple Device:new device 1 reason unknown
