The iPhone kinda works but not reliable. It switches off its ble signal.
Will walk you through when you get it.
#if defined(FREEdevcie)
#define maxAnalogValue 10000
#define serialBaudRate 57600
#endif
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
Sketch uses 24,668 bytes (76%) of program storage space. Maximum is 32,256 bytes.
Global variables use 2,510 bytes (122%) of dynamic memory, leaving -462 bytes for local variables. Maximum is 2,048 bytes.
processing.app.debug.RunnerException: Not enough memory; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing your footprint.
at cc.arduino.Compiler.size(Compiler.java:319)
at cc.arduino.Compiler.build(Compiler.java:156)
at processing.app.Sketch.build(Sketch.java:1111)
at processing.app.Sketch.exportApplet(Sketch.java:1146)
at processing.app.Sketch.exportApplet(Sketch.java:1132)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409)
at java.lang.Thread.run(Thread.java:745)
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Sketch uses 22,784 bytes (70%) of program storage space. Maximum is 32,256 bytes.
Global variables use 2,106 bytes (102%) of dynamic memory, leaving -58 bytes for local variables. Maximum is 2,048 bytes.
kw123 wrote:In the sketch you read d2, write the temp to eg s0. In the plugin you read s0
No d2 in the plugin
kw123 wrote:in device edit you define the mode of the pin (enable/disable S0 variable = input)
the output is for sending data to the arduino
kw123 wrote:read from string
