FINGSCAN - discussion
Mon Aug 07, 2017 7:03 am
Re: FINGSCAN - discussion
Glad it works again. It should have not done anything .. but you never know
Sat Aug 12, 2017 4:43 pm
Maty13 offline
kw123 wrote:
it tries to move
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/ls /usr/local/share/fing/bin/*
to
/usr/local/bin
and
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/fingEXE/lib/*
to
/usr/local/lib
and some more. This was implemented when Sierra started blocking the /usr/bin directories for sudo users. ( one higher than regular users) only SU user can do that now.
So we moved the fing exec modules to /usr/LOCAL/bin etc where regular users still have access.
it seems that that does not work on your MAC
are you sure that your password is correct?
could you check if the directories
/usr/local/bin/
/etc/fing/
/usr/local/lib/
/usr/local/lib/fing/
/var/data/fing/
exists?
type
to check if that directory exists
the fastest way to diagnose this would be an online scion with teamviewer. It would take me 10 minutes to find out why it does not copy the files.
I am experiencing the same problem with Fingscan and Sierra. I am hoping this has been resolved and I can apply a fix easily.
Sun Aug 13, 2017 1:11 am
Which problem do you experience?
Fri Oct 27, 2017 6:02 am
RedYuriPrime offline
Hi Karl,
Have fingscan running on my own Indigo setup fine. My son now has a very similar setup - for example sharing the same python code and differing only in that his house has sligghtly different devices.
Copied fingscan over, used the same setup parameters, and it failed. :shock:
One obvious difference is that he has a Sky router - which could mean its a different configuration for fingscan, but not sure how to tell what should be different.
Output of fingscan into the log is shown below. No devices were populated into the device folder.
Running the Fing app on an iphone works fine on the router.
Any suggestions?
Thanks, Geoff
fingscan error in Line '3425' ; error='max() arg is an empty sequence'
fingscan printWiFi: no WiFi devices defined
fingscan settings: iDevicesEnabled False
fingscan settings: inbetweenPingType sequential
fingscan settings: wifiRouter 0
fingscan settings: wait seconds between cycles 5
fingscan settings: password entered True
fingscan settings: debugLevel
fingscan settings: FINGSCAN will scan Network 192.168.0.... # of bits:8
fingscan
fingscan network: 192.168.0.0 netwType: 8 quitNow: new Network
fingscan --> while loop break stopping ... quitNOW was:new Network
Reloading plugin "fingscan 7.22.5"
Stopping plugin "fingscan 7.22.5" (pid 62748)
fingscan stopConcurrentThread called 2
fingscan stopConcurrentThread called 3
fingscan shutdown called
Stopped plugin "fingscan 7.22.5"
Starting plugin "fingscan 7.22.5" (pid 62985)
Started plugin "fingscan 7.22.5"
fingscan FINGSCAN--V 7-22-5 initializing will take ~ 2 minutes...
fingscan leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
fingscan indigo variables initialized
fingscan getting password
fingscan get password done
fingscan loaded indigo data
fingscan ifind plugin: com.corporatechameleon.iFindplugBeta
fingscan FING initializing
fingscan FING pids 3= ['']
fingscan (re)started FING
fingscan FING initialized
fingscan
fingscan
fingscan error in Line '3101' ; error='list index out of range'
Z-wave system with 80+ devices, Indigo7 on a dedicated MacMini
Controlling lighting, heating, hotwater, security; but still a lot to learn ... :shock:
Fri Oct 27, 2017 10:10 am
could you try this version 7-23-15
viewtopic.php?f=166&t=12787&p=86408#p86408
it will not create the error message (does a check on a variable) but probably does not fix the other issues.
could you check if FING is running:
open terminal and type FING
if you don't see error message then FING and then also fingscan should work..
if you do see error messages then FING is not properly installed.
let me know
Mon Dec 11, 2017 5:54 pm
Frozenman offline
Events Dont Fire
I have a new installation of Indigo plus Fingsscan. My Fingscan version is 7.24.17.
I created a test trigger that simply makes an entry in the log. I tested this first by having the event by a "Device State Changed" event. When a light went on or off, it fired.
