Re: Latest Version NEST Home - 2.0.10 (Maintenance Release)
Sat Jun 13, 2015 6:10 am
Chameleon offline
There is a new version of NEST Home but don't get that excited - it just resolves a few minor bugs. It also allows a user to maintain three independent sites from Indigo with the release of another production version imaginatively called NEST Home 3. Note that there isn't any differences between the versions so you should install NEST Home rather than NEST Home 2 or 3 if you've only got one location to worry about.
(If you attempted to install version 2.0.6. you'll have got an already installed message because I forgot to update the version number :oops: )
You can find the latest versions NEST Home 2.0.10 on these links:
If you've already got NEST Home running successfully then you probably don't need to install this version and you can safely wait for the next major release - coming soon.
As usual, download and install - don't delete any devices or the preferences file and NEST Home will automatically sync itself to match your set up(s) on the first refresh.
Regards
Mike
Thu Oct 13, 2016 8:56 am
Busta999 offline
Dropbox error for download :shock:
That file isn’t here anymore
Someone might’ve deleted the file or disabled the link.
Fri Nov 11, 2016 12:50 pm
symmetric offline
It looks like there is a newer version - see the top level of the forum: http://forums.indigodomo.com/viewforum.php?f=170 (currently "Latest Version 2.0.32")
The "NEST Home Manual" pdf has a link in it to this page - it probably should point somewhere else...
