- Posted on
Fri Sep 09, 2022 3:14 pm
VincentS
offline
Just this..
2022-09-09 20:47:14 initializing ...
2022-09-09 20:47:14 path To files: =================
2022-09-09 20:47:14 indigo /Library/Application Support/Perceptive Automation/
2022-09-09 20:47:14 installFolder /Library/Application Support/Perceptive Automation/Indigo 2022.1/
2022-09-09 20:47:14 plugin.py /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/INDIGOplotD.indigoPlugin/Contents/Server Plugin/
2022-09-09 20:47:14 detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.INDIGOplotD/plugin.log
2022-09-09 20:47:14 testing logging levels, for info only:
2022-09-09 20:47:14 logger enabled for THREADDEBUG ==> TEST ONLY
2022-09-09 20:47:14 logger enabled for DEBUG ==> TEST ONLY
2022-09-09 20:47:14 logger enabled for INFO ==> TEST ONLY
2022-09-09 20:47:14 logger enabled for WARNING ==> TEST ONLY
2022-09-09 20:47:14.669 ERROR Plugin.__init__ logger enabled for ERROR ==> TEST ONLY
2022-09-09 20:47:14.669 CRITICAL Plugin.__init__ logger enabled for CRITICAL ==> TEST ONLY
2022-09-09 20:47:14 Plugin short Name INDIGOplotD
2022-09-09 20:47:14 my PID 5000
2022-09-09 20:47:14 Achitecture macOS-10.15.7-x86_64-i386-64bit
2022-09-09 20:47:14 OS 10.15.7
2022-09-09 20:47:14 indigo V 2022.1.2
2022-09-09 20:47:14 python V 3.10.2
2022-09-09 20:47:14 using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
2022-09-09 20:47:15 initializing ... ; debuglevel=[], apiversion:3.1
2022-09-09 20:47:15 number of days per bin category are: [8, 38, 390] for [days, hours, minutes] data
2022-09-09 20:47:15.057 CRITICAL Plugin.startup Fatal error could not create indigoplot PNG file Directory
indigoMPplot 2022-09-09 20:48:09.827977 ---- INDIGO matplot started Version 6.8; pid:5031; sys.version_info(major=3, minor=10, micro=2, releaselevel='final', serial=0) ------
2022-09-09 20:53:19 command: InstallGnuplot
2022-09-09 20:53:55 command: debug OFF
2022-09-09 20:55:26.226 ERROR Plugin.pickExistingOrNewDeviceCALLBACK 'Plugin' object has no attribute 'oldDevNo'line#,Module,Statement:(6040, 'pickExistingOrNewDeviceCALLBACK', 'if devNo ==\tself.oldDevNo:')
2022-09-09 20:55:45.725 ERROR Plugin.pickExistingOrNewDeviceCALLBACK 'Plugin' object has no attribute 'oldDevNo'line#,Module,Statement:(6040, 'pickExistingOrNewDeviceCALLBACK', 'if devNo ==\tself.oldDevNo:')
2022-09-09 20:55:52.578 ERROR Plugin.pickExistingOrNewDeviceCALLBACK 'Plugin' object has no attribute 'oldDevNo'line#,Module,Statement:(6040, 'pickExistingOrNewDeviceCALLBACK', 'if devNo ==\tself.oldDevNo:')
2022-09-09 20:57:01.793 ERROR Plugin.startMAT 'Plugin' object has no attribute 'PLOT'line#,Module,Statement:(9494, 'plotNow', 'for nPlot in self.PLOT:')
2022-09-09 20:57:01 command: switch to MATPLOT
indigoMPplot 2022-09-09 20:57:05.976583 ---- INDIGO matplot started Version 6.8; pid:5497; sys.version_info(major=3, minor=10, micro=2, releaselevel='final', serial=0) ------
2022-09-09 20:57:15 command: switch to GNUPLOT
2022-09-09 20:57:37 stop_concurrent_thread called
2022-09-09 21:08:01 initializing ...
2022-09-09 21:08:01 path To files: =================
2022-09-09 21:08:01 indigo /Library/Application Support/Perceptive Automation/
2022-09-09 21:08:01 installFolder /Library/Application Support/Perceptive Automation/Indigo 2022.1/
2022-09-09 21:08:01 plugin.py /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/INDIGOplotD.indigoPlugin/Contents/Server Plugin/
2022-09-09 21:08:01 detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.INDIGOplotD/plugin.log
2022-09-09 21:08:01 testing logging levels, for info only:
2022-09-09 21:08:01 logger enabled for THREADDEBUG ==> TEST ONLY
2022-09-09 21:08:01 logger enabled for DEBUG ==> TEST ONLY
2022-09-09 21:08:01 logger enabled for INFO ==> TEST ONLY
2022-09-09 21:08:01 logger enabled for WARNING ==> TEST ONLY
2022-09-09 21:08:01.844 ERROR Plugin.__init__ logger enabled for ERROR ==> TEST ONLY
2022-09-09 21:08:01.844 CRITICAL Plugin.__init__ logger enabled for CRITICAL ==> TEST ONLY
2022-09-09 21:08:01 Plugin short Name INDIGOplotD
2022-09-09 21:08:01 my PID 6069
2022-09-09 21:08:01 Achitecture macOS-10.15.7-x86_64-i386-64bit
2022-09-09 21:08:01 OS 10.15.7
2022-09-09 21:08:01 indigo V 2022.1.2
2022-09-09 21:08:01 python V 3.10.2
2022-09-09 21:08:01 using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
2022-09-09 21:08:01 initializing ... ; debuglevel=[], apiversion:3.1
2022-09-09 21:08:01 number of days per bin category are: [8, 38, 390] for [days, hours, minutes] data
2022-09-09 21:08:01.923 CRITICAL Plugin.startup Fatal error could not create indigoplot PNG file Directory
2022-09-09 21:15:14 stop_concurrent_thread called
