A few errors in v2022.34.81
Fri Aug 26, 2022 4:47 pm
Monstergerm offline
This happened after selecting "Reset all Devices"
fingscan Error
File "plugin.py", line 2028, in resetDevices
self.writeToFile()
File "plugin.py", line 2681, in writeToFile
f.write(writestring.encode("utf8")) # -->this needs to be decode
TypeError: write() argument must be str, not bytes
fingscan Error
File "plugin.py", line 5703, in updateIndigoIpDeviceFromDeviceData
dev = indigo.devices[devId]
KeyError: 'key not found in database'
During handling of the above exception, another exception occurred:
File "plugin.py", line 5736, in updateIndigoIpDeviceFromDeviceData
dev = indigo.devices[name]
TypeError: elem or key type must be either an elem integer ID, elem string name, or elem instance
Same errors happen after selecting "Reset all Events", plus this additional one
fingscan Error
File "plugin.py", line 4136, in compareToFingIfExpired
xxx = self.fingMACNumbers.index(theMAC)
ValueError: '7C:D1:C3:1B:95:C7' is not in list
Sat Aug 27, 2022 12:06 am
I believe, i have fixed the first errors, now looking at:
that section should never throw an error. it has an try / except around it
            try:  ## try to find this indigo mac number in  fingdata
            except:  ## this one is in indigo, but not in the fingdata file, set to exipred if not already done or ignore if better data from wifirouter
and I can not reproduce the error.
But it should fix itself after all data is loaded ..
please try the new posted version : 2022.34.82
Sat Aug 27, 2022 12:32 pm
Monstergerm offline
Re: A few errors in v2022.34.81
Karl,
First a couple of questions:
1) What is the MAC password that I should enter in the config dialog, the Indigo Server Mac computer password or the Wifi Router admin password?
2) Also, should fingscan try to find the user friendly device name in the Indigo UI for each fingscan device, like MacMini-ServerRoom? Currently they are named MAC_XX:XX:XX:XX:XX:XX or New-0-XX:XX:XX:XX:XX:XX
I tried new version .82
UTF-8 error is fixed but I still get the other errors when I select "Reset all Devices". A total of 24 IP devices show up (not 26).
Aug 27, 2022 at 11:07:49 AM
fingscan updateIndigoIpDeviceFromDeviceData: devId 0 does not exist in indigo devices, recreate for mac#:A6:89:B1:69:D8:10
fingscan Warning updating ipDevice 01 does not exist , (re)creating
Aug 27, 2022 at 11:08:11 AM
fingscan updateIndigoIpDeviceFromDeviceData: devId 0 does not exist in indigo devices, recreate for mac#:90:72:40:07:DD:91
fingscan Error
File "plugin.py", line 5722, in updateIndigoIpDeviceFromDeviceData
File "plugin.py", line 5756, in updateIndigoIpDeviceFromDeviceData
fingscan Warning updating ipDevice 03 does not exist , (re)creating
fingscan FINGSCAN initialized
Aug 27, 2022 at 11:08:32 AM
fingscan updateIndigoIpDeviceFromDeviceData: devId 0 does not exist in indigo devices, recreate for mac#:8C:2D:AA:2F:CD:B1
fingscan Warning updating ipDevice 04 does not exist , (re)creating
fingscan Error
fingscan Error
Aug 27, 2022 at 11:09:15 AM
fingscan Warning updating ipDevice 06 does not exist , (re)creating
fingscan Warning updating ipDevice 07 does not exist , (re)creating
fingscan Warning updating ipDevice 08 does not exist , (re)creating
fingscan Warning updating ipDevice 09 does not exist , (re)creating
fingscan Warning updating ipDevice 10 does not exist , (re)creating
fingscan Warning updating ipDevice 11 does not exist , (re)creating
fingscan Warning updating ipDevice 12 does not exist , (re)creating
fingscan Warning updating ipDevice 13 does not exist , (re)creating
fingscan Warning updating ipDevice 14 does not exist , (re)creating
fingscan Warning updating ipDevice 15 does not exist , (re)creating
fingscan Warning updating ipDevice 16 does not exist , (re)creating
fingscan Warning updating ipDevice 17 does not exist , (re)creating
fingscan Warning updating ipDevice 18 does not exist , (re)creating
fingscan Warning updating ipDevice 19 does not exist , (re)creating
fingscan Warning updating ipDevice 20 does not exist , (re)creating
fingscan Warning updating ipDevice 21 does not exist , (re)creating
fingscan Warning updating ipDevice 22 does not exist , (re)creating
fingscan Warning updating ipDevice 23 does not exist , (re)creating
fingscan Warning updating ipDevice 24 does not exist , (re)creating
fingscan Warning updating ipDevice 25 does not exist , (re)creating
Aug 27, 2022 at 11:10:30 AM
fingscan updateIndigoIpDeviceFromDeviceData: devId 0 does not exist in indigo devices, recreate for mac#:60:C5:47:90:39:58
fingscan Error
Aug 27, 2022 at 11:11:13 AM
fingscan Warning updating ipDevice 26 does not exist , (re)creating
Sun Aug 28, 2022 1:41 am
Password: it is the mac user password. Wifi is not used any more. It was for an old asus wifi router. I should delete that section
2. why do you want to reset everything?
