Latest versions 2.0.22 released with setpoint triggers
Tue Oct 06, 2015 5:11 am
Chameleon offline
This new version adds the ability to track if the ambient temperature is within a set number of degrees of the cool, heat or target set point. This was based on a user request (see forum http://forums.indigodomo.com/viewtopic.php?f=170&t=14615&p=103231#p103231)
You can download the latest version (2.0.22) of NEST Home 1, 2 & 3 from these addresses:
In this release you will find:
    U07 - I would like a trigger that tells me when the ambient temperature is within x degrees of the CoolSetpoint, HeatSetPoint or TargetSetpoint (for users who only have heat or cool systems not combined)
This version enables the user to set a differential value in the NEST Home configuration dialog. By default it's set to 5 degrees (F or C depending on your NEST Settings).
New Configuration Screen
Screen Shot 2015-10-06 at 12.02.15.png (72.06 KiB) Viewed 1013 times
NEST Home now maintains three trigger states:
    coolpointTrigger - for HVAC systems. Set to true if the ambient temperature is +/- degrees differential (set in configuration screen) of the current cool setpoint otherwise false
    heatpointTrigger - for HVAC systems. Set to true if the ambient temperature is +/- degrees differential (set in configuration screen) of the current heat setpoint otherwise false
    targetTrigger - for heating or cooling systems. Set to true if the ambient temperature is +/- degrees differential (set in configuration screen) of the target temperature otherwise false
You can update your NEST Home in the usual way. The state of the trigger variables is calculated on each NEST update cycle and may take a few seconds to update initially. The triggers will remain blank until the calculation is completed for the first time.
