Support for Nest Temperature Sensor?
Wed Apr 18, 2018 4:50 pm
dcjackson offline
Would it be possible to add support for the new Nest Temperature Sensor?
https://nest.com/thermostats/nest-tempe ... /overview/
These report temperature in other rooms of the house, and you can configure the thermostat to use a particular sensor as the one to use to make thermostat decisions.
The main thing I care about would be the ability to log the temperature readings in each room over time via Indigo.
I don't really care about using Indigo to set which temperature sensor to use with the thermostat....
