problem when creating a device
Posted: Wed Feb 28, 2018 12:36 pm
Hi...
Love this plugin... it has some real potential for me and I'm sure others.
Question...
I have looked through the 1st steps and am having a couple problems and would appreciate your input.
background
mac mini el capitan
current versions of:
Indigo 7
sqlite
gnu plot
looked for an answer, but couldn't find a solution
reviewing INDIGOplotD - 1st steps
trying to plot temps from 3 thermostats in system
from plugin
- print variable states for eligibility to ensure I am using valid items
Step 1 define data to be tracked for plotting
no issue
i am able to select the 3 valid devices that I want, confirm them, and then select the state I want to graph
Step 2
from indigo, create a new device, fill it in as in your example, and hit confirm
no issue
Step 3
add the lines that I want to plot
I have again checked vs your screenshot to ensure my settings are the same
modify or add line
datasource for this line
- i see the datasource i want (1 of 3) but when I select it, the field just blanks out and I cannot ADD any lines to my graph?
This seems like it should be so simple to use. I have checked logs and can not see any glaring errors, data appears to be available via sql. Not sure what I am missing, or what is NOT set up correctly?
Your help would be appreciated.
Thanx
Dave
Question...
background
mac mini el capitan
Indigo 7
sqlite
gnu plot
from plugin
no issue
Step 2
no issue
Step 3
modify or add line
Thanx
Dave
