Error in v2022.36.89
Sun Sep 18, 2022 12:59 pm
Betacruxis offline
Great plug-in. Very useful. Thanks for your work.
Altho, after the last two updates I keep getting the following error (I transcribe the full load sequence. Error message comes last):
18 Sep 2022 15:52:12
fingscan --> while loop break stopping ... quitNOW was: restart required; 'Plugin' object has no attribute 'M2V'
Reloading plugin "fingscan 2022.36.89" using API v3.0.0
Stopping plugin "fingscan 2022.36.89" (pid 29224)
fingscan Warning stopConcurrentThread called 2
fingscan runConcurrentThread stopping plugin due to: ::::: no :::::
Plugin restart request ignored (plugin is currently stopping or starting)
fingscan killing 2
Stopped plugin "fingscan 2022.36.89"
Starting plugin "fingscan 2022.36.89" (pid 29501)
fingscan initializing ...
fingscan path To files: =================
fingscan detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.fingscan/plugin.log
fingscan testing logging levels, for info only:
fingscan logger enabled for INFO ==> TEST ONLY
fingscan Warning logger enabled for WARNING ==> TEST ONLY
fingscan Error logger enabled for ERROR ==> TEST ONLY
fingscan Error logger enabled for CRITICAL ==> TEST ONLY
fingscan using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
Started plugin "fingscan 2022.36.89"
fingscan testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
fingscan debug settings :[]
fingscan FINGSCAN-- initializing will take ~ 2 minutes..
fingscan indigo variables initialized
fingscan network info: {'netMask': '255.255.255.0', 'netWorkId': '192.168.1.1', 'broadcast': '192.168.1.255', 'hostRange': '192.168.1.1 - 192.168.1.254', 'maxHosts': 254}, netwType:24
fingscan getting password
fingscan get password done; checking if FING is installed
fingscan loaded indigo data
fingscan Initializing parameters for FING
fingscan Waiting for first data from FING
18 Sep 2022 15:52:42
fingscan Initializing .. FING created new data waiting ~ 1 minute for stable operation
fingscan .. (re)started FING, initialized
fingscan
fingscan
EVENT defs:::::::::::::::::: Start :::::::::::::::: -- all
EVENT defs:::::::::::::::::: END ::::::::::::::::::
fingscan getting vendor info..
fingscan Error
File "plugin.py", line 540, in updateVendors
if not self.waitForMAC2vendor: self.waitForMAC2vendor = not self.M2V.makeFinalTable(quiet=True)
AttributeError: 'Plugin' object has no attribute 'M2V'
The plug-in stops and reloads itself every one minute or so.
I left the plug-in running for about two days (the last version before this one behaved all the same), but still get that error and behavior with the new version.
Thanks for your time!
Tue Sep 20, 2022 7:37 am
Re: Error in v2022.36.89
please try v ...90
should be fixed
Added features / changes in v2022.36.90 @ 2022-09-20
fixed:  'Plugin' object has no attribute 'M2V'
  this happens when vendor loockup is disabled
  variables are now properly initialized
Tue Sep 20, 2022 8:04 am
Betacruxis offline
Works like a charm in version ...90.
