kw123 wrote:looks like a missing declaration (wifi vs ethernet etc) -- I would need to see the whole code to find it.
Karl, here is the sketch.
It's the one you've modified as we had the remote session (for UNO with Ethernet shield, you removed some parts of the sketch - because it used too much memory, remember?)
I've replaced the WiFi part where my SSID and password are with dummies (MYSSID and MYPASSWORD)
- Code: Select all
// UNO/MEGA/ESP w ethernet/WIFI sketch by karl wachs July 26 2016 v 1.10.4
// v1.10.4
// changed types for time variables: long --> unsigned long
// v1.10.3
// changed the onewire included setup etc,
// fixed and tested reboot option watchdog timer function
// v1.10.2
// v1.10.1
// added reboot option watchdog timer function
// v1.9.2.
// fixed debug --> DEBUG and removed debug print statement
// v1.9.1.
// added support MKR1000
// fixed some smaller things
// v1.8.3
// replaced min() max() with if(){}, some compiler versions did not like it
// v1.8.2
// fixed removed additional & in analog write For S variables
// added: v 1.8.1:
// 1.added DS18B20 temp sensors example, will support several senors on one pin.
// see http://milesburton.com/Dallas_Temperature_Control_Library#The_Library
// 2. added rise and fall time for ramp up/down/continuous, requires plugin V >= 2.6.1
// 3. added FREEdevice: this device has no limts from the plugin point of view. All pins (50xD,16xA,20xS) are available. YOU will need to manage in code. also IP# mac# wifi etc.
// command to be send: curl 192.168.1.155"?--command-string--?"
// command string has the form command:pin=value& eg: command:pin=value1,value2&command:pin&command:pin=value1&
// commands implemented:
// rd wr aw pg mU mD pD pU rU rD pC
// rd:A1&rd:D3& ==> will read analog pins 1 and digital pin 3
// wr:D1=0&wr:D4=0& ==> set digital pins 1 to 0 and digital pin4 to 1
// aw:D3=55& ==> analogWrite(3,55) will set digital pin3 to 55
// pg:D5=O&pg:D4=I&pg:D7=U&
// ==> will reprogram digital pin 5 to Output and digital pin 4 to Input and digital pin 7 to input_pullUp with pull up resistor
// mU:D5=100& ==> will program digital pin 5 to do: 500msec up then down (digital write set to 0/1)
// mD:D2=5555& ==> will program digital pin 2 to do: 5555 msec down then up (digital write set to 0/1)
// pU:D5=100,5555& ==> will program digital pin 5 to do: 100msec up ; then 5555 msec down and repeat (digital write set to 0/1)
// pD:D5=2000,3000& ==> will program digital pin 5 to do: 3000msec down ; then 2000 msec up and repeat (digital write set to 0/1)
// rC:D5=2000,3000,10,255&=> will program digital pin 5 to do: set v=10; ramp up in 2 secs to 255; ramp down in 3 seconds to v=10 and repeat (analog write to set to 10/255)
// rU:D5=2000,10,255& ==> will program digital pin 5 to do: set v=10; ramp up 2 seconds to v=255 (analog write set to 10/255)
// rD:D5=2000,10,255& ==> will program digital pin 5 to do: set v=255; ramp down 2 seconds to v=10 (analog write set to 10/255)
// rd:S1&rd:S2& ==> will read contents of variable S1 and S2
// aw:S1=abc -=; def& ==> will write "abc -=; def" to varibale S1
// pins can be D0..Dxx A0.. Axx, S0..S4
// Dx are digital i/o pins they can be read ==> 0/1; digital write 0/1 or analogWrite 0..255
// Ax are anlog input pins delivery values 0..1023
// Sx are String variables can be written to and read from eg "231234 9p8137598734 kajshdlkjh=-:" but NOT a "&" that will end the string
// here a more complex example:
// command curl http://192.168.1.155/"?rd:a1&wr:d5=1&pg:d7=O&wr:d7=1&?" note the "
// you can combine multiple commands, each command must end with a &
// in python it is
// ret= urllib2.urlopen("http://ipnumber/?rd:a1&wr:d5=1&pg:d7=O&wr:d7=1&?").read()
// would send ret =">>rd:A1=311&wr:D5=1&pg:D7=O&wr:D7=0&wr:D7=1&"
// excution times: for mega reading 70 pins ... use this for time out setting, default is 5 seconds
// debug on ethernet: 0.4 secs
