Error in v2022.36.91
Mon Sep 26, 2022 12:27 pm
thumpinc offline
Hi - Thanks again for the plugin. The errors my setup was having with previous version .90 continue. The plugin reloads over and over again.
Log is below. Thanks for taking a look.
fingscan Initializing .. FING created new data waiting ~ 1 minute for stable operation
fingscan .. (re)started FING, initialized
fingscan
fingscan
EVENT defs:::::::::::::::::: Start :::::::::::::::: -- all
EVENT defs:::::::::::::::::: END ::::::::::::::::::
fingscan getting vendor info..
fingscan --> while loop break stopping ... quitNOW was: Indigo variable error 8
Reloading plugin "fingscan 2022.37.91" using API v3.0.0
Stopping plugin "fingscan 2022.37.91" (pid 3292)
fingscan Warning stopConcurrentThread called 2
fingscan runConcurrentThread stopping plugin due to: ::::: no :::::
Plugin restart request ignored (plugin is currently stopping or starting)
fingscan killing 2
Stopped plugin "fingscan 2022.37.91"
Starting plugin "fingscan 2022.37.91" (pid 3530)
fingscan initializing ...
fingscan path To files: =================
fingscan detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.fingscan/plugin.log
fingscan testing logging levels, for info only:
fingscan logger enabled for INFO ==> TEST ONLY
fingscan Warning logger enabled for WARNING ==> TEST ONLY
fingscan Error logger enabled for ERROR ==> TEST ONLY
fingscan Error logger enabled for CRITICAL ==> TEST ONLY
fingscan using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
Started plugin "fingscan 2022.37.91"
fingscan testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
fingscan debug settings :['all']
fingscan FINGSCAN-- initializing will take ~ 2 minutes..
fingscan indigo variables initialized
fingscan network info: {'netMask': '255.255.255.0', 'netWorkId': '192.168.86.1', 'broadcast': '192.168.86.255', 'hostRange': '192.168.86.1 - 192.168.86.254', 'maxHosts': 254}, netwType:24
fingscan getting password
fingscan get password done; checking if FING is installed
fingscan Warning new dev#: newIPDevNumber:A52<< devV[ipDevice]:03<<
fingscan loaded indigo data
fingscan Warning getting data from indigo: bad variable ipDevice03 does not have a valid IP number>>192.168.86.237-changed<<\ deleting and letting the program recreate it
fingscan Initializing parameters for FING
fingscan Waiting for first data from FING
fingscan
fingscan
Stopping plugin "fingscan 2022.37.91" (pid 3530)
fingscan killing 2
Starting plugin "fingscan 2022.37.91" (pid 3777)