This was an option for when by mistake things were screwed up. I have not used that one for years.
3. device names. The current schema guarantees a unique name. You then need to rename them to what ever you like. Adding fancy naming algorithms is a source for issues
If you don’t do a reset, things should work fine
And I will check the errors.
Sun Aug 28, 2022 1:09 pm
Monstergerm offline
I just wanted to reset devices since I had so many expired ones and also devices that said "UP 0", instead of "UP <date>"
also got this error in the middle of the night
fingscan Error
File "plugin.py", line 3146, in getfingData
self.fingStatus = self.column(self.fingData,2)
File "plugin.py", line 6147, in column
return [row[i] for row in matrix]
File "plugin.py", line 6147, in <listcomp>
IndexError: list index out of range
Mon Aug 29, 2022 9:00 am
please try v 2022.35.84 posted on GitHub and indigo store
Mon Aug 29, 2022 1:26 pm
Monstergerm offline
thanks Karl, will test it.
Regarding the password, you might want to clarify this in the Config dialog, like "Enter Indigo Server Mac login password:"
MAC is confusing since we also have MAC addresses.
I would also hide the password from prying eyes by setting the flag secure="true" in the PluginConfig.xml
And why does the plugin need to restart every night?
And only one of my devices has a hardwareVendor listed. Shouldn't they all get updated at first run of plugin?
Mon Aug 29, 2022 3:17 pm
"Enter Indigo Server Mac login password:" ==> yes will do
secure="true" ==> only you look at it. and it is stored openly in plugin prefs in the indigo directory. initially I had stored it in the mac keychain, but since some OS versions ago that did not not work anymore.
And why does the plugin need to restart every night? I had this initially just as a check . Never saw the need to change that. the plugin will restart and then be quiet for 3 minutes ie no state changes until everything is settled. and as this happens at midnight it should not matter
And only one of my devices has a hardwareVendor listed. ==> that depends on if the MAC numbers are registered with the public data base.
ps try the menu: Print details of IP_services of ... it will give you a very nice overview of your network, with all devices, open ports etc. !!! it will take several minutes !!!
eg:
   fingscan                        IP-Device Number, Name, Vendor,..IP-Device port scan on  2022-08-29 16:55:24IP-Device Number, Name, Vendor,...------------------------------------------------------------------------
IP-Device Number, Name, Vendor,...192.x.x.x      B4:FB:E4:29:F0:BD                         MAC_B4:FB:E4:29:F0:BD Ubiquiti Networks Inc.firewall:false
..... service Port, Name, Comment:    22 ssh               SSH Secure Shell
..... service Port, Name, Comment:    53 domain            Domain Name Server
..... service Port, Name, Comment:    80 http              World Wide Web HTTP
..... service Port, Name, Comment:    443https             Secure World Wide Web HTTP (SSL)
Tue Aug 30, 2022 12:41 pm
Monstergerm offline
still getting this error during the night in v 2022.35.84
fingscan Error
File "plugin.py", line 2182, in getfingData
File "plugin.py", line 4163, in column
File "plugin.py", line 4163, in <listcomp>
Tue Aug 30, 2022 1:37 pm
before I "fix" that:
could you check the files:
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.fingscan/fing.data
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.fingscan/fing.log
they will appear after ~ 1-2 minutes after start of the plugin
they should look like this with several lines
192.168.1.20;;up;;;B8:27:EB:5A:47:CF;Raspberry Pi Foundation
if there are lines that are shorter ie with less than 6 ";" then there is a fing.exe problem.
ps I now have a version that
1. sets password =**** in the config screen
2. you can select if and when the plugin should restart every night
would like to let it run one more night to check
Tue Aug 30, 2022 3:17 pm
Monstergerm offline
Hi Karl
both files have six ";" per line
And it might not matter, I am on a 10.0.1.1 network range.
But what is weird, the log lists hardware vendors for most of my devices, but in Indigo UI looking at custom states only one of my Apple devices shows "Apple" and the rest is not showing any vendor at all.
Also, still have many "UP 0" devices but log shows a date for all of those.