// debug off 0.2 secs
// debug on wifi : 0.9 secs
// debug off : 0.6 secs
// UNO reading 15 pins
// debug off ethernet: 0.05 secs
// debug on : 0.2 secs
// debug off wifi : 0.3
// debug on : 0.5 secs
// this needs to be set : 1. #define DEBUG only for testing
// 2. #define ETHERNET / WIFI only for uno or mega
// 3. #define UNO MEGA ESP1 ESP16 --- in the tools menue in ARDUINO IDE you have to select the proper board also
// for ethernet you need to set the IP number and the MAC number, WIFI gets it those from the router, but you have to set the SID and wifi password, You have to figure out the IP number either in debug mode or on the router
// byte mac[] = { 0x55, 0x55, 0x55, 0x55, 0x55, 0x53 }; // pick one thats not on your network
// IPAddress ip(192,168,1, 183);
// some of the pins are disabled / enabled automatically: pin D7 D10,11,12,13 50,..are used to communicate to the ethernet/wifi boards
// pins d0 d1 are used for usb communication, so in debug mode they are diabled, debug off they can used as all other pins
/// you need to adapt/change parameters in lines indicated with : //<-----------------
// enable serial monitor for debugging, if in production do not send data to serial port
//#define DEBUG //<-----------------
// enable watchdogtimer
#define WATCHDOGenabled //<----------------- put // infront if you want to switch off
///////////////////////////// for watchdog timer, to enable: set maxWatchDogTimer >0 in millisecs eg 1 minute =60000
#if defined(WATCHDOGenabled)
long watchDogTimer = 0; // initialize
long maxWatchDogTimer = 125000; // reboot if 2 minutes 5 secs w/o http request, you could make it higher
int watchDogTimerPin = 7; // set to pin that is connected to reset pin MAKE sure your do not use that pin in the plugin, for D0 use 0, here D7
// during program load the cable must not be connected to reset pin
#endif
// select which board you use --------------------------------
/// --------> #include <xx> does not work in
// #if defined(zz)
// #endif
// it is always included, have to do it manually
//////////////////////////////////////////////// ESP
//#define ESP1 //<-----------------
#define ESP16 //<-----------------
// for both:
#include <ESP8266WiFi.h> //<----------------- for ESP1 and ESP16
/////////////////////////////////////////////// FREEdevice
//#define FREEdevice // <-- freely defined device. no restrictions from plugin YOU must define everything yourself
// if etehrnet, wifi ip numebr etc..
// comes with 50 defined D pins; 16 A pins; 20 S pins, like MEGA
//#include <SPI.h> // needed for WIFI and ETHERNET, not for ESP
// for uno and mega:
//#define WIFI //<----------------- EITHER WIFI
//#include <WiFi.h> //<-----------------
//#define ETHERNET //<----------------- or ETHERNET
//#include <Ethernet.h> //<-----------------
/////////////////////////////////////////////// mkr1000
//#define mkr1000 //
// comes with 8 defined D pins; 7 A pins; 20 S pins,
//#define WIFI101
//#include <WiFi101.h>
//////////////////////////////////////////////// MEGA and UNO
//#define MEGA //<----------either
#define UNO //<--------or
//////////// here YOU MUST ENTER YOUR NETWORK PARAMETERS !!
//////////////////////////////// configure network here
//#if defined(WIFI) || defined(ESP1) || defined(ESP16) || defined(mkr1000)
// char ssid[] = "MYSSID"; //<----------------- your network SSID (name)
// char pass[] = "MYPASSWORD"; //<----------------- your network password
// int keyIndex = 0; // your network key Index number (needed only for WEP)
// WiFiServer server(80);
//#endif
//#if defined(ETHERNET) // this is for ethernet
// byte mac[] = { 0xde, 0xad, 0xbe, 0xef, 0xfe, 0xee }; //<----------------- pick one thats not on your network
// IPAddress ip(192,168,100,20); //<----------------- pick one that works for you
// EthernetServer server(80);
//#endif
//////////// here YOU MUST ENTER YOUR NETWORK PARAMETERS END !!
