Santa Tracker Beta Feedback Post
Mon Dec 07, 2015 7:47 am
Chameleon offline
Please post in this forum to provide feedback, ideas, changes and praise (if applicable) for the beta system
Mike
Sun Dec 13, 2015 3:35 am
evansgo offline
Re: Santa Tracker Beta Feedback Post
I'm getting a dropbox error when trying to download the plugin, has something not been updated?
Gareth
Sun Dec 13, 2015 6:42 am
Chameleon offline
Gareth
Gareth
You were right - not sure how that happened :oops:
I've updated the link in the post but you can download it from here:
https://www.dropbox.com/s/enne6kfrcyfcy2x/SantaTracker.zip?dl=1
I tested this one and it works fine.
Regards
Mike
Sun Dec 13, 2015 7:08 am
MarcoGT offline
Hello :)
with the latest version (0.2.01) I am having this error:
  File "plugin.py", line 1128, in runConcurrentThread
  File "plugin.py", line 850, in newDisplayStateId
<type 'exceptions.ValueError'>: empty string for float()
  Santa Tracker Error             plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sun Dec 13, 2015 9:29 am
Chameleon offline
Chameleon wrote:
Gareth
Gareth
https://www.dropbox.com/s/67zrw5fm6ksz4a1/SantaTracker.zip?dl=1
Regards
Mike
And now I've updated the Control page link...
https://www.dropbox.com/s/znarhlzmj8o2ce4/SantaTrackerCP.textClipping?dl=1
Sun Dec 13, 2015 9:39 am
Chameleon offline
MarcoGT wrote:
Hello :)
Hmmm - interesting error.
I've trapped out the error in this hotfix version but it shouldn't be happening. It implies that there's something not quite right in the Santa Tracker configuration... can you check that?
https://www.dropbox.com/s/enne6kfrcyfcy2x/SantaTracker.zip?dl=0
You can also look, and send me a copy, of the error log file which you'll find in the folder - /Library/Perceptive Automation/Indigo 6/Logs/ with the name SantaTrackerErrors.log. This file should pinpoint exactly what isn't working with the preferences. Most common error is having the name of the Maps directory incorrectly spelt or entered or blank.
Regards
Mike
Sun Dec 13, 2015 9:42 am
Chameleon offline
MarcoGT wrote:
Hello :)
Also you might want to consider deleting the sleigh device and starting again... but try checking the log and configuration details first.
Regards
Mike
Fri Dec 25, 2015 12:26 am
evansgo offline
Worked a treat - Happy Christmas all :)
