Page 1 of 2
after moving to new mac plots doe not show data
Posted:
Sat Aug 11, 2018 2:47 pm
by superholz
After moving my indigo installation to a new mac indigoPlotD seems to run but the plot files that are created show no data and the log shows:
/Users/Rabe/Documents/INDIGOplotD/gnu/TemperaturePlotII-minute-S1.gnu has no lines defined -- dont forget to click CONFIRM before you save the lines and plots, ignore this warning if just created
This type of message is shown for all the plots I made earlier.
Also in the select/define data menu I don't see any variables. It seems to me that indigoPlotD cannot find the definitions for the variables somehow. Did I miss to copy some files? Do I have to point indigoPlotD to the data somehow?
The path fort the indigo installation stayed the same for old and new machine except the HD name is different.
Re: after moving to new mac plots doe not show data
Posted:
Sat Aug 11, 2018 3:20 pm
by kw123
do you have a directory ~/indigo/indigoplotd?
THAT directory has to be copied. All defs are in there
if anything is missing do
/menu/select config to restore
after you copied the directory.
Posted:
Sat Aug 11, 2018 3:27 pm
by superholz
Thank you for the quick response!
I have the indigoPlotD directory in the Documents directory where also the indigo database file is. But I do not have the parent directory Indigo. I think I never had it. It is necessary?
And Yes I copied the whole directory from the old installation.
Posted:
Sat Aug 11, 2018 3:40 pm
by superholz
Seem that I (actualy more you) solved it. I checked the IndigoPlotD directory and not all files where there from the old install. It could be that the transfer was interrupted and I did not realize.
Thanks, looks good now.
Posted:
Sat Aug 11, 2018 5:28 pm
by kw123
in newer OSX the ~/documents directory gets synced through iCloud with other MACs. Hence I moved the directory to ~/indigo to avoid heavy traffic to iCloud .
Posted:
Mon Aug 27, 2018 1:22 pm
by bsp9493
Hi Karl...
similar problem here.
ended up doing a new install of indigo,
anyhow...
got my whole installation working again with the exception of plotD.
copied the ~/indigo/INDIGOplotd/ folder over to exact location on new computer, did the restore configuration as noted, but I am ending up with the following error when it tries to restart.
- Code: Select all
INDIGOplotD Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 8835, in runConcurrentThread
File "plugin.py", line 6479, in checkIfEventData
AttributeError: 'Plugin' object has no attribute 'DEVICE'
INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
i turned debug on to see if there was anything else, but it looks like the restore worked (no errors other than this one when it restarts)
as always, your help would be appreciated.
Thanx
dave
Posted:
Mon Aug 27, 2018 11:43 pm
by kw123
I have likely no time to check for the next 2 days. Will try to look into it on Thursday.
just a quick check. This can not be the first error message. "self.DEVICE" is defined very early in in startup. It can only be not defined if the startup processes fail...
Posted:
Tue Aug 28, 2018 11:37 am
by bsp9493
no worries, let me know.
yes, that is the only error message.
process used below.
clean install of indigo.
install plugin from scratch - like new.
no issues, all works as expected.
go to plugin
enable
import configuration, then all the problems start
you know what... further look at things and yes, there is another error message... seems to be a permission error accessing the sqlcmd.log
that's strange. I have had a few weird permissions things going on since I reinstalled the OS and indigo. hmmmm
any ideas?
- Code: Select all
Aug 28, 2018 at 10:33:38 AM
Enabling plugin "INDIGOplotD 4.18.48"
Starting plugin "INDIGOplotD 4.18.48" (pid 24743)
Started plugin "INDIGOplotD 4.18.48"
INDIGOplotD indigo version found: 7
INDIGOplotD number of days per bin category are: [8, 38, 390] for [days, hours, minutes] data
INDIGOplotD using '/usr/bin/python2.7' for utily programs
INDIGOplotD Error Error in plugin execution startup:
File "plugin.py", line 517, in startup
File "plugin.py", line 943, in clearFlags
OSError: (13, 'Permission denied', '/Users/davidmorhun/indigo/INDIGOplotD/sql/sqlcmd.log')
Posted:
Tue Aug 28, 2018 12:33 pm
by bsp9493
Hey Karl...
yes, the noted permissions error was causing my grief.
Somehow during the process my new install of OSX and indigo created a bunch of permissions errors with my Home drive.
once I was able to correct that, all is now well.
Sorry for the false alarm.
For reference, this is how I corrected the problem in case anyone else runs into this.
https://support.apple.com/en-ca/HT203538as always ... Love the PlugIn
Thanx
d
Posted:
Tue Aug 28, 2018 5:29 pm
by bsp9493
maybe spoke too soon...