#if defined(WIFI) || defined(mkr1000)
int status = WL_IDLE_STATUS;
#endif
// for DHT sensors///////////////////////////////////////
//#define DHTSensor
#if defined(DHTSensor)
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE);
#endif
// for ONEWIRE ///////////////////////////////////////
#define ONEWIRE
#if defined(ONEWIRE)
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin x on the Arduino
#define ONE_WIRE_PIN 4
OneWire oneWire(ONE_WIRE_PIN);
DallasTemperature sensors(&oneWire);
#endif
#if defined(UNO) || defined(MEGA)
#define maxAnalogValue 255
#define serialBaudRate 9600 /// <<<<<--------
#endif
#if defined(mkr1000)
#define maxAnalogValue 1023
#define serialBaudRate 57600
#endif
#if defined(FREEdevcie)
#define maxAnalogValue 10000
#endif
#if defined(WIFI)
#define WiFiDelay 2000
#endif
#define WiFiDelay 1000
#endif
#if defined(ESP1) || defined(ESP16)
#define serialBaudRate 115200
#endif
char cmd[20];
char command[3];
int pin = 0 ;
int value1 = -1;
int value2 = -1;
int value3 = -1;
int value4 = -1;
String valueS="";
int cmdL = 0;
char c=' ';
char mode = 'I';
int kk=1;
int eIndex=-1;
int kIndex=-1; // : index
int cIndex1=-1; // comma index 1,2,3
int cIndex2=-1;
int cIndex3=-1;
int cc =0; // used for counter in doMyStuff
int dd =0; // used for counter in doMyStuff
String configured ="no";
// free values to read from and write to
String S[20]={"","","","","","","","","","","","","","","","","","","",""};
String out ; // this can get: 68* 12 = 800+ for mega and 14*12 = 170 for uno
#if defined(FREEdevice)
int activeDPins =50;
int activeAPins =16;
char dConfig[50] ;
char pulseCMD[50] ;
unsigned long pulseEND[50] ;
unsigned long pulseV1[50] ;
unsigned long pulseV2[50] ;
unsigned long pulseMAX[50] ;
unsigned long pulseMIN[50] ;
bool doNotUsePin[50];
#endif
int activeDPins =21;
int activeAPins =7;
char dConfig[21] ;
char pulseCMD[21] ;
unsigned long pulseEND[21] ;
unsigned long pulseV1[21] ;
unsigned long pulseV2[21] ;
unsigned long pulseMAX[21] ;
unsigned long pulseMIN[21] ;
bool doNotUsePin[21];
#endif
#if defined(MEGA)
char dConfig[50] ;
char pulseCMD[50] ;
#endif
#if defined(UNO)
int activeDPins =10;
int activeAPins =6;
char dConfig[10] ;
char pulseCMD[10] ;
unsigned long pulseEND[10] ;
unsigned long pulseV1[10] ;
unsigned long pulseV2[10] ;
unsigned long pulseMAX[10] ;
unsigned long pulseMIN[10] ;
bool doNotUsePin[20];
#endif
#if defined(ESP16)
int activeAPins =1;
char dConfig[17] ;
char pulseCMD[17] ;
unsigned long pulseEND[17] ;
unsigned long pulseV1[17] ;
unsigned long pulseV2[17] ;
unsigned long pulseMAX[17] ;
unsigned long pulseMIN[17] ;
#endif
#if defined(ESP1)
int activeDPins =3;
int activeAPins =1;
char dConfig[3] ;
char pulseCMD[3] ;
unsigned long pulseEND[3] ;
unsigned long pulseV1[3] ;
unsigned long pulseV2[3] ;
unsigned long pulseMAX[3] ;
unsigned long pulseMIN[3] ;
bool doNotUsePin[3];
#endif
int activeSPins =20;
//////////////////////////// put your stuff here, is called once per loop, make sure you add a delay at the end if you use an ESP module
void doMyStuff(){ // example for DHT, 2 methods to get data to indigo
if (true){ // switch on off: use true or false
// method 1: just define S1 and S2 as input in indigo plugin , will get current stored value
cc +=1;
