Indigo and SecuritySpy via cynical ?
Forum rules
Fri May 17, 2013 7:04 am
hugues0509 offline
Hello, I want to start by apologizing for my English who is not my native language.
I use Indigo 6 with SecuritySpy 3,0,4 and I try to use the cynical plugin 1,4,1 but I can't understand how to configure.
The plugin is installed and able.
I try to start a connection bay adding a server - New device - Cynical - server - host : localhost - port:8000 - username and password OK
When I try the http://localhost:8000 with user and pass in safari, it work fine.
The status of my new device/server stay in "preparing"
When i try to add my camera, the select box don't show my cameras but only unavailable.
is there something i'm doing wrong ?
Thank your for your help.
Hugues
Fri May 17, 2013 9:12 am
DomoPat offline
Re: Indigo and SecuritySpy via cynical ?
Hello,
I am testing Security Spy and the plugin since a few days ago, and it worked immediately for me, and very reliably. I set it up without passwords at the moment to make it simple... PM me in French if you want, it might be easier to find the problem !
A bientôt,
Patrick
Fri May 17, 2013 9:21 am
hugues0509 offline
Thank you ! PM en français ;-)
Wed Jun 19, 2013 7:30 am
ckeyes888 offline
Hugues
Same issue here. Anyone know of any setup docs anywhere?
Carl
Wed Jun 19, 2013 8:05 am
DomoPat offline
Have you tried the page linked to the 'about' menu of the plugin ? following that page I was able to get it to work.
http://www.cynic.org/indigo/plugins/online/securityspy.html
Where exactly are you stuck ?
Thu Jun 20, 2013 11:58 pm
ckeyes888 offline
Found the docs and got it all working. Great plugin!
Carl