I changed the event to a Fingscan Event for "one device home". In the Fingscan menu, I created Event 1 with 2 devices (2 iPhones), one of which is indeed home and one of which is not.
EVENT# 1                        Dev#  HomeStat HomeTime    HomeDist    AwayStat    AwayTime    AwayDist     oneHome allHome oneAway allAWay
   EVENT# 1                          1   True        61.0        False       False       540.0       True        True    True    False   False
   EVENT# 1                          2   False       23138.0     False       True        23138.0     True        True    False
If I make device #1 be away for a while (airplane mode) then come home, the device status changes as expected, the fing variables change as expected, the events are tested as expected, but the EVENT-1-onehome is not fired.
Dec 11, 2017, 6:33:45 PM
   EVENT# 1                          1   False       180.0       False       True        119.0       True        False   False   False   False
   EVENT# 1                          2   False       22717.0     False       True        22717.0     True        False   False   True    False
   EVENT# 1                        oneHome:0; allHome:0; oneAway:1; allAway:0
Dec 11, 2017, 6:34:40 PM
   EVENT# 1                          1   True        235.0       False       False       174.0       True        True    True    False   False
   EVENT# 1                          2   False       22772.0     False       True        22772.0     True        True    False   True    False
   EVENT                           triggerEvent: EVENT-1-oneHome
   EVENT                           testing trigger id : 341102134  EVENT_1_oneHome
   EVENT# 1                          1   True        6.0         False       False       180.0       True        True    True    False   False
   EVENT# 1                          2   False       22778.0     False       True        22778.0     True        True    False   True    False
   EVENT# 1                        oneHome:1; allHome:0; oneAway:1; allAway:0
I'm at a loss for what to check next.
Thanks in advance for any help.
Jay
Mon Dec 11, 2017 9:30 pm
please upgrade to 7.24.19
I changed the "-" to _ in the names and states variables etc across my plugins (*).. forgot one or 2 places.
== EVENT-1-oneHome ==> EVENT_1_oneHome
that should fix it. you might need to redefine the events / triggers
(*) in some places indigo does not like the "-" sign. So I tried to avoid it everywhere.
Tue Dec 12, 2017 8:42 am
Frozenman offline
Thanks Karl!
That did the trick..
EVENT                           testing trigger id:    341102134; eventId:EVENT_1_oneHome;  EVENT_1_oneHome
   EVENT                           firing trigger id : 341102134
   Trigger                         test
   Action Collection               My Event Has Triggered!
Jay
Wed Jan 24, 2018 7:55 pm
roquej offline
Karl,
Updated to the latest version x.21 and getting the follow error:
in Line '451' has error=''Plugin' object has no attribute 'netwType''
Suggestions?
JP
Wed Jan 24, 2018 10:40 pm
please download the plugin again. I screwed up the first upload and re loaded it. it is the same version number
Thu Jan 25, 2018 5:19 pm
roquej offline
That did it. Working now.
Thank you!
JP
Sun Jan 28, 2018 6:26 am
shapa offline
Really old issue - basically "show MSG" setting never worked. properly
Could you please fix it? :)
Screenshot 2018-01-28 12.24.12.png (40.41 KiB) Viewed 3316 times
Screenshot 2018-01-28 12.23.54.jpg (134.61 KiB) Viewed 3316 times
Sun Jan 28, 2018 2:02 pm
it checks the following before logging:
                            if "suppressChangeMSG" in dev.states:
                                if dev.states["suppressChangeMSG"] =="show":
                                    self.myLog("all",u"MAC#:"+theMAC  +" -- old IP: "+ str(props["address"])+ ";  new IP number: "+ str(self.formatiPforAddress(devI["ipNumber"]))+" to switch off changed message: edit this device and select no msg")
could you check if the device state of that device is "notShow" or "show"
if it is not show, please try to set it to "notShow". If that does not work there is a bug... otherwise "IT SHOULD WORK"
Fri Feb 02, 2018 2:55 pm
shapa offline
It's definitely configured as "not to show"
Fri Feb 02, 2018 3:17 pm
What does the device state say?
