Detect a new device/person on LAN and take actions
Sun Jul 01, 2018 2:25 pm
mundmc offline
Hi Karl,
I'm a little neurotic, and I want Pushover notifications whenever a new device connects to my LAN. I'm unclear whether I would be better suited to do this on your Unifi plugin, which I also use.
I assume the best way is via 1) Trigger on "Fingscan Event" -> "New IP Device on Network"
My question is HOW do I tell what the MAC address, etc, of the new device is? It looks like it is stored in the "IP devices" folder. I've played at this for about 2 hours, sorry to bug if it's an obvious answer!
PS- I'll wash your car if you can then tell me how to do this for devices Unifi (or piBeacon) detects that are NOT on my network, because that mailman of mine is looking shifty :)
Sun Jul 01, 2018 6:34 pm
mundmc offline
Re: Detect a new device/person on LAN and take actions
I'm doing it like this in the interim, not sure if it's working as it hasn't been triggered yet...
newDevice = indigo.variables[491200589].value # "ipDevsNewIPNumber"
indigo.server.log("New Device: " + newDevice)
#New Device: ipDevice54;new-10-9C:8E:CD:0D:97:EF
newDeviceNumber = newDevice[15:17]
newDeviceMAC = newDevice[18:35]
indigo.server.log("Device Number: " + str(newDeviceNumber))
indigo.server.log("Device MAC: " + str(newDeviceMAC))
Sun Jul 01, 2018 11:13 pm
here the update command:
indigo.variable.updateValue("ipDevsNewDeviceNo", "ipDevice"+str(newIPDevNumber)+";"+devI["deviceName"])
variable ipDevsNewDeviceNo will contain:
ipDeviceindigo.dev.number;indigo.devicename
eg "ipDevice12345;new-571"
where 12345 is the indigo device number and new-5711 is the indigo device name of the new device
AND do not use indigo variable # but indigo variable name to check. The variable gets recycled at midnight = deleted and recreated - that means it gets a new indigo #. That way the sql tables are kept smaller.
   var = indigo.devices("ipDevsNewDeviceNo").value
   var = var.split(";")
   newDeviceNumber =int( var[0].split("Device")[1])
   newDeviceName   = var[1]
except:
   newDeviceNumber =0
   newDeviceName =""
if newDeviceNumber != 0:   do your stuff
should give you the indigo device name & numbers if there is a new ip device added.
the try/ except is useful if the variable is blank or 0 (eg at creation)
hope that helps.
ps I have 2 cars
Mon Jul 02, 2018 7:15 am
mundmc offline
Thanks Karl,
I’ll give it a go!
Mon Jul 02, 2018 2:55 pm
actually it is not the dev.id but the variable name eg:
ipDevice07;new-10-00:1F:5B:30:E9:20
tried by deleting a device and it was recreated.
so the code should be
except:
   newDeviceName =""
if newDeviceName != "":   do your stuff
Wed Jul 04, 2018 1:40 am
McJohn offline
Thanks for the info Karl.
We have also a question about this issue.
Fingscan Event Trigger:
New IP Device on Network;
Actions:
email the new IP device details:
(hardware vendor, MACNumber, ipNumber)
How could we do that?
Thanks for your help!
Warm regards,
John
Wed Jul 04, 2018 2:52 am
create trigger : new ip device on network, then in ACTIONS server script:
ipDev = indigo.variables["ipDevsNewDeviceNo"]
ipDevVarNumber   = ipDev.value.split(";")[0]
devName = ipDev.split(";")[1]
theSubject = "new device on network " + devName
theBody = "new device on network\n"
theBody += indigo.variables["ipDevice00"].value +"\n" # this gives the headline
theBody += indigo.variables[ipDevVarNumber].value  # this writes the contents of the new variable below the header line
indigo.server.log(theBody)# also send it to the indigo log file
indigo.server.sendEmailTo("youremail@xxx.com", subject=theSubject, body=theBody)
Wed Jul 04, 2018 8:42 am
McJohn offline
Thanks for the fast feedback Karl! Super!
One problem (sorry):
Script Error embedded script: 'Variable' object has no attribute 'split'
embedded script, line 4, at top level
AttributeError: 'Variable' object has no attribute 'split'
Wed Jul 04, 2018 9:37 am
line 4:
I think should be
devName = ipDev.value.split(";")[1]
Wed Jul 04, 2018 9:40 am
Yes, just typed it on my cell
indigo.variables.value gives the string.
Wed Jul 04, 2018 2:37 pm
mundmc offline
So i've got this so far:
var = indigo.variables["ipDevsNewDeviceNo"].value
indigo.server.log("New Device String: " + var)
indigo.server.log("New Device Name:  " + newDeviceName)
subvar = var[1].split("-")
newDeviceMAC = subvar[2]
indigo.server.log("New Device MAC:  " + newDeviceMAC)
newDeviceTimeUp = indigo.devices[newDeviceName].states["lastFingUp"] # State lastFingUp of newest device
indigo.server.log("New Device Time Up: " + newDeviceTimeUp)
newDeviceIP = indigo.devices[newDeviceName].states["ipNumber"] # State ipNumber of newest device
indigo.server.log("New Device IP:  " + newDeviceIP)
indigo.variable.updateValue(indigo.variables[529430126], newDeviceName) # DEVICETRACKING_fing_devicename
indigo.variable.updateValue(indigo.variables[1683113861], newDeviceMAC) # DEVICETRACKING_mac_address
indigo.variable.updateValue(indigo.variables[96904041], str(newDeviceTimeUp)) # DEVICETRACKING_last_new_up
indigo.variable.updateValue(indigo.variables[934101919], str(newDeviceIP)) # DEVICETRACKING_ipaddress
I need to test it, but my hope is this will make new devices logging into wifi push an alert to me (I use pushover, though email will be good redundancy).
Am I correct in my assumption that new guests logging into my wifi will trigger this?
Any recommendations on how best to test it? (I plan to pick out the MAC of a known device and delete it's Device created by the plugin, though I may have to delete it's Variable as well.
Wed Jul 04, 2018 2:49 pm
the script looks fine .
to your question on new MAC device if guest login:
if a new device attaches to the network and sends ANY broadcast fing(SCAN) will catch it.
Thu Jul 05, 2018 12:56 am
McJohn offline
Yes! It's working!
Thank you very much for the fast Service! :D
Thu Jul 05, 2018 2:03 am
McJohn offline
Is it btw possible to give each header and content a return?
So, then the text is better readable on an iPhone.
Screen Shot 2018-07-05 at 09.58.11.png (77.55 KiB) Viewed 4301 times
Thu Jul 05, 2018 2:57 am
Add
+”\n”
To the end of each line you want to have an extra new line