if (cc > 5000 ){ // get sensor data every ~10 seconds - there is a delay of 2-3 msec every loop * 5000 ~ 10-15 seconds, this can be changed to faster or slower depending on your needs
cc =0 ;
S[1] = String(dht.readTemperature());
S[2] = String(dht.readHumidity());
S[0] = "";
S[3] = String(dht.readHumidity());
// method 2 only read sensor when asked, store in S1 and S2 and pick up next time ==> do a write S0=DHT, a read S1 and S2 (define S1 and S2 as input) will be executed every xx seconds
//if (S[0]="DHT" ){ // do it only when asked to do so
//S[1] = String(dht.readTemperature());
//S[2] = String(dht.readHumidity());
//S[0] = "";
delay(1);
#endif
#endif
dd +=1;
if (dd > 5000 ){ // do it every xx seconds only
dd=0;
sensors.requestTemperatures();
S[0] = String(sensors.getTempCByIndex(0));
// S[2] = String(sensors.getTempCByIndex(1)); // if you haƒ√ensors attached to pin x
#endif
void watchDog(){
if ( millis() > 125000 ){ // dont to anything in the first 2 minutes
//Serial.print("millisec = "); Serial.print(millis());Serial.print("watchDogTimer = "); Serial.println(watchDogTimer);
//delay(500);
if ( maxWatchDogTimer > 0 and ( millis() - watchDogTimer) > maxWatchDogTimer ){
if (watchDogTimerPin >= 0){
#if defined(DEBUG)
Serial.print("rebooting timer= "); Serial.println(watchDogTimer);
Serial.print("millisec = "); Serial.println(millis());
delay(1000);
#endif
pinMode(watchDogTimerPin, OUTPUT);
digitalWrite(watchDogTimerPin,LOW); // this will reset the board immediately
#endif
///////////////// dont change anything after this, should be the same for each device and program /////////////////////
void setup() {
for (int i =0;i< activeDPins;i++){
dConfig[i] ='0';
pulseCMD[i] ='0';
pulseEND[i] =0;
pulseV1[i] =0;
pulseV2[i] =0;
doNotUsePin[i]=false;
digitalWrite(watchDogTimerPin, HIGH);
#endif
#if defined(DHT)
dht.begin(); // start DHT
#endif
sensors.begin();
#endif
#if defined(DEBUG)
doNotUsePin[0] = true;
doNotUsePin[1] = true;
Serial.begin(serialBaudRate);
Serial.print("server starting");
#endif
#if defined(ETHERNET) || defined(WIFI) // these pins are used for communication to network board
doNotUsePin[7] = true;
doNotUsePin[10] = true;
doNotUsePin[11] = true;
doNotUsePin[12] = true;
doNotUsePin[13] = true;
#endif
#if defined(mkr1000) // these pins are used for communication to network board
//doNotUsePin[9] = true;
//doNotUsePin[11] = true;
//doNotUsePin[12] = true;
//doNotUsePin[13] = true;
//doNotUsePin[14] = true;
//doNotUsePin[15] = true;
doNotUsePin[16] = true;
doNotUsePin[17] = true;
doNotUsePin[20] = true;
doNotUsePin[21] = true;
analogWriteResolution(10);
analogReadResolution(10);
#endif
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
delay(1000);
// Open serial communications and wait for port to open:
#if defined(DEBUG)
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
#endif
#endif // ETHERNET
// start wifi
#if defined(WIFI) || defined (mkr1000)
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
#if defined(DEBUG)
Serial.println("WiFi shield not present");
#endif
while(true);// don't continue:
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
#if defined(DEBUG)
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
#endif
status = WiFi.begin(ssid, pass);
// wait xx seconds for connection:
