Thank you and I appreciate the plugin. I was thinking a picture of a nest protect with some indigo-style status icons... I found these on the NEST site describing the color functions of the circle. They could be renamed and used in the indigo static variable folder... I think.
(no color, but a place-holder file, mostly transparent with a thin line around the border for editor.)
(no color, but a place-holder transparent file... could mean no power, may have "OFF" printed in the middle.)
NestProtect+blue.png PAIRING/TESTING
- blue-light.png (9.2 KiB) Viewed 1635 times
NestProtect+green.png OKEY-DOKEY
- green-light.png (9.48 KiB) Viewed 1635 times
NestProtect+red.png EMERGENCY
- red-light.png (10.24 KiB) Viewed 1635 times
NestProtect+white.png PATHLIGHT (motion)
- white-light.png (7.78 KiB) Viewed 1635 times
NestProtect+yellow.png WARNING
- yellow-light.png (9.17 KiB) Viewed 1635 times
Having a picture of the nest protect to go under these controls may or may not add anything; I think simple is better. These PNG's would need scaling (smaller) most likely but maybe not. Also they use transparency and the best background would be a medium gray or black.... if you want to see the white ring. Obviously these need to be cropped as well when they are reformatted. The NestProtect+OFF.png file would be completely transparent while the NestProtect+.png file would be a cropped box with a thin red line around it just so it is visible while in the Indigo Control Page editor.
