Plugin.py help please
Forum rules
Mon Mar 25, 2013 9:07 am
jd10884 offline
The script below runs fine when run in a Python 2.5 Editor but throws wobbler when run in Indigo 5. The error is;
Script Error Error in plugin execution compileExecuteSource:
File "plugin.py", line 201, in compileExecuteSource
File "plugin.py", line 190, in _compileExecuteSource
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'lstrip'
Can you tell me why Indigo's plugin.py doesn't like the script?
from __future__ import with_statement
from datetime import date
import linecache
import os
fileDate = str(date.today())
theBody = []
baseDir = '/Library/Application Support/Perceptive Automation/Indigo 5/Logs'
tmpFileName = os.path.join(baseDir, 'tmp.txt')
log = os.path.join(baseDir, fileDate + ' Events.txt')
with open(tmpFileName) as tmpFile:
    prenumLines = sum(1 for line in tmpFile)
with open(tmpFileName, 'w') as tmpFile:
    with open(log, 'r') as logFile:
        for line in logFile:
            if 'Error' in line:
                tmpFile.write(line )
    postnumLines = sum(1 for line in tmpFile)
lineNum  = prenumLines
    while lineNum < postnumLines:
        theBody.append(linecache.getline(tmpFileName, lineNum + 1) )
        lineNum = lineNum + 1
#theBody is the body of  an email to be sent next
theBody =  "".join(theBody)
Mon Mar 25, 2013 12:04 pm
Re: Plugin.py help please
Indigo has to wrap the script code inside a function before it can execute it, which is causing it to fail on this line:
I just modified Indigo (for next beta) to automatically include the with statement __future__ import for all script code it executes. So once that is released your script will run after you delete the first line.
In the mean time the workaround would be to both remove the first line and remove the usage of the with statements.
Mon Mar 25, 2013 3:04 pm
jd10884 offline
Matt,
Will this addition be available in Indigo 5 with the next update?
Jeff
Mon Mar 25, 2013 3:22 pm
Hi Jeff,
Under Indigo 5 you'll need to use the workaround (no with statements).
Mon Mar 25, 2013 4:48 pm
jd10884 offline
Matt,
Hmmmmmmmm Thats not what I was really hoping to hear, I was hoping to hear that Indigo 5 was going to be supported and there was not going to be any reason to upgrade to 6. Is there any reason why 5 could not be integrated into the update so the Python functionality that was supposed to be supported in Indigo 5 could be supported rather than having to create workarounds?
Jeff
Mon Mar 25, 2013 5:30 pm
Yes - the code change was non-trivial and given that there's a simple workaround we don't believe that back-porting the change is critical (particularly given that this is the first time we've seen this problem and Indigo 5 has been on the market almost 2 years).
