Try deleting the preferences file (/Library/Application Support/Perceptive Automation/Indigo 6/Preferences)
Delete the file that contains corporatechameleon
let me know if that helps...
Mike
Chameleon wrote:Try deleting the preferences file (/Library/Application Support/Perceptive Automation/Indigo 6/Preferences)
Mike
Installing and enabling plugin "NEST Home" v1.2.72
Loading plugin "NEST Home 1.2.72"
Starting plugin "NEST Home 1.2.72" (pid 77383)
Started plugin "NEST Home 1.2.72"
NEST Home Error versionCheck: There was an error parsing the server's version file.
May 25, 2015, 5:05:26 PM
NEST Home Basement Nest Protect last_connection updated to 2015-05-25t22:19:12.470z
NEST Home Craft Room Nest Protect (Upstairs) last_connection updated to 2015-05-25t22:49:33.918z
NEST Home Downstairs Hallway Nest Protect last_connection updated to 2015-05-25t22:46:52.448z
NEST Home Living Room Nest Protect last_connection updated to 2015-05-25t22:46:50.828z
NEST Home Master Bedroom Nest Protect last_connection updated to 2015-05-25t16:54:34.730z
NEST Home Office Nest Protect (Downstairs) last_connection updated to 2015-05-25t12:28:28.302z
NEST Home Upstairs Nest Protect (Hallway) last_connection updated to 2015-05-25t22:49:31.601z
NEST Home Upstairs Nest Protect (Office) last_connection updated to 2015-05-25t22:49:32.533z
NEST Home NEST nestPostcode has changed to 80538
May 25, 2015, 5:06:34 PM
NEST Home Thermostat Thermostat (Downstairs) last_connection updated to 2015-05-25T23:05:33.279Z
pegoto wrote:Hi,
Which variable would show me that my nest is heating or not? The variables I thought looked like the ones do not work and I see no other question like this so...I believe I missed it. Please help.
artpics wrote:here is a new error
May 27, 2015, 2:16:31 AM
Upgrading plugin "NEST Home" to newer version 1.2.80 (previous version moved to trash)
Loading plugin "NEST Home 1.2.80"
Starting plugin "NEST Home 1.2.80" (pid 36172)
Started plugin "NEST Home 1.2.80"
NEST Home Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1423, in runConcurrentThread
File "plugin.py", line 332, in nestMapping
File "plugin.py", line 983, in nestDeviceSync
<type 'exceptions.TypeError'>: string indices must be integers, not str
NEST Home Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Chameleon wrote:pegoto wrote:Hi,
Sorry I missed your post.
Although the NEST API doesn't provide these simple fields I have added them now. There are three that should be updated at each refresh. IsCooling (Yes or no), IsHeating and heatOrCool (Heating, Cooling, Saving Energy or Off). These provide the information you're looking for. These should be available if your using NEST Home 1.2.80 (the latest version). How these fields work and calculated are covered in the Latest Software release notes forum under version 1.1.36.
You've reminded me that I need to update the FAQ s again
Remember these fields won't be updated until the first refresh. If these fields remain blank on yoursystem then we've got an issue I need to resolve and we'll have to investigate further
Regards
Mike
mikeL wrote:Thank you, Mike, for this great plugin. The hvac_state attribute in 1.3.10 is working well for me, so far. I use that attribute to trigger energy usage calculations for my AC and heating system.
Do you have any news on Goggle’s plans to allow us to turn the fan on and off at will? During warm periods, my cooling system pumps a bunch of cold air into the basement of my house. This airis essentially trapped in the basement. This happens because the central heating/cooling system in my typical Canadian house is located in the basement and its ducts are quite leaky. If I turn the fan on without the AC operating, the cold air gets pushed up into the main part of the house. I do this now using the Nest app, but Indigo could do this automatically if only we could control the fan through the API.
I look forward to seeing this functionality in the plugin someday. Thanks,
Mike
