Fingscan Stopping and starting every 10 seconds
Thu Sep 13, 2018 6:00 am
Busta999 offline
Hi
Just upgraded to latest version.
Now getting the following - I have disabled it for now because it is just constantly stopping and starting
Any suggestions - I can't access Configure when disabled and can't access it when enabled so not sure what else I can do here.
Reloading plugin "fingscan 7.29.35"
   Stopping plugin "fingscan 7.29.35" (pid 4273)
   fingscan Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Stopped plugin "fingscan 7.29.35"
   Starting plugin "fingscan 7.29.35" (pid 4323)
   Hue Lights                      received "Motion - Landing (Hue)" status update is off
   Started plugin "fingscan 7.29.35"
   fingscan                        FINGSCAN--   initializing     will take ~ 2 minutes...; sending logs to /Users/michaelhorton/indigo/fing/fingPlugin.log
   SQL Logger                      creating table variable_history_1606032837 for "ipDevsLastUpdate"
   SQL Logger                      creating table variable_history_1575592607 for "ipDevsLastDevChangedIndigoName"
   SQL Logger                      creating table variable_history_1584192804 for "ipDevsNewDeviceNo"
   SQL Logger                      creating table variable_history_858403646 for "ipDevsNewIPNumber"
   SQL Logger                      creating table variable_history_127122148 for "ipDevsNoOfDevices"
   fingscan                        in Line '499' has error='invalid literal for int() with base 10: '''
   Stopping plugin "fingscan 7.29.35" (pid 4323)
Thu Sep 13, 2018 6:28 am
Re: Fingscan Stopping and starting every 10 seconds
should be fixed in v .36
after start you then MUST set the config settings, ie network# etc
