Disappearing and re-appearing thermostats
Fri Jun 08, 2018 7:11 am
vtmikel offline
Yesterday, my NEST thermostats were deleted by the NEST plugin and re-added. This is the second time this has happened, the last time was ~1 month ago.
The occurrence of this is hard to detect because the devices look the exact same, but they are clearly a different Device ID as I had my thermostat ID's in several scripts that I hardcoded.
When it happens, HomeKit Bridge burps out the device, and several of my triggers need to be re-assigned. I discussed with @C4W and it's not something to do with HomeKit Bridge.
I think I'm giving up on having my thermostats in HomeKit Bridge. I don't use them via the Home app anyway. My household is used to going to the NEST app to control the thermostats. Old habits die hard. This will limit my re-work when this happens.
I saw a post from @dduf617 that indicated that I may not be the only one with this happening. Is the plugin still in active development? I wish there was a config option to turn off the automatic device removal/addition. This only needs to be there during initial setup and if someone adds a new NEST device to their household.
Fri Jun 08, 2018 7:19 am
Colorado4Wheeler offline
Re: Disappearing and re-appearing thermostats
Chameleon has been dealing with some health issue I believe, but he chimed in recently to let us all know he is OK. It's not HKB, we know that from your last post and the logs from then. I have Nests myself and have never had this happen. What generation are your thermostats?
Fri Jun 08, 2018 7:38 am
vtmikel offline
Here's a bit of info.
I have two 3rd generation thermostats, and 8 Protects (two second generation, six first generation, 7 are wired, 1 is battery).
Looking back at the logs, the devices disappeared right as I disconnected from a remote Indigo client to my Indigo server (.82 is a Mac client). It also appears that several plugins momentarily had problems connecting to their cloud services when this happened.
2018-06-07 22:48:23.610   Application   Indigo Cocoa client disconnected (10.66.0.82)
2018-06-07 22:48:23.616   Rachio Sprinklers Error   Unknown error:
  File "plugin.py", line 381, in _update_from_rachio
    dev.replacePluginPropsOnServer(props)
StandardError: ServerCommunicationError -- timeout waiting for response
2018-06-07 22:48:23.618   HomeKit Bridge Error   Exception in plugin.onAfter_nonpluginDeviceUpdated line 637: ServerCommunicationError -- timeout waiting for response
                      CODE: if serverId not in indigo.devices:
2018-06-07 22:48:23.618   Sonos Error   Error in plugin execution runConcurrentThread:
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 379, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 615, in updateRelTime
2018-06-07 22:48:23.618   Sonos Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2018-06-07 22:48:23.619   Z-Wave   received "Mudroom Luminance" sensor update to 1 lux
2018-06-07 22:48:23.621   Z-Wave   received "Mudroom Humidity" sensor update to 52%
2018-06-07 22:48:23.622   Z-Wave   received "Mudroom Temperature" sensor update to 68.0 °F
2018-06-07 22:48:23.972   HomeKit Bridge Warning   Indigo device Downstairs Thermostat was removed and is linked to HomeKit, removing from any impacted servers
2018-06-07 22:48:24.081   HomeKit Bridge   Caching all HomeKit Bridge devices...
2018-06-07 22:48:25.835   HomeKit Bridge Error   Exception in homekit.special_nestHvacMode line 1805: 'key id 1449718684 not found in database'
                      CODE: obj = indigo.devices[self.objId]
For object id 1449718684 alias 'Upstairs Thermostat'
2018-06-07 22:48:25.836   HomeKit Bridge Error   Exception in homekit.special_thermTemperatureSetPoint line 1921: 'key id 1449718684 not found in database'
2018-06-07 22:48:25.839   HomeKit Bridge Error   Exception in homekit.detCharacteristicValues line 1003: 'key id 1449718684 not found in database'
2018-06-07 22:48:25.840   HomeKit Bridge Error   Exception in homekit.detCharacteristicValues line 1000: 'key id 1449718684 not found in database'
                      CODE: if getter.replace("attr_", "") in dir(indigo.devices[self.objId]): hasvalue = True
2018-06-07 22:48:25.843   HomeKit Bridge Warning   Indigo device Upstairs Thermostat was removed and is linked to HomeKit, removing from any impacted servers
2018-06-07 22:48:25.867   HomeKit Bridge   Caching all HomeKit Bridge devices...
2018-06-07 22:48:27.328   HomeKit Bridge   Caching all HomeKit Bridge devices...
2018-06-07 22:48:29.157   HomeKit Bridge   Attempting to stop 'HomeKit Bridge'
2018-06-07 22:48:30.435   Sonos   SoCo Reactor Ignition...
2018-06-07 22:48:34.178   HomeKit Bridge   HomeKit server 'HomeKit Bridge' has been stopped
2018-06-07 22:48:34.204   HomeKit Bridge Warning   Device ID 1449718684 (Upstairs Thermostat) is linked to server 'HomeKit Bridge' but that device ID no longer exists in Indigo and will be removed from the configuration
2018-06-07 22:48:34.215   HomeKit Bridge   Caching all HomeKit Bridge devices...
2018-06-07 22:48:36.005   HomeKit Bridge   Attempting to start 'HomeKit Bridge'
2018-06-07 22:48:40.648   HomeKit Bridge   Server 'HomeKit Bridge' has successfully started, you can use your HomeKit apps or Siri for this accessory
2018-06-07 22:48:41.038   HomeKit Bridge   Caching all HomeKit Bridge devices...
2018-06-07 22:48:42.867   HomeKit Bridge   Attempting to stop 'HomeKit Bridge'
2018-06-07 22:48:47.889   HomeKit Bridge   HomeKit server 'HomeKit Bridge' has been stopped
2018-06-07 22:48:48.331   HomeKit Bridge   Attempting to start 'HomeKit Bridge'
2018-06-07 22:48:50.723   HomeKit Bridge   Server 'HomeKit Bridge' has successfully started, you can use your HomeKit apps or Siri for this accessory
2018-06-07 22:49:11.543   Z-Wave   received "Stairwell Temperature" sensor update to 72.0 °F
2018-06-07 22:49:12.408   Z-Wave   received "Stairwell Humidity" sensor update to 55%
2018-06-07 22:49:17.898   Z-Wave   received "Stairwell Luminance" sensor update to 0 lux
2018-06-07 22:49:18.132   Z-Wave   received "Stairwell Ultraviolet" sensor update to 0
2018-06-07 22:49:19.977   Z-Wave   received "036 - Stairwell Motion Sensor" status update battery level 100%
2018-06-07 22:49:25.282   Error   device "Downstairs Thermostat" state key humidityInput1 not defined (ignoring update request)
2018-06-07 22:49:25.285   Error   device "Downstairs Thermostat" state key humidityInputsAll not defined (ignoring update request)
2018-06-07 22:49:25.286   Error   device "Downstairs Thermostat" state key humidityInput1 not defined (ignoring update request)
2018-06-07 22:49:25.886   Error   device "Upstairs Thermostat" state key humidityInput1 not defined (ignoring update request)
2018-06-07 22:49:25.886   Error   device "Upstairs Thermostat" state key humidityInputsAll not defined (ignoring update request)
2018-06-07 22:49:25.887   Error   device "Upstairs Thermostat" state key humidityInput1 not defined (ignoring update request)
The plugin log in the "com.corporatechameleon.nestplugBeta" folder has no interesting log items.
I've been working with Matt about a server crash that I experience occasionally, though this does not coincide with one of those crashes.
