Plugin Shutdown error
Forum rules
Fri Aug 09, 2013 7:03 am
jd10884 offline
I have written a plugin that works fine except it will not reload or disable without this error:
Error process (pid 225) failed to quit after polite request -- forcing it to quit now
I have stripped the plugin.py code down to this and still I get the above error. Obviously there is something fundamentally wrong in my basic code. With this plugin.py
in my plugin, it writes to the debug log every 60 seconds just fine but I get the above error when I try to disable or reload the plugin.
Can you please see what is causing this error?
plugin.py as follows:
#! /usr/bin/env python
# -*- coding: utf-8 -*-
   def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
      indigo.PluginBase.__init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs)
      self.debug = pluginPrefs.get("showDebugInfo", True)
   def __del__(self):
      pInterval = 60
      self.debugLog("Starting concurrent thread")
      self.debugLog("L98 set to update every %s %s" %(pInterval, 'seconds'))
         while True:
            self.sleep(int(pInterval))
            self.update()
      except self.StopThread:
         pass
      self.stopThread = True
   def update(self):
      self.debugLog('L272 testing')
Thanks in advance and I look forward to your comments.
Fri Aug 09, 2013 8:01 am
Re: Plugin Shutdown error
Remove these two lines:
And I believe it will work correctly. The base plugin class (which your plugin inherits from) defines that method already. It does what your method does (set self.stopThread to True) and it also writes to a stopThreadPipe that is used internally by the base implementation to abort the sleep() call. Since your implementation is missing the latter (and doesn't call the base implementation), the sleep() method is not properly aborting when the plugin is told to shutdown.
Fri Aug 09, 2013 9:52 am
jd10884 offline
Thanks Matt for the Rapid response :D
One more Question?
How would you stop the thread in an Exception like so?
except Exception, e:
   self.debugLog("****** L357 error %s %s "  %(device.name, e))
   if e == '[Errno 6] Device not configured':
      self.StopThread
Thanks in advance
Jeff
Fri Aug 09, 2013 11:28 am
If you call:
self.stopConcurrentThread()
Then that will set the flags that cause sleep() to throw an exception. Note it doesn't immediately throw an exception in the thread that makes the call since you would normally call this from a different thread than the runConcurrentThread() you are trying to abort.