And even weirder, I named all my devices in Indigo UI but only some devices show this new name as custom state "nickName" while others still show the nickName with the original default name MAC_XX:XX:XX:XX:XX:XX
Wed Aug 31, 2022 5:51 am
please try new version just posted 2022.36.85
Thu Sep 01, 2022 7:08 pm
new2me07 offline
022-09-01 20:58:25   killing FING Processes pids   all - ['']
2022-09-01 20:58:25   FING kill cmd:echo 'xxxxxx | sudo -S /bin/kill -9    > /dev/null 2>&1 &
2022-09-01 20:58:26 testing if FING is running
2022-09-01 20:58:26   FING running pids2=
2022-09-01 20:58:26   FING still running,  pids = ['']--[]
2022-09-01 20:58:26 FING cmd= '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/startfing.py' '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.fingscan/paramsForStart'  &
startfing  20:58:26 L:276 Lv:20 ========= start   @ 2022-09-01 20:58:26.737000   ===========;  loglevel:20
startfing  20:58:26 L:230 Lv:20  get pids of old processes w cmd:ps -ef | grep 'Plugin/startfing.py' | grep -v grep | awk '{print $2}'
startfing  20:58:26 L:230 Lv:20  get pids of old processes w cmd:ps -ef | grep '/usr/local/lib/fing/fing.bin' | grep -v grep | awk '{print $2}'
startfing  20:58:26 L:230 Lv:20  get pids of old processes w cmd:ps -ef | grep '/usr/local/bin/fing' | grep -v grep | awk '{print $2}'
startfing  20:58:26 L:287 Lv:20 params: {'ppp': '&a3xxxxx#5B', 'theNetwork': '192.168.1.0', 'netwType': '24', 'logLevel': 20, 'fingEXEpath': '/usr/local/bin/fing', 'macUser': 'chxxxx', 'pythonPath': '/Library/Frameworks/Python.framework/Versions/Current/bin/python3'}
startfing  20:58:26 L:290 Lv:20 echo 'xxxxxxx | sudo -S /bin/rm '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.fingscan/fing.data'
startfing  20:58:26 L:294 Lv:20 echo 'xxxxxxx' | sudo -S /bin/rm '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.fingscan/fing.log'
startfing  20:58:26 L:298 Lv:20 echo 0 > '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.fingscan/fing.log'
startfing  20:58:27 L: 69 Lv:20 chk versions.opsys: 12.5;   fingVersion:5.5 from cmd:echo 'xxxxxxx | sudo -S /usr/local/bin/fing -v;
startfing  20:58:27 L: 85 Lv:20 into doFingV5 with yearTag: 2022/09, netTag: 192., version: 5.5;  opsys: 12.5
startfing  20:58:27 L: 93 Lv:20 fing start command: cd '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.fingscan/';echo 'xxxxxx' | sudo -S '/usr/local/bin/fing' 192.168.1.0/24   -o table,csv,  log,csv  &
startfing  20:58:27 L:100 Lv:40 try# 1; msg  <_io.BufferedReader name=7> -- err: <_io.BufferedReader name=9>, ListenProcessFileHandle:<Popen: returncode: None args: "cd '/Library/Application Support/Perceptive ...>
2022-09-01 20:58:27 testing if FING is running
2022-09-01 20:58:27   FING running pids2=
2022-09-01 20:58:27   killing FING Processes pids   onlyParents - ['33410']
2022-09-01 20:58:27   FING kill cmd:echo 'xxxxxxx' | sudo -S /bin/kill -9   33409 > /dev/null 2>&1 &
2022-09-01 20:58:28 testing if FING is running
2022-09-01 20:58:29   FING running pids2=
2022-09-01 20:58:29   FING still running,  pids = ['33410']--[]
2022-09-01 20:58:29 Waiting for first data from FING
startfing  20:58:29 L:230 Lv:20  get pids of old processes w cmd:ps -ef | grep 'sudo -S /usr/local/bin/fing' | grep -v grep | awk '{print $2}'
startfing  20:58:29 L:230 Lv:20  get pids of old processes w cmd:ps -ef | grep '/bin/sh /usr/local/bin/fing' | grep -v grep | awk '{print $2}'
startfing  20:58:29 L:112 Lv:20 fing.bin launched
2022-09-01 21:00:14 Initializing .. FING data file not created, return
2022-09-01 21:00:14.724   ERROR          Plugin.initConfig                 FING not running... quit
2022-09-01 21:00:14 settings:  inbetweenPingType            parallel
2022-09-01 21:00:14 settings:  wait seconds between cycles  4
Any ideas why the data and log files aren't getting created... I've had a lot of issues, but its still updates things in the UI, sporadically. I deleted the data and log files a while ago, as I've done in the passed, and they've always respawned. It was probably 3 versions ago when they were deleted
Thu Sep 01, 2022 7:19 pm
Monstergerm offline
I installed 2022.36.85 and had no errors for the last 24 hours.
This version also fixed the "UP 0" issue in the Indigo UI, all devices now have a date.
It did NOT fix the nickName issue and hardwareVendor issue as previously explained.
Thu Sep 01, 2022 10:48 pm
For the Harvard vendor info
Switch on debug logic and restart.
It should show you what info is available for each device.
