INDIGOplotD Error in plugin execution runConcurrentThread
Posted: Sat Jan 20, 2018 6:40 am
When I try to initialise the IndigoPlotD plugin, I get the message shown below in the log.
I am running latest 4.16.28 against latest Indigo 7.1.1.
I have tried different recent versions of PlotD to no avail.
I'm unable to change any of the settings of PlotD - like to turn the debugging on - because any attempt to save the config gives an error "Error validating fields - hover over the field in RED" - but there is no field in RED displayed.
When I press "save" on the config dialog I get the message:
Error in pluigin execution UiValidate
plugin.py line 8066 validatePrefsConfigUi
KeyError: key showExpertParameters Not Found in dict
Any ideas?
2018-01-20 00:00:01.823 Z-Wave received "023 Zwift - Smart Energy Appliance Module (TZ88E)" power load to 6.6 W
2018-01-20 00:00:03.995 Z-Wave received "026 Loft Rack Master - TZ88E" power load to 846.7 W
2018-01-20 00:00:04.118 INDIGOplotD Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 8726, in runConcurrentThread
File "plugin.py", line 6396, in checkIfEventData
AttributeError: 'Plugin' object has no attribute 'DEVICE'
2018-01-20 00:00:04.120 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2018-01-20 00:00:04.598 Z-Wave received "026 Loft Rack Master - TZ88E" power load to 831.9 W
2018-01-20 00:00:04.969 Z-Wave received "035 - Compressor (TZ88E)" power load to 0.1 W
Any ideas?