I get this error after restarting plugin.
- Code: Select all
Reloading plugin "INDIGOplotD 4.18.48"
Stopping plugin "INDIGOplotD 4.18.48" (pid 2226)
INDIGOplotD ------------------------------------------------------------------------------
INDIGOplotD Line '9110' has error='None'
INDIGOplotD main loop stopped
Error DeleteOrigAndSwapInTemp() caught exception: FileIOError -- failed to delete original file
Stopped plugin "INDIGOplotD 4.18.48"
Starting plugin "INDIGOplotD 4.18.48" (pid 9883)
also noticing plots are not updating... and seeing this repeatedly
- Code: Select all
Aug 28, 2018 at 4:12:51 PM
INDIGOplotD restarting SQL import, it seems to hang. If this happens several times reload INDIGOplotD :
Posted:
Wed Aug 29, 2018 12:25 am
by kw123
- Code: Select all
Line '9110'
is
- Code: Select all
self.sleep(1)
.. don't understand how that could throw an error.
when you get the message
- Code: Select all
you might have the sql import string wrong, set it in config .
switch on sql import debug. check the sql command used.
also check ~indigo/indiplotd/sql/. for log files and data produced during sql import
Posted:
Wed Aug 29, 2018 9:45 am
by bsp9493
Thanx Karl...
found it - my bad
actually a couple things.
Looks like I reinstalled a different version of sql app so yes, the sql import string didn't match
also still had a few file permission errors on plugin config files - no access to write updated config info when I hit save (still don't understand how that happened, but it's fixed now)
appreciate your help and the great work on the plugin.
dave
Posted:
Thu Oct 11, 2018 9:05 pm
by hamw
FWIW after installing the new Postgres and the new version of IndigoPlotD for 7.2, I have totally lost all my plots. Blank. Getting this repeated error:
- Code: Select all
Oct 11, 2018, 10:57:03 PM
INDIGOplotD plotting GNUPLOT error/warning for /Users/hamiltonwilliams/indigo/INDIGOplotD/gnu/Plot_Temp_Hum_Attic-minute-S1
INDIGOplotD
plot ,
"/Users/hamiltonwilliams/indigo/INDIGOplotD/gnu/Plot_Temp_Hum_Attic-minute-S1.gnu", line 34: invalid expression
INDIGOplotD plotting GNUPLOT error/warning for /Users/hamiltonwilliams/indigo/INDIGOplotD/gnu/Plot_Temp_Hum_Attic-hour-S1
INDIGOplotD
plot ,
"/Users/hamiltonwilliams/indigo/INDIGOplotD/gnu/Plot_Temp_Hum_Attic-hour-S1.gnu", line 34: invalid expression
INDIGOplotD plotting GNUPLOT error/warning for /Users/hamiltonwilliams/indigo/INDIGOplotD/gnu/Plot_Temp_Hum_Attic-day-S1
INDIGOplotD
plot ,
IndigoPlot path here: /usr/local/bin/gnuplot
plots here: /Users/hamiltonwilliams/Documents/INDIGOplotD/
postgres command string here: /Applications/Postgres.app/Contents/Versions/9.6/bin/psql indigo_history postgres
Limited Debug:
- Code: Select all
Reloading plugin "INDIGOplotD 4.18.49"
Stopping plugin "INDIGOplotD 4.18.49" (pid 78573)
Stopped plugin "INDIGOplotD 4.18.49"
Starting plugin "INDIGOplotD 4.18.49" (pid 78958)
Started plugin "INDIGOplotD 4.18.49"
INDIGOplotD SQLMode: batch; GNUPLOT/MATPLOT: gnu; GNUplotVersion= 5.0; PLOT-Directory= /Users/hamiltonwilliams/Documents/INDIGOplotD/
INDIGOplotD dataversion 2 dataOffsetInTimeDataNumbers:5
INDIGOplotD read file /Users/hamiltonwilliams/indigo/INDIGOplotD/data/minute.dat lines: 2304 ok
INDIGOplotD read file /Users/hamiltonwilliams/indigo/INDIGOplotD/data/hour.dat lines: 912 ok
INDIGOplotD read file /Users/hamiltonwilliams/indigo/INDIGOplotD/data/day.dat lines: 390 ok
INDIGOplotD sql logger used 8.85 secs CPU so far
INDIGOplotD wait for SQL logger to finish start up -- before retrieving SQL data
INDIGOplotD sql logger used 8.98 secs CPU so far
INDIGOplotD wait for SQL logger ended
INDIGOplotD checking py-restore files
INDIGOplotD initializing ...2
INDIGOplotD not configured yet, please select menue: Indigo /plugins/INDIGOplotD/Configure...
