Event resetting
Tue Oct 20, 2020 3:25 pm
MartinG offline
Re: Event resetting
Plugin config as requested
Screenshot 2020-10-20 at 22.24.46.png (211.69 KiB) Viewed 2536 times
Tue Oct 20, 2020 3:56 pm
Re: Event resetting
Could you finish a the selections ie set BC on or off?
Tue Oct 20, 2020 4:39 pm
MartinG offline
Re: Event resetting
Done - enabled for all. Will post what happens next....
Tue Oct 20, 2020 11:54 pm
MartinG offline
Re: Event resetting
Good news - setting 'Enable BC of up/down status' to 'Enable All' seems to have solved the disappearing EVENT definitions. This is without me upgrading to v .60.
The plugin is still restarting at 00:19:00 though.
Wed Oct 21, 2020 7:03 am
Re: Event resetting
Ok I will fix this. The property was not set = undefined
You do not to need to enable that function
You can disable it.
Fri Oct 23, 2020 1:57 am
MartinG offline
Re: Event resetting
Karl,
Thanks for the responsiveness and updates. Having updated everything to the latest versions, I'm pleased to report that the event definitions remain persistent.
The plugin is still restarting every night at the same time, but it's not causing me any problems. Happy to help you debug this if you want - just let me know what data you need.
Martin
Fri Oct 23, 2020 4:43 am
Re: Event resetting
The restart is part of the design.
Sat Oct 24, 2020 8:39 am
MartinG offline
Re: Event resetting
Also this indicates a real problem:
2020-10-19 00:19:03.848 ERROR Plugin.dorunConcurrentThread --> setup config, save, then a manual reload of plugin
2020-10-19 00:19:03 --> while loop break stopping ... quitNOW was: please setup config , waiting
2020-10-19 00:19:03.854 ERROR Plugin.dorunConcurrentThread --> you have 2 minutes to fix config, before restart
2020-10-19 00:19:03.855 ERROR Plugin.dorunConcurrentThread --> do a manual reload of plugin
The plugin does not start properly.
2020-10-20 00:19:05.464 ERROR Plugin.dorunConcurrentThread --> setup config, save, then a manual reload of plugin
2020-10-20 00:19:05 --> while loop break stopping ... quitNOW was: please setup config , waiting
2020-10-20 00:19:05.465 ERROR Plugin.dorunConcurrentThread --> you have 2 minutes to fix config, before restart
2020-10-20 00:19:05.465 ERROR Plugin.dorunConcurrentThread --> do a manual reload of plugin
indicates the the plugin is not happy. something is wrong:
>>> setup config, save, then a manual reload of plugin<<<
indicates the plugin is not setup correctly, something is missing
but there is still a problem that the plugin just restarts, reason unclear.
2020-10-24 00:19:04.545   ERROR          Plugin.dorunConcurrentThread     -->  setup config, save, then a manual reload of plugin
2020-10-24 00:19:04 --> while loop break  stopping ...  quitNOW was: please setup config , waiting
2020-10-24 00:19:04.562   ERROR          Plugin.dorunConcurrentThread     --> you have 2 minutes to fix config, before restart
2020-10-24 00:19:04.562   ERROR          Plugin.dorunConcurrentThread     --> do a manual reload of plugin
OK. :D
Just let me know if you'd like more data. You've solved my problem, so I'd be very happy to help in return.
