importing historical data
Posted: Fri Mar 02, 2018 6:00 pm
Thought I had everything figured out once I switched to Postgres app for sql logger.
When in look in my indigo_history db, I see there is historical data for the item I am plotting
INDIGOplotD does not seem to want to import the historical stuff from the sql logger though:(
currently using
- postgres app - for sql logger
- updated the "postgre command string" in the plugin config to the following...
"/Applications/Postgres.app/Contents/Versions/10/bin/psql" -p5432 -d "indigo_history"
(which appears to be valid as that is what is working in the Utilities plugin -- when I query the db with Utilities plugin - I can see my historical data)
Do I have the wrong command string?
I have seen a few threads related to this but unable to find a solution.
Your help is appreciated.
Thanx
d
sql debug below
INDIGOplotD pending indigoCommands: ['ReloadSQL']
INDIGOplotD clearSqlData sqlupdates: [0, 0]
INDIGOplotD command: reLoad SQL started
INDIGOplotD setupSQLDataBatch 2 updateslist:[0, 49]
INDIGOplotD sql importfile file not created yet, resetting import parameters: /Users/david/indigo/INDIGOplotD/sql/1978589258-ambient_temperature_c
INDIGOplotD sqlID ==0, delete col:1 sql/1978589258-ambient_temperature_c
INDIGOplotD "/Applications/Postgres.app/Contents/Versions/10/bin/psql" -p5432 -d "indigo_history" -t -A -F ';' -c " SELECT id, to_char(ts,'YYYYmmddHH24MIss'), ambient_temperature_c from device_history_1978589258 WHERE ambient_temperature_c IS NOT NULL AND ID > 0 order by id LIMIT 10000000;" 2>/Users/david/indigo/INDIGOplotD/sql/1978589258-ambient_temperature_c.error | awk -F';' 'NF>2 && !/data unavailable/ {print}' > /Users/david/indigo/INDIGOplotD/sql/1978589258-ambient_temperature_c.sqlOut
/usr/bin/python2.7 '/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/INDIGOplotD.indigoPlugin/Contents/Server Plugin/fixSQLoutput.py' {"fileDir": "/Users/david/indigo/INDIGOplotD/sql/", "startID": "0", "outputFile": "1978589258-ambient_temperature_c", "logFile": "sqlFix", "inputFile": "1978589258-ambient_temperature_c.sqlout"}
INDIGOplotD sql command for col:1 name-state:nthermostat main-ambient_temperature_c starting at record: 0 added; last existing record is: no SQL file generated yet
INDIGOplotD sql commands launched sqlID anythingToupdates 0 1
INDIGOplotD sql commands launched 2018-03-02 15:51:06.667059 waiting for SQL tasks to end to read data into INDIGOplotD pid=2130
INDIGOplotD readSQLdataBatch calledfrom ...runConcurrentThread sqlHistListStatus[0, 10]
INDIGOplotD ...runConcurrentThread sqlColListStatus [0, 5]
INDIGOplotD sql file if done, now reading it 2 [0, 10]
INDIGOplotD theCol:1; updatesALL:True; sqlDynamic:batch; sqlHistListStatus:[0, 10]
INDIGOplotD Convert no records found, try later 1
INDIGOplotD Convert no records found, try later 2
INDIGOplotD SQL import 2018-03-02 15:51:07.774958 ... sqlColListStatus: [0, 0]
INDIGOplotD ...runConcurrentThread sqlColListStatus [0, 0]
INDIGOplotD sql file if done, now reading it 0 [0, 10]
INDIGOplotD SQL import 2018-03-02 15:51:09.962158 ... sqlColListStatus: [0, 0]
currently using
Thanx
d
sql debug below
