Error Message
Posted:
Mon Sep 04, 2017 12:55 pm
by bkmar1192
I keep getting the following error on the second data line added.
- Code: Select all
File "plugin.py", line 6386, in buttonConfirmDeviceStatesCALLBACK
KeyError: ('2',)
Can't get past it.
Re: Error Message
Posted:
Tue Sep 05, 2017 9:58 am
by kw123
could you try this version. I added some debug statements and some error catching.
when you select a new / existing device you MUST click on CONFIRM first
anyway please try this one
https://www.dropbox.com/s/p625btnmyqcyfa2/INDIGOplotD-v-4-16-23.zip?dl=1
Re: Error Message
Posted:
Tue Sep 05, 2017 1:36 pm
by bkmar1192
I'll try tonight. The sequence was : create first field - no problem. Select the add field for my second field, select the device/variable, click on confirm, select the value to record and configure, click on the second confirm button - error message.
Saving the device only saves the first entry.
Re: Error Message
Posted:
Thu Sep 07, 2017 6:51 pm
by kw123
I am sorry which menu are you in?
-define/select data sources
-simple plot
- create plot
Re: Error Message IndigoPlotD
Posted:
Sat Sep 09, 2017 12:23 pm
by bkmar1192
No change with new version
In the menu "Define/Select Data Sources":
create my first data source
1. click on add new data source
2. Select variable
3. click on confirm
4. State = "Value"
5. Measure = "Sum"
6. reset = " daily"
7. nickname = "Heat Duration"
8. confirm
--- data point is saved
Create my second data source
2. Select variable
3. click on confirm
4. State = "Value"
5. Measure = "Sum"
6. reset = " daily"
7. nickname = "AC Duration"
8. confirm
--- data point is not saved
--- the status field at the top of data configuration says "E: DEVICE not selected"
Re: Error Message
Posted:
Sat Sep 09, 2017 2:21 pm
by bkmar1192
I seemed to have gotten it to work finally. Not sure what I did though just saved the plugin configuration a couple of times and it finally started working...
Re: Error Message
Posted:
Sat Sep 09, 2017 2:49 pm
by kw123
Ok will check.
Re: Error Message
Posted:
Sat Sep 09, 2017 3:00 pm
by kw123
did exactly that .. no (error) message.. I guess we need to wait until it reappears..? don't know what to do if I can not replicate
