Cookie-Data not synchronous with sen.se
Tue Jul 12, 2016 2:49 pm
Nine offline
Hi Karl
I do have one cookie which shows "present" even sen.se knows, that the cookie is absent (the app says cookie is absent).
Reset ALL in indigo plugin does not help. Delete the cookie does not help... Is it possible, that sen.se delivers wrong data in the api? how can I check that?
Indigo debug:
 updateIndigo.... Presence Caro Presence {u'lastStatusChange': '2016-07-12 13:51:03', u'used': True, u'uid': u'X4MKFXYtKpbBqnGENFBm6ShIGeW0d3dL', u'lastEventSeconds': 1468324263.0, u'url': u'https://apis.sen.se/v2/feeds/X4MKFXYtKpbBqnGENFBm6ShIGeW0d3dL/events/', u'type': u'presence', u'lastTimeTest': 1468355737.7082951, u'queryWait': {'Absent': u'4', 'Present': 60}, u'ignore': False, u'addWait': 60, u'data': {u'body': u'Present', u'code': 200}, u'payload': '2', u'subscription': u'RxsTFMVIrYGAkR90NP0LFyNPVuItFjnI'}
  updateIndigo.... Presence Caro Presence updating LastEventDate 2016-07-12 13:51:03
13:51:03 was indeed the last time, this cookie was present.
Nine
Tue Jul 12, 2016 9:17 pm
Re: Cookie-Data not synchronous with sen.se
sorry just saw this.
do you use pull or push?
if push switch to pull just for 5 minutes (might need to restart) then back to push.
if you use pull do the other way around.
If you use push you can find a log file in ~documents/mother/webserver.log
you will see the push messages in clear text .
check out the address number an see if any message with number appear - if you open the log file console log viewer will open it . you can set a filter to right for that number .
I guess that number is X4MFK...
and if it states: LastEventDate 2016-07-12 13:51:03 then that is the date of the last message received .
must be a bug I guess
Thu Jul 14, 2016 3:14 pm
Nine offline
well... I switched from pull to push and back... changed API-key... and the next morning it went fine :-)
Will consult the specific log file next time it happens.
Simon