delay(WiFiDelay);
server.begin();
printWifiStatus();
#endif // WIFI
while (WiFi.status() != WL_CONNECTED) { delay(1000);} // wait 1 seconds for connection:
server.begin();
printWifiStatus();
#endif
void SpecialPredefinedOutputs() { }
void doNextCMD(){
if ( (configured == "no") and (strcmp(command,"pg") !=0 ) ) {
out=">>notConfigured";
#if defined(DEBUG)
Serial.println(">>notConfigured");
#endif
return;
if ( strcmp(command,"st") ==0 and configured =="yes" ) { out=">>Configured"; return; }
if ( strcmp(command,"st") ==0 and configured =="no" ) { out=">>notConfigured"; return; }
if ( cmd[3]=='I' and pin >=activeAPins ) { out+=command;out+=":I";out+=String(pin);out+="=outOfRange&"; return;} // for I2C not implemeted yet
if ( cmd[3]=='A' and pin >=activeAPins ) { out+=command;out+=":A";out+=String(pin);out+="=outOfRange&"; return;} // analog in
if ( cmd[3]=='D' and pin >=activeDPins ) { out+=command;out+=":D";out+=String(pin);out+="=outOfRange&"; return; } // digital
if ( cmd[3]=='S' and pin >=activeSPins ) { out+=command;out+=":S";out+=String(pin);out+="=outOfRange&"; return; } // String
if ( cmd[3]=='D' and doNotUsePin[pin] ) { out+=command;out+=":D";out+=String(pin);out+="=notUseable&"; return; } // digital
configured="yes";
if ( strcmp(command,"cf") ==0 or strcmp(command,"lc")==0 ) {
if ( strcmp(command,"cf") ==0 ) {
#if defined(DEBUG)
Serial.println("command = cf - ");
#endif
for (int i=0;i<activeDPins;i++){out+="cf:D"+String(i)+'='+dConfig[i]+'&';}
return ;
if ( strcmp(command, "i2") ==0 ){ // not implemented yet, dummy function
if (cmd[3]=='I') { //= read i2c devices
return;
if (strcmp(command, "pg")==0 and (cmd[3]=='D' or cmd[3] == 'S' )){
#if defined(DEBUG)
Serial.println("command =pg "+ String(pin) +" to mode=" + mode +", cmd="+ cmd);
#endif
if (cmd[3]=='D'){
if (doNotUsePin[pin] ) { return; }
if (mode =='I'){ pinMode(pin, INPUT); dConfig[pin] ='I';out+=cmd ;}
if (mode =='O'){ pinMode(pin, OUTPUT);dConfig[pin] ='O';out+=cmd ;}
if (mode =='U'){ pinMode(pin, INPUT_PULLUP);dConfig[pin] ='U';out+=cmd ;}
pulseCMD[pin]='0';
pulseEND[pin]=0;
return;
if (cmd[3]=='S'){return;}
if ( strcmp(command, "rd")==0 ){
if ( cmd[3]=='A') { // ANALOG
int val = analogRead(A0); // ESP has only one pin and it must be address as A0
#if defined(DEBUG)
Serial.print("command = A-read - "); Serial.println(val);
#endif
out+="rd:A"+String(pin)+'='+String(val)+'&';
return;
if (cmd[3]=='D'){ // Digital
int val = digitalRead(pin);
#if defined(DEBUG)
Serial.print("command = D-read - ");Serial.println(val);
#endif
out+="rd:D"+String(pin)+'='+String(val)+'&';
pulseCMD[pin]='0';
pulseEND[pin]=0;
return;
if (cmd[3]=='S'){ // this will return the S[pin] string
#if defined(DEBUG)
Serial.print("command = S-read - ");Serial.println(S[pin]);
#endif
out+="rd:S"+String(pin)+'='+S[pin]+'&';
return;
if (strcmp(command, "aw") ==0 and cmd[3]=='S'){
S[pin]= valueS;
Serial.print("command = S-write - ");Serial.print(S[pin]); Serial.println(valueS);
out+=cmd;
return;
if ( cmd[3]=='D'){
if (strcmp(command, "wr")==0 ){
//#if defined(DEBUG)
Serial.print("command = wr -");Serial.println(value1);
//#endif
digitalWrite(pin,value1);
pulseCMD[pin]='0';
out+=cmd;
return;
if (strcmp(command, "aw") ==0 and cmd[3]=='D'){
#if defined(DEBUG)
