ASUS/MERLIN version confusion
Posted:
Fri Dec 09, 2016 5:25 am
by Hackencrash
Having just updated to FINGSCAN v7.21.2, I'm in confusion as to what to set my "type of Router" to on the Plugin Configure page.
I have an Asus Router with v380.62_1 Merlin firmware, so should I select
< 378_54 or
v= 378_54 as neither of these mathematically equate?
Re: ASUS/MERLIN version confusion
Posted:
Fri Dec 09, 2016 7:29 am
by kw123
Try it out. It's about what kind of op-Sys your router runs. But it does not support any newer version with the new better security model. ~ introduced 18 months ago
Posted:
Fri Dec 09, 2016 7:39 am
by Hackencrash
I think you need to spell it out for me.
Does
v= 378.84 mean
>= 378.84 or has FINGSCAN only been tested with that specific version and I need to downgrade my firmware, or are you saying that I should try different values in fingscan for this to see what happens?
If I choose the latter option, what should I be looking out for to see if it works or not?
More confused than before
Posted:
Fri Dec 09, 2016 8:28 am
by kw123
I don't recall anymore ... sometime around these versions the screen got changed. And I adopted the program. I guess I mistyped the version #'s
anyway these merlin versions should work:
378.56_2 (2-Nov-2015)
and
380.58 (20-Mar-2016)
anything with the new token security not anymore.
Posted:
Fri Dec 09, 2016 9:39 am
by Hackencrash
OK, since my current Merlin version is only a minor version difference from the latest version you've tested (380.62 vs 380.58) I would imagine I'm OK at my firmware level with fingscan and that I should choose the last option from the fingscan router type: ASUS/MERLIN v= 378_54 as being the most feature rich?
Posted:
Fri Dec 09, 2016 10:00 am
by kw123
looking at the code: the last version that is indicated is MERLIN378_54
and anything before should pick ASUS/MERLIN < 378_54
I am sorry not be able to help as I have switched to unifi routers and AP's. I switched this year in June and I believe they upgraded to the new security schema in ~ April/May. That is when the wifi part stopped working as the simple "curl" statement did not work any more.
to test if it can work: could you open a terminal and type:
/usr/bin/curl --max-time 3 -u YOURUSERID:YOURPASSWORD 'http://IPNUMBER/Main_WStatus_Content.asp'
if it comes back with a lot of text (thats good) and NOT "error not authorized stuff" you should be able to make it work
Posted:
Fri Dec 09, 2016 10:17 am
by Hackencrash
Ah, OK, it looks as though my version doesn't work, but if this is specifically just for obtaining WiFi info then I'm not bothered by that since I have numerous WiFi repeaters around the place which wouldn't report their WiFi data to the plugin either.
