- Code: Select all
<Action id="sendir" deviceFilter="indigo.device,self.iremitter">
- Code: Select all
<Event id="ircomplete" deviceFilter="indigo.device,self.iremitter">
Cheers
-- perry
Because we believe that most device events will fall under the "Device State Changed" trigger, which already has built-in device selection.
Although, if you're attempting to model the state of an IR emitter, it might very well be done better through states: idle, sending, receiving, and error? Unless there's some way to pair up the send message with some kind of confirmation, then that's really the only thing that you can realistically model, right?
