Re: Trigger based on current ambient temperature?
Posted: Fri Jul 12, 2019 8:41 am
autolog wrote:Chipping in
I suspect that might be because the state you are comparing against is a text string of '79 F' and therefore not numeric?
Is there a numeric only custom state that you can compare against?
The nest device is an Indigo thermostat. The trigger is against a standard device attribute. You can't get the "Becomes greater than" on the popup for a string type.
