Error with latest
Fri Apr 12, 2024 7:33 pm
vtmikel offline
Error with latest
Hi-
Since upgrading to 40.98, I'm getting these errors on startup:
ValueError: invalid literal for int() with base 10: ''
   fingscan Error
  File "plugin.py", line 920, in deviceStartComm
    if addrOld != self.formatiPforAddress(addrOld).strip(" "):
  File "plugin.py", line 4701, in formatiPforAddress
    if   int(digit) < 10:   last = "00"
Sun Apr 14, 2024 1:58 am
Re: Error with latest
v .99 should catch that error message.
you must have a device that has a blank address field,
the latest version is checking the address field (removing links and checking if its a proper ip number) and hence gets that error.
Now you will get a message with the name of the device that is not properly defined.
this should only happen during startup. and should not impact normal operations
Sun Apr 14, 2024 10:15 am
vtmikel offline
Hey thanks-- one more exception to report. This started happening yesterday. I added a new device to my network, which may be the culprit.
   fingscan Error                  name:FING-1C:63:49:3B:84:C7-Texas Instruments
  File "plugin.py", line 4110, in createDev
    address=self.formatiPforAddress(devI["ipNumber"]),
  File "plugin.py", line 4705, in formatiPforAddress
   fingscan Error
  File "plugin.py", line 4121, in createDev
    dev = indigo.devices[theName]
KeyError: 'key name FING-1C:63:49:3B:84:C7-Texas Instruments not found in database'
   Cynical Weather Error           Weather - Westwood Location ignoring update request within {MIN_REFRESH} minutes of last one
Sun Apr 14, 2024 12:00 pm
I can catch that error, BUT what is the IP number of the device?
please check vhttps://github.com/kw123/fingscan/releases/tag/2022.40.100 not official release.
add some more if statements to catch more exceptions.
i deleted some devices, and added them back, no errors.
Sun Apr 14, 2024 12:04 pm
vtmikel offline
Here's the log:
   fingscan                        createDev; try to create new dev:FING-1C:63:49:3B:84:C7-Texas Instruments, with MAC:1C:63:49:3B:84:C7, ipN:>>{'ipNumber': '10.66.0.197', 'timeOfLastChange': '2024-04-14 13:59:08', 'status': 'up', 'noOfChanges': 75, 'hardwareVendor': 'Texas Instruments', 'deviceInfo': '', 'usePing': 'doNotUsePing', 'upToDownPing': 30, 'downToExpiredPing': 60, 'useWakeOnLanSecs': 0, 'useWakeOnLanLast': 0, 'suppressChangeMSG': 'show', 'deviceId': 0, 'deviceName': '', 'fingLastUp': 0, 'firstFingDown': 0, 'expirationTime': 0, 'variableName': '', 'devExists': 0}<<
   fingscan                        createDev; new dev:FING-1C:63:49:3B:84:C7-Texas Instruments, with States : (dict)
Sun Apr 14, 2024 11:47 pm
did it create the device and could you send a screen copy of the device states?
I will be out for 2 days, back on wednesday, but i can look at things, but can not d any updates
