FINGSCAN - discussion
Wed Feb 08, 2017 3:57 pm
aldera offline
Re: FINGSCAN - discussion
kw123 wrote:
I guess that's the problem.
Which os are your using?
Fingscan wants to jnstall in /usr/bin.
If that does not work ... it will fail
Using macOS Sierra, 10.12.3. There is a directory, "fing" under the "Documents" directory and there are three files, fing.data, fing.log, fingerror.log. I assume those are created when fing is run for the first time. Not a linux guy. Is fing some kind of daemon process? Can I just move some files to the correct directory or is there something else I can do to make this work? Thanks.
Edit: Just looked and found that fing appears to get installed at /usr/local/bin. It also creates a fing directory under /usr/local/lib if that helps you figure out what is going on.
Wed Feb 08, 2017 4:09 pm
it tries to move
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/ls /usr/local/share/fing/bin/*
to
/usr/local/bin
and
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/fingEXE/lib/*
to
/usr/local/lib
and some more. This was implemented when Sierra started blocking the /usr/bin directories for sudo users. ( one higher than regular users) only SU user can do that now.
So we moved the fing exec modules to /usr/LOCAL/bin etc where regular users still have access.
it seems that that does not work on your MAC
are you sure that your password is correct?
could you check if the directories
/usr/local/bin/
/etc/fing/
/usr/local/lib/
/usr/local/lib/fing/
/var/data/fing/
exists?
type
to check if that directory exists
the fastest way to diagnose this would be an online scion with teamviewer. It would take me 10 minutes to find out why it does not copy the files.
Sun Apr 23, 2017 7:50 pm
nchiles offline
Are there instructions showing how to use this plugin somewhere?
Wed Apr 26, 2017 2:54 am
petematheson offline
Just trying to re-install this on a new machine - I can't actually find the Fingscan install anywhere. The download just contains the Indigo plugin?
Wed Apr 26, 2017 3:28 am
You only need the plugin.
Double click on the plugin
Go into config
Set userid password ...
And then it should start creating devices for each ip device on your network.
You then can fine tune: loop time, if you want to use ping to confirm up.... but not needed to get startet.
Wed Apr 26, 2017 7:36 am
Ah cheers, one of the downloads still had the 'download fing' note in there !
Wed Apr 26, 2017 8:56 am
Sorry changed that some time ago. Now fing exe is included in the plugin and it will install it too.
Mon Jun 12, 2017 11:19 am
Rocco offline
Hi Karl,
I can't seem to get the long IP list in event configuration to save anything outside of the original 5 places. If I add more they seem to get truncated. Is there a trick to it that I'm missing?
Best,
Rocco
Thu Jul 13, 2017 5:01 pm
mgolden50 offline
Hi Karl,
I think I've determined that FINGSCAN will not work with the new Airport Extreme ac routers because they don't support SNMP. Is this correct? If so is there a work-around short of replacing the router?
Thanks in advance for your insights about this.
Mike
Thu Jul 13, 2017 8:47 pm
Fingscan does not use snmp
Is this the Probleme where the router constantly changes ip and mac?
Mon Jul 31, 2017 5:55 pm
roquej offline
Karl,
I am having an issues with the latest version of fingscan, v.7.22.5
The iPhones/iPads go from up to down, but never to expired.
suggestions?
JP
Mon Jul 31, 2017 9:54 pm
I am checking .. ..
checkout v -6 for a fix
Sun Aug 06, 2017 6:14 pm
roquej offline
karl,
The latest version solved the down - expired issue. However, Events are not triggered now. With debug on, the log shows:
EVENT triggerEvent: EVENT-3-allHome
But this doesn't translate to the Indigo Triggers working. It was before. Tried many times by manually triggering the event from the plugin menu and had the same behavior. Same for all events.
Suggestions?
JP
Sun Aug 06, 2017 8:18 pm
I just tried it .. and mine fires..
make sure everything is enabled.. (jn fingscan menu events, in trigger ) add a print text to log file to test ..
attached a version with a little more debugging in that section.
you should see: >>firing trigger id : # << just before the indigo trigger routine is called "indigo.trigger.execute(trigger)"
https://www.dropbox.com/s/jedqmkjyzr2oiw9/fingscan-v-7-22-7.zip?dl=1
also added: test fire events now 1...12 (up from 1...5)
and fixed a bug I came across adding code in the last version
I will be out tomorrow noon for 3+ weeks with little access to indigo (son's wedding in Hungary = no indigo allowed .. )
if I get anything back before, I can try fixing..
log file output should look like:
21:28:41 EVENT       -triggerEvent: EVENT-12-allHome
21:28:41 EVENT       -testing trigger id : 1423847604  EVENT-1-allAway
21:28:41 EVENT       -testing trigger id : 138456350  badWiFi
21:28:41 EVENT       -testing trigger id : 1174867687  EVENT-1-oneHome
21:28:41 EVENT       -testing trigger id : 395786349  IPNumberChanged
21:28:41 EVENT       -testing trigger id : 1247784583  NewDeviceOnNetwork
21:28:41 EVENT       -testing trigger id : 1461827517  EVENT-2-allAway
21:28:41 EVENT       -testing trigger id : 835070741  EVENT-2-allHome
21:28:41 EVENT       -testing trigger id : 1652526187  EVENT-12-allHome
21:28:41 EVENT       -firing trigger id : 1652526187
and the action shows:
  Trigger                         test fingscan
   fing                            home
Mon Aug 07, 2017 3:50 am
roquej offline
As soon as I loaded your test version, triggers started working again....just loaded it with no other change.
Maybe that bug you fixed took care of the issue?
JP
