It does not create the zones however.
It just keeps banging out row after row of...
- Code: Select all
ELK M1G Control Error EOFError: telnet connection closed
Any ideas here?
ELK M1G Control Debug Alarm code saving enabled
ELK M1G Control Debug True, True, True
ELK M1G Control Connecting to Alarm Panel
ELK M1G Control Disconnecting from Alarm Panel
jcrides wrote:I'll add some more debugging tonight to see if I can figure out what's going on. In the meantime you can try powercycling your M1-XEP ethernet module. I've had a few occasions in the past where I needed to do that.
~JC
jserv:~ jcarey$ telnet 10.10.10.131 2101
Trying 10.10.10.131...
Connected to 10.10.10.131.
Escape character is '^]'.
16XK02061942504121100070
16XK3206194250412110006D
Enabling plugin "ELK M1G Control 1.0.0"
Starting plugin "ELK M1G Control 1.0.0" (pid 812)
Plugin "ELK M1G Control" connected
Plugin "ELK M1G Control 1.0.0" started
Apr 25, 2012 8:58:40 PM
ELK M1G Control Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 50, in runConcurrentThread
File "plugin.py", line 159, in dispatchMsg
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Elk Plugin.indigoPlugin/Contents/Server Plugin/elkextra.py", line 120, in setZoneStatus
<type 'exceptions.KeyError'>: 'key name Zone 17 not found in database'
ELK M1G Control Error plugin runConcurrentThread function returned or failed; will attempt again in 10 seconds
Apr 25, 2012 9:23:19 PM
Swancoat wrote:Any progress on freeing up the 'name' field to be changed?