Serial.print("command = aw, value=" );Serial.println(value1);
#endif
analogWrite(pin,value1);
pulseCMD[pin]='0';
out+=cmd;
return;
if (strcmp(command, "pU")==0 ){ // pulse Down / pulse Up
pulseEND[pin]= millis()+ value1;
pulseV1[pin]=value1;
pulseV2[pin]=value2;
pulseCMD[pin]='P';
//analogWrite(pin,maxAnalogValue);
digitalWrite(pin,1);
#if defined(DEBUG)
Serial.println("command = pU");
#endif
out+=cmd;
return;
if (strcmp(command, "pD")==0 ){ // pulse up / pulse down
pulseEND[pin]= millis()+ value2;
pulseCMD[pin]='p';
//analogWrite(pin,0);
digitalWrite(pin,0);
#if defined(DEBUG)
Serial.println("command = pD");
#endif
out+=cmd;
return;
if (strcmp(command, "mU")==0 ){ // moment UP
pulseCMD[pin]='M';
#if defined(DEBUG)
Serial.println("command = mU");Serial.println(value1);
#endif
out+=cmd;
return;
if (strcmp(command, "mD")==0 ){ // moment Down
pulseCMD[pin]='m';
#if defined(DEBUG)
Serial.println("command = mD");Serial.println(value1);
#endif
out+=cmd;
return;
if (strcmp(command, "rD")==0 ){ // ramp down
pulseEND[pin] = millis()+ value1;
pulseV1[pin] = value1;
if (value3 == -1){ value3 = maxAnalogValue;}
if (value2 <0){value2 =0;};if (value2> maxAnalogValue){ value2 = maxAnalogValue;}; pulseMIN[pin] =value2;
if (value3 <0){value3 =0;};if (value3> maxAnalogValue){ value3 = maxAnalogValue;}; pulseMAX[pin] =value3;
pulseCMD[pin] = 'r';
#if defined(DEBUG)
Serial.print("command = rD v1 " );Serial.print(value1); Serial.print(" MIN "); Serial.print(pulseMIN[pin]); Serial.print(" max "); Serial.println(pulseMAX[pin]);
#endif
analogWrite(pin,pulseMAX[pin]);
out+=cmd;
return;
if (strcmp(command, "rU")==0 ){ // ramp up
pulseCMD[pin] = 'R';
#if defined(DEBUG)
Serial.print("command = rU v1 " );Serial.print(value1); Serial.print(" MIN "); Serial.print(pulseMIN[pin]); Serial.print(" max "); Serial.println(pulseMAX[pin]);
#endif
analogWrite(pin,pulseMIN[pin]);
out+=cmd;
return;
if (strcmp(command, "rC")==0 ){ // rampup AND down continuously
pulseV2[pin] = value2;
if (value4 == -1){ value4 = maxAnalogValue;}
if (value4 <0){value4 =0;};if (value4> maxAnalogValue){ value4 = maxAnalogValue;}; pulseMAX[pin] =value4;
if (value3 <0){value3 =0;};if (value3> maxAnalogValue){ value3 = maxAnalogValue;}; pulseMIN[pin] =value3;
pulseCMD[pin]='C';
#if defined(DEBUG)
Serial.print("command = rC v1 " );Serial.print(pulseV1[pin]); Serial.print(" V2 "); Serial.print(pulseV2[pin]); Serial.print(" MIN "); Serial.print(pulseMIN[pin]); Serial.print(" MAX "); Serial.println(pulseMAX[pin]);
#endif
out+=cmd;
return;
int findCinCMD( char x){
for ( int i=0;i<cmdL;i++){ if (cmd[i] == x){ return i;}}
return -1;
void parseCMD() { // structure: rd:D09& or wr:D55=1234& or mU:d3=1234,4321& or pg:d33=I&
int i; String xx=""; int i1; int i2;
value1 = -1; value2 = -1; value3 = -1; value4 = -1; mode=' ';
command[0]=cmd[0]; command[1]= cmd[1];command[2]='\0';
//Serial.print("\n ki: ");Serial.print(kIndex);Serial.print(" ei: ");Serial.print(eIndex);Serial.print(" c: ");Serial.print(cIndex);
if (eIndex==-1){eIndex=cmdL;}; if (cIndex1==-1){cIndex1=cmdL;} // if no "=" or "," signs
// get pin # is integer 0.. 99 allowed
if (eIndex > 0) { xx=""; for (i = kIndex+2; i< eIndex; i++ ) { xx+=cmd[i]; }; pin=xx.toInt(); }
// now get values
if (eIndex>3){ // any "=" sign?
