Problems with Fing on Catalina
Tue Jan 14, 2020 9:19 am
vtmikel offline
I posted about this last night. I had a previous version of your plugin working fine under Catalina. I had to approve all of the security exceptions, etc.
Upon upgrading, I got an error about the os not being defined. I installed the included pkg for the latest copy of Fing. I'm stuck in this loop:
Jan 14, 2020 at 10:13:00 AM
   Enabling plugin "fingscan 7.31.48"
   Starting plugin "fingscan 7.31.48" (pid 1264)
   fingscan                        =========================   initializing   ==============================================
   fingscan                        path To files:          ==================
   fingscan                        indigo                  /Library/Application Support/Perceptive Automation/
   fingscan                        installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.4/
   fingscan                        plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/
   fingscan                        Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/
   fingscan                        !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
   fingscan Warning                !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
   fingscan Error                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
   fingscan Critical Error         !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
   fingscan                        check                   /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log  <<<<    for detailed logging
   fingscan                        Plugin short Name       fing
   fingscan                        my PID                  1264
   fingscan                        set params for indigo V 7.4
   Started plugin "fingscan 7.31.48"
   fingscan                        testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   fingscan                        myLogSet setting parameters -- logFileActive= standard; logFile= ;  debug plugin:[]
   fingscan                        FINGSCAN--   initializing     will take ~ 2 minutes...; sending logs to
   fingscan Warning                leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
   fingscan                        getting password
   fingscan                        get password done;  checking if FING is installed
   fingscan                        fing install check done
   fingscan                        loaded indigo data
   fingscan                        network info: {'netWorkId': '10.66.0.0', 'broadcast': '10.66.0.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '10.66.0.1 - 10.66.0.254'}
   fingscan                        ifind plugin: com.corporatechameleon.iFindplugBeta
   fingscan                        MAP2Vendor initializing
   fingscan                        FING initializing parameters
   fingscan                        FING waiting for first data
Jan 14, 2020 at 10:13:29 AM
   Z-Wave                          received "Basement Stairway Luminance" sensor update to 0 lux
   Z-Wave                          received "Basement Stairway Humidity" sensor update to 23%
   Z-Wave                          received "Basement Stairway Temperature" sensor update to 61.7 °F
   fingscan                        FING initializing checking if output created, old timeStamp:1578967034.8; new timeStamp:1578967034.8
Jan 14, 2020 at 10:13:50 AM
   Schedule                        Turn on lights in Foyer when motion at the Front Door (delayed action)
   Action Collection Error         Insert Timestamp into Variable: action references variable that no longer exists
Jan 14, 2020 at 10:14:10 AM
Jan 14, 2020 at 10:14:30 AM
   Z-Wave                          received "Master Bedroom Temperature" sensor update to 58.7 °F
   Z-Wave                          received "Master Bedroom Humidity" sensor update to 57%
   Z-Wave                          received "Master Bedroom Luminance" sensor update to 174 lux
   Z-Wave                          received "Master Bedroom Ultraviolet" sensor update to 0
   Script                          auto_lights script for Zone 'Downstairs Entryway', zone has been changed outside of the auto_lights script.  Devices: [Foyer Light].  Current State: [0], Previous State: [100], zone is locked for 15 minutes (until 2020-01-14 10:29:35)
   Z-Wave                          received "013 - Master Bedroom Motion Sensor" status update battery level 100%
   Z-Wave                          received "Front Porch Luminance" sensor update to 6502 lux
   fingscan                        FING initialized .. data file not created, return
   fingscan Error                   fing not running... quit
