Alpha Feedback Post
Sun Jun 28, 2015 11:36 am
Chameleon offline
Alpha Feedback Post
Please leave any feedback and/or ideas in this post thread.
Mike
Sun Jul 12, 2015 9:04 am
StefID93 offline
Re: Alpha Feedback Post
sorry for my English, I use a translator.
in any case, I find the idea for the beautiful rgbw fibaro, also because I would like to use in the room and then give me this opportunity to be able to better manage is a beautiful thing, my problem is that I can not configure it, and I would like to have advice if possible.
I write the following error
Fibaro Light Manager Error Error in plugin execution UiValidate:
File "plugin.py", line 257, in validateDeviceConfigUi
<type 'exceptions.TypeError'>: 'Dict' object is not callable
Mon Jul 13, 2015 3:02 am
Chameleon offline
Hi Stef
Sorry for the late response. I'm away on holiday this week but I'll look at it when I get back.
In the meantime try this version - you don't need to copy other files around just double click on the file when it's downloaded :D
https://www.dropbox.com/s/dayo30alpcx8lki/Fibaro%20RGB%20Lights.zip?dl=0
I'll look at the programme in more detail when I get back next week
Mike
Mon Jul 13, 2015 3:58 am
StefID93 offline
Blessed are you that you're on vacation! I tried the plugin and it works! Thank you very much! nice job, I thought, however, doing some tests that you can not dimmer the LED, you can implement the function?
Thu Jul 16, 2015 4:44 am
aderrington offline
I'm having some issues with the latest release,
When i try to find the Fibaro RGBW device i see this in the console:
Fibaro Light Manager Error Error in plugin execution GetUiDynamicList:
<type 'exceptions.TypeError'>: Expecting an object of type list; got an object of type tuple instead
Any ideas?
Andrew
Fri Jul 24, 2015 3:43 pm
Furball offline
I have the same issue. Any fix or instruction?
Sun Jul 26, 2015 7:33 am
Chameleon offline
Hi all
Sorry I've been away for the last couple of weeks but I'm back on the case now. I'm looking at the code and I'll provide an update soon.
Regards
Mike
Sun Jul 26, 2015 9:13 am
Chameleon offline
Hi Everyone
I've been able to identify a couple of issues that I've now resolved in the latest version 0.1.15. You can download this from the Latest Software topic along with some notes.
The main issue was that I was 'assuming' - wrongly - that the Composite Device would be named something like Composite Lights when clearly a number of people would change that default name DUH! :oops:
I've now updated the plugin so that it can recognise the core Composite device without any specific help from the user and it works great :D
It goes to show how important user testing is from independent people like yourselves. Give it a go and let's see how we get on.
Regards
Mike
Tue Sep 08, 2015 3:04 pm
Chockymonster offline
Any chance of being able to interface with the white channel?
I use RGBW tape with all of my led dimmers
Tue Sep 08, 2015 3:15 pm
Chameleon offline
Probably... If indigo gives me access to it :)
Tue Sep 08, 2015 3:22 pm
Well it lets me turn the whites on ;)
Tue Oct 06, 2015 12:49 am
yassi offline
Hi guys,
I'm very interested in this plugin, but I'm not quite sure about one thing: can I control with the plugin also the white?
I want to order a RGBW-Strip for my office and want to have also sometimes only white and no other color (to be able to work something or read).
Let's say, when I enter the office, the light should go on on white and for example when I watch a movie or hear music it should switch some color combination (mood lights)?
Can I select white too in the plugin?
Best,
yassi
Thu Oct 08, 2015 11:00 am
At the moment it doesn't support white. I use rgbw in every room but one so can't use the plugin for those modules yet
Thu Oct 08, 2015 12:11 pm
yassi offline
So, you're not using your RGBW Stripes with Z-Wave for now?
Or are you using only RGB with the plugin?
Thu Oct 08, 2015 12:53 pm
Chameleon offline
Hi both
Tomorrow is RGBW day for dimmers. I'm going to update to include the White Channel and release again.
Sorry it's taken so long - but tomorrow will see a new version :D I've been distracted with a couple of major changes to NEST and iFindStuff so I've neglected this plugin - but no more :oops:
Regards
Mike
