Fingscan Error
Posted: Sat Nov 12, 2022 12:41 pm
by earache
Just installed Fingscan and am getting a series of these errors:
fingscan Error
File "plugin.py", line 3751, in createDev
indigo.device.create(
ValueError: NameNotUniqueError
fing.log seems to indicate that it's finding all my devices.
Any ideas?
Re: Fingscan Error
Posted: Mon Nov 21, 2022 4:43 am
by lotsacaffeine
I'll double down on this question. Now the strange part is my subnet is 10.185.0.0/24 not 192.168.1.0/24.
Later down the log you'll see it pick up my subnet.
It's failing while trying to create what looks like a discovered device whose name is possibly lingering in the database?
Just taking a guess.
I think there's a way to flush fingscan's memory. I'll look...give it a try...and let you know later.
--Bill
Nov 21, 2022 at 5:30:48 AM
fingscan Warning network setings changed, will auto restart plugin in a minute new defs: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
fingscan
fingscan --> while loop break stopping ... quitNOW was: new Network
Reloading plugin "fingscan 2022.37.92" using API v3.0.0
Stopping plugin "fingscan 2022.37.92" (pid 69212)
fingscan Warning stopConcurrentThread called 2
fingscan runConcurrentThread stopping plugin due to: ::::: no :::::
Plugin restart request ignored (plugin is currently stopping or starting)
fingscan killing 2
Stopped plugin "fingscan 2022.37.92"
Starting plugin "fingscan 2022.37.92" (pid 90615)
fingscan initializing ...
fingscan path To files: =================
fingscan detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.fingscan/plugin.log
fingscan testing logging levels, for info only:
fingscan logger enabled for INFO ==> TEST ONLY
fingscan Warning logger enabled for WARNING ==> TEST ONLY
fingscan Error logger enabled for ERROR ==> TEST ONLY
fingscan Error logger enabled for CRITICAL ==> TEST ONLY
fingscan using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
Started plugin "fingscan 2022.37.92"
fingscan testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
fingscan debug settings :[]
fingscan FINGSCAN-- initializing will take ~ 2 minutes..
fingscan indigo variables initialized
fingscan network info: {'netMask': '255.255.255.0', 'netWorkId': '10.185.0.1', 'broadcast': '10.185.0.255', 'hostRange': '10.185.0.1 - 10.185.0.254', 'maxHosts': 254}, netwType:24
fingscan getting password
fingscan get password done; checking if FING is installed
fingscan Error
fingscan Error
fingscan Error
fingscan Error
fingscan Error
fingscan loaded indigo data
fingscan Initializing parameters for FING
fingscan Waiting for first data from FING
Nov 21, 2022 at 5:31:18 AM
Disabling plugin "fingscan 2022.37.92"
Stopping plugin "fingscan 2022.37.92" (pid 90615)
fingscan Warning stopConcurrentThread called 1
fingscan Error
File "plugin.py", line 1966, in initFing
self.sleep( 1 )
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/plugin_base.py", line 487, in sleep
raise self.StopThread
plugin_base.PluginBase.StopThread: None
fingscan Error FING not running... quit
fingscan
fingscan
EVENT defs:::::::::::::::::: Start :::::::::::::::: -- all
EVENT defs:::::::::::::::::: END ::::::::::::::::::
fingscan getting vendor info..
fingscan Warning shutdown called
Re: Fingscan Error
Posted: Thu Dec 08, 2022 8:43 am
by siclark
Hi Karl, I am getting the same error as well. I disabled the plugin, deleted the plugin folder, all preferences and logs and downloaded fresh and it still did the same thing. Interestingly it remembered my Mac password, so maybe there was a file I didn't find?
Simon
Re: Fingscan Error
Posted: Thu Dec 08, 2022 9:04 am
by siclark
It appears to be working ok on version v2022.37.90. but when I then download latest version I get the same error again. Downgrading doesn't help.