if (eIndex == cmdL-1){return;} // no values given
// this is for programming to Input or Output
if (cmd[eIndex+1] =='I'){mode = 'I';return;}
if (cmd[eIndex+1] =='O'){mode = 'O';return;}
if (cmd[eIndex+1] =='U'){mode = 'U';return;}
// get integer numbers may by one or 2 , if "," present then it has 2 numbers
if (cmd[3]=='S'){
xx=""; for ( i = eIndex+1; i< cmdL; i++ ){ xx+=cmd[i];}; valueS=xx; // only one value for strings
return;
if ( eIndex < cmdL-1){
if (cIndex1>0 ){ // we have 2,3,4 numbers separated by a ","
xx=""; for ( i = eIndex+1; i< cIndex1; i++ ){ xx+=cmd[i];}; value1=xx.toInt(); // at least 2
i1=cmdL; if (cIndex2 !=-1) { i1= cIndex2; }
xx=""; for ( i = cIndex1+1; i< i1; i++ ){ xx+=cmd[i];}; value2=xx.toInt(); //
if (cIndex2>0){
i2=cmdL; if (cIndex3 !=-1){i2=cIndex3;}
xx=""; for ( i = cIndex2+1; i< i2; i++ ){ xx+=cmd[i];}; value3=xx.toInt();
if (cIndex3>0){
xx=""; for ( i = cIndex3+1; i< cmdL; i++ ){ xx+=cmd[i];}; value4=xx.toInt();
return;
// just one number/ string, no "," present
xx=""; for ( i = eIndex+1; i< cmdL; i++ ){ xx+=cmd[i];}; value1=xx.toInt();
return;
return ;
void loop(){
delay(5);
#endif
watchDog();
#endif
SpecialPredefinedOutputs();
delay(5);
#endif
// special stuff if you want to implement your things
doMyStuff();
// listen for incoming clients
WiFiClient client = server.available();
#endif
EthernetClient client = server.available();
#endif
//Serial.print("a") ;
if (client) {
#if defined(DEBUG)
Serial.println("new client");
#endif
char c4 =' '; char c3=' ' ; char c2=' '; char c1=' '; c=' ';int GETfound =0;int newLine=0;cIndex1=-1;cIndex2=-1;cIndex3=-1;kIndex=-1;eIndex=-1;
while (client.connected()) {
if (client.available()) {
c4=c3;c3=c2;c2=c1;c1=c;
c = client.read();
#if defined(DEBUG)
Serial.write(c);
#endif
watchDogTimer = millis();
#endif
if (GETfound ==0){ if ( c4=='G' and c3=='E' and c2=='T' and c1 ==' ' and c=='/'){ // string "GET /" found, now get data
#if defined(DEBUG)
Serial.println(">>GET /<< Found");
#endif
GETfound =1; c = client.read();// skip "?" in "GET /?"
#if defined(DEBUG)
Serial.write(c);
#endif
cmdL=-1; c = client.read(); out =">>"; // get first character
#if defined(DEBUG)
Serial.write(c);
#endif
} // skip "?" and read first char (avoid another loop)
if (GETfound ==1) {
if (c != '?' and out !=">>notConfigured" ) { // skip if not configured, otherwise read until ending "?"
cmdL+=1;
cmd[cmdL]=c;
if (c==':' and kIndex ==-1) {kIndex=cmdL;} // use the first occurence
if (c=='=' and eIndex ==-1) {eIndex=cmdL;}
if ( c==',' ){
if ( cIndex1 ==-1) {cIndex1=cmdL;}
else{
if (cIndex2 ==-1) {cIndex2=cmdL;}
else {
if (cIndex3 ==-1) {cIndex3=cmdL;}
if (c=='&'){
cmd[cmdL+1]= '\0';
parseCMD();
#if defined(DEBUG)
Serial.print("next cmd: ");Serial.println(command);
#endif
doNextCMD();
cmdL=-1;cIndex1=-1;cIndex2=-1;cIndex3=-1;eIndex=-1;kIndex=-1;}
else{ GETfound=2;
#if defined(DEBUG)
Serial.println(" all data read" );
#endif
if (GETfound ==2) { // here we send the header and the composed data
GETfound=3;
client.println("HTTP/1.1 200 OK");
client.print("Content-Length: "); client.println(out.length());
client.println("Content-Type: text/html");
client.println();
client.print(out);
delay(5);
#if defined(DEBUG)
Serial.println(out.length());
Serial.println(out);
Serial.println("finished processing");
#endif
if (GETfound ==3) { // read the rest of the message until \n\r thats the end of it
if (c=='\n'){newLine+=1;}
else if (c== '\r' && newLine==1){client.stop();break;}
if (c != '\n'){newLine=0;}
yield();// give ESP time to do its background stuff
#endif
#if defined(DEBUG)
Serial.println("client disconnected");
#endif
void printWifiStatus() {
// print the SSID of the network you're attached to:
#if defined(DEBUG)
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
#endif
#endif