INDIGOplotD initialized
Debug says it is not configured yet. Could it have lost all my devices and plots somehow?
Full Debug:
- Code: Select all
Stopping plugin "INDIGOplotD 4.18.49" (pid 78958)
INDIGOplotD could not read matplotPID file
INDIGOplotD stop matplot: not active, PID: x
Starting plugin "INDIGOplotD 4.18.49" (pid 79076)
INDIGOplotD initializing ... ; debuglevel=Restore,General,Initialize,Plotting,SQL,special,all
INDIGOplotD sqlDynamic batch
INDIGOplotD clearing plot flags
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Pool_Temp id:1138786092
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Pool_Temp id1138786092 fname:Plot_Pool_Temp
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Temp_Hum_Apt id:1861407002
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Temp_Hum_Apt id1861407002 fname:Plot_Temp_Hum_Apt
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Temp_Hum_Attic id:378635821
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Temp_Hum_Attic id378635821 fname:Plot_Temp_Hum_Attic
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Temp_Hum_Fam_Rm_Crawl_Space id:32335221
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Temp_Hum_Fam_Rm_Crawl_Space id32335221 fname:Plot_Temp_Hum_Fam_Rm_Crawl_Space
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Temp_Hum_Game_Rm_Crawl_Space id:828854081
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Temp_Hum_Game_Rm_Crawl_Space id828854081 fname:Plot_Temp_Hum_Game_Rm_Crawl_Space
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Temp_Hum_Main_House_Crawl_Space id:95146107
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Temp_Hum_Main_House_Crawl_Space id95146107 fname:Plot_Temp_Hum_Main_House_Crawl_Space
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Temp_Hum_Pantry_Wine id:619668618
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Temp_Hum_Pantry_Wine id619668618 fname:Plot_Temp_Hum_Pantry_Wine
INDIGOplotD syncPlotsWithIndigo copying PLOT using Plot_Temp_Hum_Pool_House id:1428247593
INDIGOplotD syncPlotsWithIndigo found new PLOT ... syncing 2 Plot_Temp_Hum_Pool_House id1428247593 fname:Plot_Temp_Hum_Pool_House
INDIGOplotD initgnu syncPlotsWithIndigo
INDIGOplotD PLOT: Plot_Pool_Temp
INDIGOplotD ss: 0 TTI: 0
INDIGOplotD ncols: 0
INDIGOplotD lines: ['plot \\\n']
INDIGOplotD ss: 0 TTI: 1
INDIGOplotD ss: 0 TTI: 2
INDIGOplotD PLOT: Plot_Temp_Hum_Attic
INDIGOplotD PLOT: Plot_Temp_Hum_Fam_Rm_Crawl_Space
INDIGOplotD PLOT: Plot_Temp_Hum_Pantry_Wine
INDIGOplotD PLOT: Plot_Temp_Hum_Apt
INDIGOplotD PLOT: Plot_Temp_Hum_Pool_House
INDIGOplotD PLOT: Plot_Temp_Hum_Main_House_Crawl_Space
INDIGOplotD PLOT: Plot_Temp_Hum_Game_Rm_Crawl_Space
INDIGOplotD redolineDataSource called from : startup
INDIGOplotD redolineDataSource: listOfSelectedDataColumnsAndDevPropName[(0, 'None')] calledfrom :startup
INDIGOplotD sql logger used 11.41 secs CPU so far
INDIGOplotD Updating device/prop from SQL db: no device or variable defined.. skipping updates ...
INDIGOplotD redolineDataSource called from : cleanData
INDIGOplotD redolineDataSource: listOfSelectedDataColumnsAndDevPropName[(0, 'None')] calledfrom :cleanData
INDIGOplotD initgnu runConcurrentThread1
Ham
Posted:
Thu Oct 11, 2018 9:56 pm
by kw123
it looks as if all config is lost.
do you have files like:
/Users/hamiltonwilliams/indigo/INDIGOplotD/py/RestoreConfigAndPlots-20181011-001604.py
you can restore everything (almost) by running them in menu/select config to restore
select a recent file (date stamp in name) and run it
if it still gives errors, do a reset (last item in menu) and then repeat above restore
Posted:
Fri Oct 12, 2018 8:31 pm
by hamw
Karl, tried both approaches and no joy. Part of it may be that I did not realize the plot problem initially and then did not look into it for several days. The restore files go back 3 days or so... more than enough time but in my case these backups preserved the new, broken state. I can recreate them.... just a bit of a pain. Any idea why the devices/data sources would have disappeared following the upgrade to 7.2?
