Triggering a message on a new IP device added.
Wed Mar 09, 2016 3:33 am
peteinau offline
I know there is a trigger when a new IP device is added, is there a way to get the details of what IP device was added in the actions?
Pete
Thu Dec 24, 2020 4:21 pm
ryanbuckner offline
Re: Triggering a message on a new IP device added.
I had this same question. There's a variable called ipDevsNewIPNumber that I think has this value. I think there used to be a way to list the device hardware etc.. but I can't remember how I did it in AppleScript.
Thu Dec 24, 2020 10:43 pm
trigger on variable "ipDevsNewDeviceNo" changed
then add executive server script w
devInfo = indigo.variables["ipDevsNewDeviceNo"].value
devName = devInfo.split(";")[1] # format is ipDevice+iPDevNumber+;+devName
dev = indigo.devices[devName]
hardware = dev.states["hardwareVendor"]
# then eg:
indigo.server.log(u"fingscan new dev:"+dev.name+u" vendor:"+ hardware)
or use variable info
varname = devInfo.split(";")[0]
indigo.server.log(u"fingscan new dev:"+ indigo.variables[varname].value)
this should work, not tested
